[postgis-tickets] [PostGIS] #5009: Inconsistent results when using empty geometries with different SRIDS
trac at osgeo.org
Wed Oct 20 15:32:32 PDT 2021
Reporter: samuelspurling | Owner: pramsey
Type: defect | Status: closed
Priority: low | Milestone: PostGIS 3.1.5
Component: postgis | Version: 3.1.x
Resolution: wontfix | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => wontfix
Comment:
Okay so with the index, no fail.
And when drop index
DROP INDEX test_table_lines_geom_idx;
SELECT *
FROM test_table_lines t
WHERE st_dwithin(st_setsrid(ST_GeomFromText('MULTILINESTRING EMPTY'), 0),
t.geom, 1);
Bam fail with:
ERROR: LWGEOM_dwithin: Operation on mixed SRID geometries
(MultiLineString, 0) != (LineString, 27700)
SQL state: XX000
That said yes it's a regression and the behavior is not the same. That
said is this something we can even fix even if we cared to fix it without
some dier consequences? I think the answer is NO.
So marking this as a won't fix.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5009#comment:1>
