[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-380-g09c3683
Fri Jul 30 12:01:49 PDT 2021
the project "PostGIS".
       via  09c36831d267c1ccd14fc83a13a31421df424b93 (commit)
      from  320a7b548f9c93415f6afd99d1f2dee9558e043e (commit)
revisions in full, below.
commit 09c36831d267c1ccd14fc83a13a31421df424b93
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Fri Jul 30 12:06:47 2021 -0700
    Fix doc typo
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index 0cc89a5..00345b8 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -166,7 +166,7 @@
       <ulink url="https://www.iso.org/obp/ui/#iso:std:iso-iec:13249:-3:ed-5:v1:en"><emphasis>ISO/IEC 13249-3 SQL Multimedia - Spatial</emphasis></ulink>
       standard (SQL/MM) extends the
 	  OGC SFA to define Geometry subtypes containing curves with circular arcs.
-      The SQL/MM types supprt 3DM, 3DZ and 4D coordinates.
+      The SQL/MM types support 3DM, 3DZ and 4D coordinates.
 	  </para>
 	  <note>
 		<para>All floating point comparisons within the SQL-MM implementation
Summary of changes:
 doc/using_postgis_dataman.xml | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
