[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-356-g8ed39fe
git at osgeo.org
git at osgeo.org
Thu Jul 15 08:03:51 PDT 2021
the project "PostGIS".
The branch, main has been updated
via 8ed39fe907fedd88758020d49a0357aff6afefbb (commit)
from 003080f251566e9b91577c2f8177cbb3c25e4d81 (commit)
revisions in full, below.
commit 8ed39fe907fedd88758020d49a0357aff6afefbb
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jul 15 17:03:04 2021 +0200
Rename topology drop before/after to topology before/after upgrade
Also remove one of those inputs from .gitignore
diff --git a/.gitignore b/.gitignore
index cea4c4e..14d4342 100644
--- a/.gitignore
+++ b/.gitignore
@@ -171,10 +171,8 @@ topology/test/load_topology-4326.sql
topology/test/load_topology.sql
topology/test/topo_predicates.sql
topology/test/regress/topogeo_addlinestring_expected
-topology/topology_drop_after.sql
-topology/topology_drop_after.sql.in
-topology/topology_drop_before.sql
-topology/topology_drop_before.sql.in
+topology/topology_after_upgrade.sql
+topology/topology_before_upgrade.sql
topology/topology.sql
topology/topology.sql.in
topology/topology_upgrade.sql*
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 42763b6..07c6993 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -37,8 +37,8 @@ SQLPP = @SQLPP@
SQL_OBJS = \
topology.sql \
topology_upgrade.sql \
- topology_drop_before.sql \
- topology_drop_after.sql
+ topology_before_upgrade.sql \
+ topology_after_upgrade.sql
# Objects to build using PGXS
@@ -105,7 +105,7 @@ endif
topology_upgrade.sql.in: topology.sql
$(PERL) -0777 -ne 's/^(CREATE|ALTER) (CAST|OPERATOR|TYPE|TABLE|SCHEMA|DOMAIN|TRIGGER).*?;//msg;print;' $< > $@
-topology_upgrade.sql: topology_drop_before.sql topology_upgrade.sql.in topology_drop_after.sql
+topology_upgrade.sql: topology_before_upgrade.sql topology_upgrade.sql.in topology_after_upgrade.sql
cat $^ > $@
topology.sql: \
diff --git a/topology/topology_drop_after.sql.in b/topology/topology_after_upgrade.sql.in
similarity index 100%
rename from topology/topology_drop_after.sql.in
rename to topology/topology_after_upgrade.sql.in
diff --git a/topology/topology_drop_before.sql.in b/topology/topology_before_upgrade.sql.in
rename from topology/topology_drop_before.sql.in
rename to topology/topology_before_upgrade.sql.in
Summary of changes:
.gitignore | 6 ++----
topology/Makefile.in | 6 +++---
.../{topology_drop_after.sql.in => topology_after_upgrade.sql.in} | 0
.../{topology_drop_before.sql.in => topology_before_upgrade.sql.in} | 0
4 files changed, 5 insertions(+), 7 deletions(-)
rename topology/{topology_drop_after.sql.in => topology_after_upgrade.sql.in} (100%)
rename topology/{topology_drop_before.sql.in => topology_before_upgrade.sql.in} (100%)
hooks/post-receive
