[postgis-tickets] [PostGIS] #4921: PDF Doc building is failing
trac at osgeo.org
Sun May 23 14:07:05 PDT 2021
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.3
Component: documentation | Version: 3.1.x
Keywords: |
I noticed the postgis-3.1.2.pdf did not build (not in
http://postgis.net/stuff) folder, but the epub and html docs are there.
I checked the build and registers this - though it returns success:
https://debbie.postgis.net/job/PostGIS_Make_Dist/label=debbie/2499/consoleFull
19:09:16 Missing character ─
19:09:16 Missing character ─Unexpected error occured
19:09:17 Build postgis-out.pdf
19:09:47 pdflatex failed
19:09:47 Unexpected error occured
19:09:47 Error: pdflatex compilation failed
Going to check how long this has been going on and if can be fixable.
Might be caused by patch updates.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4921>
