[postgis-tickets] [PostGIS] #4921: PDF Doc building is failing
PostGIS trac at osgeo.org
Tue May 25 08:58:34 PDT 2021
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  blocker        |  Milestone:  PostGIS 3.1.3
 Component:  documentation  |    Version:  3.1.x
Resolution:                 |   Keywords:
Comment (by robe):
 just noticed this little tidbit that might be the smoking gun
 20:39:06 convert-im6.q16: attempt to perform an operation not allowed by
 the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/421.
 20:39:07 Unexpected error occured
 20:39:07 convert
 /var/lib/jenkins/workspace/PostGIS_Make_Dist/label/debbie/38ab76ac397dbf977a409824ebb55651d63e9060/doc/html/images
 /st_touches-math.gif fig1.pdf
 20:39:07 convert-im6.q16: attempt to perform an operation not allowed by
 So looks like might be because of some change in st_touches
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4921#comment:1>
