[postgis-tickets] [PostGIS] #4905: Revise shp2pgsql regress tests to include checking sql output
trac at osgeo.org
Wed May 5 14:23:31 PDT 2021
Reporter: robe | Owner: stefanpetrea
Type: defect | Status: new
Priority: low | Milestone: PostGIS 3.2.0
Component: loader/dumper | Version: master
Resolution: | Keywords:
Comment (by stefanpetrea):
Okay, I've discussed with strk. The approach in
[https://github.com/postgis/postgis/pull/611 PR 611] is to test if the SQL
generated by the loader contains ANALYZE statements. This was done by
modifying the run_test.pl Perl script.
There is another approach, which is to verify that no ANALYZE were run on
the database by checking the system catalogs to see if the table
statistics are up-to-date.
I've discussed this with Sandro (@strk) and he likes this more than the
previous approach.
Please review [https://github.com/postgis/postgis/pull/612 PR 612].
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4905#comment:4>
