[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-382-g064a015
git at osgeo.org
git at osgeo.org
Fri Jul 30 12:41:17 PDT 2021
the project "PostGIS".
The branch, main has been updated
via 064a015cf411664174271778dd0730764877da6e (commit)
via b4e803db05d0d36b06bf0a12d3fb0b9a85a7e8c2 (commit)
from 09c36831d267c1ccd14fc83a13a31421df424b93 (commit)
revisions in full, below.
commit 064a015cf411664174271778dd0730764877da6e
Merge: 09c3683 b4e803d
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Jul 30 12:41:12 2021 -0700
Merge branch 'main-json-empty' into main
commit b4e803db05d0d36b06bf0a12d3fb0b9a85a7e8c2
Date: Fri Jul 30 12:34:59 2021 -0700
Allow empty geometry to round-trip JSON format, references #4895
diff --git a/liblwgeom/cunit/cu_in_geojson.c b/liblwgeom/cunit/cu_in_geojson.c
index bb3ce74..439cf9b 100644
--- a/liblwgeom/cunit/cu_in_geojson.c
+++ b/liblwgeom/cunit/cu_in_geojson.c
@@ -40,6 +40,10 @@ static void do_geojson_test(const char * exp, char * in, char * exp_srs)
fprintf(stderr, "\nIn: %s\nExp: %s\nObt: %s\n", in, exp, h);
CU_ASSERT_STRING_EQUAL(h, exp);
+ else
+ CU_ASSERT_STRING_EQUAL(h, exp);
if ( exp_srs )
@@ -199,6 +203,36 @@ static void in_geojson_test_geoms(void)
"GEOMETRYCOLLECTION EMPTY",
"{\"type\":\"GeometryCollection\",\"geometries\":[]}",
NULL);
+ /* Empty Point */
+ do_geojson_test(
+ "POINT EMPTY",
+ "{\"type\":\"Point\",\"coordinates\":[]}",
+ NULL);
+ /* Empty LineString */
+ do_geojson_test(
+ "LINESTRING EMPTY",
+ "{\"type\":\"LineString\",\"coordinates\":[]}",
+ NULL);
+ /* Empty Polygon */
+ do_geojson_test(
+ "POLYGON EMPTY",
+ "{\"type\":\"Polygon\",\"coordinates\":[]}",
+ NULL);
+ /* Empty MultiPoint */
+ do_geojson_test(
+ "MULTIPOINT EMPTY",
+ "{\"type\":\"MultiPoint\",\"coordinates\":[]}",
+ NULL);
+ /* Empty MultiPolygon */
+ do_geojson_test(
+ "MULTIPOLYGON EMPTY",
+ "{\"type\":\"MultiPolygon\",\"coordinates\":[]}",
+ NULL);
diff --git a/liblwgeom/lwin_geojson.c b/liblwgeom/lwin_geojson.c
index 4816641..85b29ef 100644
--- a/liblwgeom/lwin_geojson.c
+++ b/liblwgeom/lwin_geojson.c
@@ -111,6 +111,8 @@ parse_geojson_coord(json_object *poObj, int *hasz, POINTARRAY *pa)
json_object *poObjCoord = NULL;
const int nSize = json_object_array_length(poObj);
+ if (nSize == 0)
+ return LW_TRUE;
if (nSize < 2)
lwerror("Too few ordinates in GeoJSON");
diff --git a/liblwgeom/lwout_geojson.c b/liblwgeom/lwout_geojson.c
index a427e99..7218399 100644
--- a/liblwgeom/lwout_geojson.c
+++ b/liblwgeom/lwout_geojson.c
@@ -370,14 +370,17 @@ asgeojson_multipoint_size(const LWMPOINT *mpoint, const char *srs, GBOX *bbox, i
LWPOINT * point;
int size;
- uint32_t i;
+ uint32_t i, ngeoms = mpoint->ngeoms;
size = sizeof("{'type':'MultiPoint',");
if (srs) size += asgeojson_srs_size(srs);
if (bbox) size += asgeojson_bbox_size(FLAGS_GET_Z(mpoint->flags), precision);
size += sizeof("'coordinates':[]}");
- for (i=0; i<mpoint->ngeoms; i++)
+ if (lwgeom_is_empty((LWGEOM*)mpoint))
+ ngeoms = 0;
+ for (i=0; i<ngeoms; i++)
point = mpoint->geoms[i];
size += pointArray_geojson_size(point->point, precision);
@@ -391,7 +394,7 @@ static size_t
asgeojson_multipoint_buf(const LWMPOINT *mpoint, const char *srs, char *output, GBOX *bbox, int precision)
LWPOINT *point;
- uint32_t i;
char *ptr=output;
ptr += sprintf(ptr, "{\"type\":\"MultiPoint\",");
@@ -399,7 +402,10 @@ asgeojson_multipoint_buf(const LWMPOINT *mpoint, const char *srs, char *output,
if (bbox) ptr += asgeojson_bbox_buf(ptr, bbox, FLAGS_GET_Z(mpoint->flags), precision);
ptr += sprintf(ptr, "\"coordinates\":[");
+ ngeoms = 0;
if (i) ptr += sprintf(ptr, ",");
@@ -431,14 +437,17 @@ asgeojson_multiline_size(const LWMLINE *mline, const char *srs, GBOX *bbox, int
LWLINE * line;
int size;
- uint32_t i;
+ uint32_t i, ngeoms = mline->ngeoms;
