[postgis-tickets] [PostGIS] #5005: ST_FlatGeoBuf crashes on tables when geometry column is not the first column (was: ST_FlatGeoBuf crashes on tables with non-geometry attributes)
PostGIS trac at osgeo.org
Sat Oct 23 09:15:16 PDT 2021
column
  Reporter:  robe      |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 3.2.0
 Component:  postgis   |    Version:  master
Resolution:            |   Keywords:
Comment (by robe):
 Okay I think I at least understand the issue now.  If the first column
 isn't the geometry and it is a numeric, it crashes.  If the first column
 is a geometry then it's fine.
 So this crashes:
 SELECT ST_ASFlatGeobuf(t)
 FROM (SELECT 1 AS x, ST_Point(1,2) AS geom FROM test) AS t;
 But this doesn't:
 FROM (SELECT ST_Point(1,2) AS geom, 1 AS x FROM test) AS t;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5005#comment:5>
