[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0alpha1-50-gb02b7bf
git at osgeo.org
git at osgeo.org
Wed Oct 6 13:04:33 PDT 2021
the project "PostGIS".
via b02b7bf7b64337665e2e824d15e71f2d2c02734e (commit)
from 32dd1e743aaabaf886ea631c757626036d62189f (commit)
revisions in full, below.
commit b02b7bf7b64337665e2e824d15e71f2d2c02734e
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Oct 6 12:42:59 2021 -0700
Turn off windowing support in ST_AsMVT
diff --git a/postgis/mvt.c b/postgis/mvt.c
index 4259aba..f128e6c 100644
--- a/postgis/mvt.c
+++ b/postgis/mvt.c
@@ -1069,8 +1069,8 @@ static VectorTile__Tile * mvt_ctx_to_tile(mvt_agg_context *ctx)
static bytea *mvt_ctx_to_bytea(mvt_agg_context *ctx)
- /* Fill out the file slot, if it's not already filled. */
- /* We should only have a filled slow when all the work of building */
+ /* Fill out the tile slot, if it's not already filled. */
+ /* We should only have a filled slot when all the work of building */
/* out the data is complete, so after a serialize/deserialize cycle */
/* or after a context combine */
size_t len;
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index ce2b4fc..e7887a2 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4871,7 +4871,7 @@ CREATE OR REPLACE FUNCTION pgis_asmvt_deserialfn(bytea, internal)
_COST_MEDIUM;
-- Availability: 2.4.0
--- Changed: 2.5.0
+-- Changed: 3.2.0
CREATE AGGREGATE ST_AsMVT(anyelement)
sfunc = pgis_asmvt_transfn,
@@ -4881,10 +4881,13 @@ CREATE AGGREGATE ST_AsMVT(anyelement)
deserialfunc = pgis_asmvt_deserialfn,
combinefunc = pgis_asmvt_combinefn,
finalfunc = pgis_asmvt_finalfn
+#if POSTGIS_PGSQL_VERSION >= 110
+ ,finalfunc_modify = read_write
+#endif
--- Changed: 2.5.0
+-- Changed: 3.2.0
CREATE AGGREGATE ST_AsMVT(anyelement, text)
@@ -4894,10 +4897,13 @@ CREATE AGGREGATE ST_AsMVT(anyelement, text)
+#endif
--- Changed: 2.5.0
+-- Changed: 3.2.0
CREATE AGGREGATE ST_AsMVT(anyelement, text, int4)
@@ -4907,10 +4913,13 @@ CREATE AGGREGATE ST_AsMVT(anyelement, text, int4)
+#endif
--- Changed: 2.5.0
+-- Changed: 3.2.0
CREATE AGGREGATE ST_AsMVT(anyelement, text, int4, text)
@@ -4920,10 +4929,13 @@ CREATE AGGREGATE ST_AsMVT(anyelement, text, int4, text)
+#endif
-- Availability: 3.0.0
--- Changed: 3.0.0
+-- Changed: 3.2.0
CREATE AGGREGATE ST_AsMVT(anyelement, text, int4, text, text)
@@ -4933,6 +4945,9 @@ CREATE AGGREGATE ST_AsMVT(anyelement, text, int4, text, text)
+#endif
Summary of changes:
postgis/mvt.c | 4 ++--
postgis/postgis.sql.in | 25 ++++++++++++++++++++-----
2 files changed, 22 insertions(+), 7 deletions(-)
hooks/post-receive