size = sizeof("{'type':'MultiLineString',");
if (bbox) size += asgeojson_bbox_size(FLAGS_GET_Z(mline->flags), precision);
- for (i=0 ; i<mline->ngeoms; i++)
+ if (lwgeom_is_empty((LWGEOM*)mline))
+ ngeoms = 0;
+ for (i=0 ; i<ngeoms; i++)
line = mline->geoms[i];
size += pointArray_geojson_size(line->points, precision);
@@ -453,7 +462,7 @@ static size_t
asgeojson_multiline_buf(const LWMLINE *mline, const char *srs, char *output, GBOX *bbox, int precision)
LWLINE *line;
- uint32_t i;
char *ptr=output;
ptr += sprintf(ptr, "{\"type\":\"MultiLineString\",");
@@ -461,7 +470,10 @@ asgeojson_multiline_buf(const LWMLINE *mline, const char *srs, char *output, GBO
if (bbox) ptr += asgeojson_bbox_buf(ptr, bbox, FLAGS_GET_Z(mline->flags), precision);
- for (i=0; i<mline->ngeoms; i++)
+ ngeoms = 0;
ptr += sprintf(ptr, "[");
@@ -496,14 +508,17 @@ asgeojson_multipolygon_size(const LWMPOLY *mpoly, const char *srs, GBOX *bbox, i
LWPOLY *poly;
int size;
- uint32_t i, j;
+ uint32_t i, j, ngeoms = mpoly->ngeoms;
size = sizeof("{'type':'MultiPolygon',");
if (bbox) size += asgeojson_bbox_size(FLAGS_GET_Z(mpoly->flags), precision);
- for (i=0; i < mpoly->ngeoms; i++)
+ if (lwgeom_is_empty((LWGEOM*)mpoly))
+ ngeoms = 0;
+ for (i=0; i < ngeoms; i++)
poly = mpoly->geoms[i];
for (j=0 ; j <poly->nrings ; j++)
@@ -523,14 +538,18 @@ static size_t
asgeojson_multipolygon_buf(const LWMPOLY *mpoly, const char *srs, char *output, GBOX *bbox, int precision)
LWPOLY *poly;
- uint32_t i, j;
char *ptr=output;
ptr += sprintf(ptr, "{\"type\":\"MultiPolygon\",");
if (srs) ptr += asgeojson_srs_buf(ptr, srs);
if (bbox) ptr += asgeojson_bbox_buf(ptr, bbox, FLAGS_GET_Z(mpoly->flags), precision);
- for (i=0; i<mpoly->ngeoms; i++)
+ ngeoms = 0;
@@ -568,7 +587,7 @@ asgeojson_multipolygon(const LWMPOLY *mpoly, const char *srs, GBOX *bbox, int pr
static size_t
asgeojson_collection_size(const LWCOLLECTION *col, const char *srs, GBOX *bbox, int precision)
- uint32_t i;
+ uint32_t i, ngeoms = col->ngeoms;
size_t size;
LWGEOM *subgeom;
@@ -577,7 +596,10 @@ asgeojson_collection_size(const LWCOLLECTION *col, const char *srs, GBOX *bbox,
if (bbox) size += asgeojson_bbox_size(FLAGS_GET_Z(col->flags), precision);
size += sizeof("'geometries':");
- for (i=0; i<col->ngeoms; i++)
+ if (lwgeom_is_empty((LWGEOM*)col))
+ ngeoms = 0;
subgeom = col->geoms[i];
size += asgeojson_geom_size(subgeom, NULL, precision);
@@ -591,7 +613,7 @@ asgeojson_collection_size(const LWCOLLECTION *col, const char *srs, GBOX *bbox,
static size_t
asgeojson_collection_buf(const LWCOLLECTION *col, const char *srs, char *output, GBOX *bbox, int precision)
- uint32_t i;
char *ptr=output;
LWGEOM *subgeom;
@@ -600,7 +622,10 @@ asgeojson_collection_buf(const LWCOLLECTION *col, const char *srs, char *output,
if (col->ngeoms && bbox) ptr += asgeojson_bbox_buf(ptr, bbox, FLAGS_GET_Z(col->flags), precision);
ptr += sprintf(ptr, "\"geometries\":[");
+ ngeoms = 0;
diff --git a/regress/core/in_geojson_expected b/regress/core/in_geojson_expected
index e3c4eec..d4e6d52 100644
--- a/regress/core/in_geojson_expected
+++ b/regress/core/in_geojson_expected
@@ -12,8 +12,8 @@ ERROR: Unable to find 'coordinates' in GeoJSON string
ERROR: unexpected character (at offset 0)
ERROR: unexpected end of data (at offset 0)
ERROR: invalid GeoJSON representation
-ERROR: Too few ordinates in GeoJSON
+#1434.5|0101000020E6100000000000000000F87F000000000000F87F
+#1434.6|0104000020E610000000000000
#2130|50
Summary of changes:
liblwgeom/cunit/cu_in_geojson.c | 34 ++++++++++++++++++++++++
liblwgeom/lwin_geojson.c | 2 ++
liblwgeom/lwout_geojson.c | 57 +++++++++++++++++++++++++++++-----------
regress/core/in_geojson_expected | 4 +--
4 files changed, 79 insertions(+), 18 deletions(-)
hooks/post-receive
