[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-371-g43b7eeb
git at osgeo.org
git at osgeo.org
Wed Jul 28 20:01:34 PDT 2021
the project "PostGIS".
The branch, main has been updated
via 43b7eeb630f6e480b60b3ab32091c1e186090407 (commit)
from 095fecc955e5c76535661564bc278b9d0a8b2ef2 (commit)
revisions in full, below.
commit 43b7eeb630f6e480b60b3ab32091c1e186090407
Author: Regina Obe <lr at pcorp.us>
Date: Wed Jul 28 23:01:30 2021 -0400
Remove renaming of geoid to tabblock_id. References #4958
diff --git a/extras/tiger_geocoder/tiger_loader_2020.sql b/extras/tiger_geocoder/tiger_loader_2020.sql
index d3bd187..edfe17d 100644
--- a/extras/tiger_geocoder/tiger_loader_2020.sql
+++ b/extras/tiger_geocoder/tiger_loader_2020.sql
@@ -294,8 +294,7 @@ ${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"', '{g
INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, single_geom_mode, insert_mode, pre_load_process, post_load_process, columns_exclude )
VALUES(11, 'tabblock20', 'tabblock20', true, false, true,false, 'c',
'${psql} -c "CREATE TABLE ${data_schema}.${state_abbrev}_${lookup_name}(CONSTRAINT pk_${state_abbrev}_${lookup_name} PRIMARY KEY (geoid)) INHERITS(tiger.${lookup_name});" ',
-'${psql} -c "ALTER TABLE ${staging_schema}.${state_abbrev}_${table_name} RENAME geoid20 TO tabblock_id;
-SELECT loader_load_staged_data(lower(''${state_abbrev}_${table_name}''), lower(''${state_abbrev}_${lookup_name}'')); "
+'${psql} -c "SELECT loader_load_staged_data(lower(''${state_abbrev}_${table_name}''), lower(''${state_abbrev}_${lookup_name}'')); "
${psql} -c "ALTER TABLE ${data_schema}.${state_abbrev}_${lookup_name} ADD CONSTRAINT chk_statefp CHECK (statefp = ''${state_fips}'');"
${psql} -c "CREATE INDEX ${data_schema}_${state_abbrev}_${lookup_name}_the_geom_gist ON ${data_schema}.${state_abbrev}_${lookup_name} USING gist(the_geom);"
${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"', '{gid}'::text[]);
Summary of changes:
extras/tiger_geocoder/tiger_loader_2020.sql | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
hooks/post-receive
