[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.4-5-gec7f996
git at osgeo.org
git at osgeo.org
Thu Oct 14 11:53:57 PDT 2021
the project "PostGIS".
The branch, stable-3.1 has been updated
via ec7f996bc9537919ea900f2517ab6ceae78c2b70 (commit)
from 7b58a4644dc0d4b9ebedfd33d4e3f9fc717ad211 (commit)
revisions in full, below.
commit ec7f996bc9537919ea900f2517ab6ceae78c2b70
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Oct 14 11:53:30 2021 -0700
Round off some regression results to avoid spurious regression test failures under the latest GEOS release.
diff --git a/regress/core/regress_buffer_params.sql b/regress/core/regress_buffer_params.sql
index 2e05a7f..21a7e76 100644
--- a/regress/core/regress_buffer_params.sql
+++ b/regress/core/regress_buffer_params.sql
@@ -5,7 +5,7 @@
-- Ouput is snapped to grid to account for small floating numbers
-- differences between architectures
-SELECT 'point quadsegs=2', ST_AsText(st_buffer('POINT(0 0)', 1, 'quad_segs=2'), 4);
+SELECT 'point quadsegs=2', ST_AsText(ST_SnapToGrid(st_buffer('POINT(0 0)', 1, 'quad_segs=2'),0.0001), 4);
SELECT 'line quadsegs=2', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2'), 3);
SELECT 'line quadsegs=2 endcap=flat', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=flat'), 5);
SELECT 'line quadsegs=2 endcap=butt', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=butt'), 5);
diff --git a/regress/core/regress_buffer_params_expected b/regress/core/regress_buffer_params_expected
index 6bd9d4f..2884744 100644
--- a/regress/core/regress_buffer_params_expected
+++ b/regress/core/regress_buffer_params_expected
@@ -1,4 +1,4 @@
-point quadsegs=2|POLYGON((1 0,0.7071 -0.7071,1.6155e-15 -1,-0.7071 -0.7071,-1 -3.2311e-15,-0.7071 0.7071,-4.6246e-15 1,0.7071 0.7071,1 0))
+point quadsegs=2|POLYGON((1 0,0.7071 -0.7071,0 -1,-0.7071 -0.7071,-1 0,-0.7071 0.7071,0 1,0.7071 0.7071,1 0))
line quadsegs=2|POLYGON((10 2,11.414 1.414,12 0,11.414 -1.414,10 -2,0 -2,-1.414 -1.414,-2 2.449e-16,-1.414 1.414,0 2,10 2))
line quadsegs=2 endcap=flat|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
line quadsegs=2 endcap=butt|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index dd4d365..e07b50c 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -311,7 +311,7 @@ SELECT '#650', ST_AsText(ST_Collect(ARRAY[ST_MakePoint(0,0), ST_MakePoint(1,1),
--SELECT '#662', ST_MakePolygon(ST_AddPoint(ST_AddPoint(ST_MakeLine(ST_SetSRID(ST_MakePointM(i+m,j,m),4326),ST_SetSRID(ST_MakePointM(j+m,i-m,m),4326)),ST_SetSRID(ST_MakePointM(i,j,m),4326)),ST_SetSRID(ST_MakePointM(i+m,j,m),4326))) As the_geom FROM generate_series(-10,50,20) As i CROSS JOIN generate_series(50,70, 20) As j CROSS JOIN generate_series(1,2) As m ORDER BY i, j, m, i*j*m LIMIT 1;
-- #667 --
-SELECT '#667', ST_AsEWKT(ST_LineToCurve(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j))) As the_geom FROM generate_series(-10,50,10) As i CROSS JOIN generate_series(40,70, 20) As j ORDER BY i, j, i*j LIMIT 1;
+SELECT '#667', ST_AsText(ST_LineToCurve(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j)),4) As geom FROM generate_series(-10,50,10) As i CROSS JOIN generate_series(40,70, 20) As j ORDER BY i, j, i*j LIMIT 1;
-- #677 --
SELECT '#677.deprecated',round(ST_DistanceSpheroid(ST_GeomFromEWKT('MULTIPOLYGON(((-10 40,-10 55,-10 70,5 40,-10 40)))'), ST_GeomFromEWKT('MULTIPOINT(20 40,20 55,20 70,35 40,35 55,35 70,50 40,50 55,50 70)'), 'SPHEROID["GRS_1980",6378137,298.257222101]')) As result;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index f8dfdd9..91b8e7c 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -93,7 +93,7 @@ NOTICE: IllegalArgumentException: Invalid number of points in LinearRing found
#835.11|MULTILINESTRING EMPTY
#835.12|MULTIPOLYGON EMPTY
#650|MULTIPOINT(0 0,1 1,2 2)
-#667|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(30 40,-50 39.99999999999987,30 40))
+#667|CURVEPOLYGON(CIRCULARSTRING(30 40,-50 40,30 40))
#677.deprecated|1121395
#677|1121395
#680|01d107000000000000000024c000000000000049400000000000000040
Summary of changes:
regress/core/regress_buffer_params.sql | 2 +-
regress/core/regress_buffer_params_expected | 2 +-
regress/core/tickets.sql | 2 +-
regress/core/tickets_expected | 2 +-
4 files changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
