[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-355-g003080f
git at osgeo.org
git at osgeo.org
Thu Jul 15 07:51:19 PDT 2021
the project "PostGIS".
The branch, main has been updated
via 003080f251566e9b91577c2f8177cbb3c25e4d81 (commit)
from 92b06f13feb21f1b903c2b7f713c39ca5fd1cc8a (commit)
revisions in full, below.
commit 003080f251566e9b91577c2f8177cbb3c25e4d81
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jul 15 16:50:53 2021 +0200
Remove redundant AddNode() function
Closes #2592
diff --git a/topology/sql/populate.sql.in b/topology/sql/populate.sql.in
index 38a83fa..361f13a 100644
--- a/topology/sql/populate.sql.in
+++ b/topology/sql/populate.sql.in
@@ -85,7 +85,7 @@ $$ LANGUAGE 'plpgsql' STABLE STRICT;
-- geografici basati su QuantumGIS e Postgis (CIG 0494241492)"
-CREATE OR REPLACE FUNCTION topology.AddNode(atopology varchar, apoint geometry, allowEdgeSplitting boolean, setContainingFace boolean DEFAULT false)
+CREATE OR REPLACE FUNCTION topology.AddNode(atopology varchar, apoint geometry, allowEdgeSplitting boolean DEFAULT false, setContainingFace boolean DEFAULT false)
RETURNS int
AS
@@ -177,19 +177,6 @@ LANGUAGE 'plpgsql' VOLATILE;
--- AddNode(atopology, point)
-CREATE OR REPLACE FUNCTION topology.AddNode(atopology varchar, apoint geometry)
- RETURNS int
-AS
- SELECT topology.AddNode($1, $2, false, false);
-LANGUAGE 'sql' VOLATILE;
---} AddNode
-- AddEdge(atopology, line)
-- Add an edge primitive to a topology and get its identifier.
diff --git a/topology/topology_drop_before.sql.in b/topology/topology_drop_before.sql.in
index 686f8aa..03e93c6 100644
--- a/topology/topology_drop_before.sql.in
+++ b/topology/topology_drop_before.sql.in
@@ -23,3 +23,8 @@ DROP FUNCTION IF EXISTS topology._ST_AddFaceSplit(varchar, integer, integer, boo
-- Added optional bbox parameter in 3.2.0
DROP FUNCTION IF EXISTS topology.validatetopology(varchar);
+-- Merged the two function into one with both allowEdgeSplitting and setContainingFace parameters
+-- being optional (3.2.0)
+DROP FUNCTION IF EXISTS topology.AddNode(varchar, geometry);
+DROP FUNCTION IF EXISTS topology.AddNode(varchar, geometry, boolean, boolean);
Summary of changes:
topology/sql/populate.sql.in | 15 +--------------
topology/topology_drop_before.sql.in | 5 +++++
2 files changed, 6 insertions(+), 14 deletions(-)
hooks/post-receive
