[postgis-tickets] [PostGIS] #4905: Revise shp2pgsql regress tests to include checking sql output
trac at osgeo.org
Mon May 3 18:48:29 PDT 2021
Reporter: robe | Owner: stefanpetrea
Type: defect | Status: new
Priority: low | Milestone: PostGIS 3.2.0
Component: loader/dumper | Version: master
Resolution: | Keywords:
Comment (by stefanpetrea):
Currently, the SQL output generated by shp2pgsql is generated
[https://github.com/postgis/postgis/blob/82ab7bc5a31f68ab42acdec48f558aac3b855804/regress/run_test.pl#L942
in a file] but it's overwritten every time a new loader test is run.
In this pull request,
[https://github.com/postgis/postgis/pull/611/commits/d1bd14c3bcc781af895b464e10b0350d478ef9c9
#diff-0c9a2f7dbae71864e1d826c0dde26f8307227843b9413d0a8b08a9f41adc4b5bR973
a check is now in place] if -Z was among the parameters passed to the
loader, in which case, the generated SQL is checked for ANALYZE
statements, and we expect there to be zero such statements there.
Please review [https://github.com/postgis/postgis/pull/611 pull request
611]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4905#comment:3>
