[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0alpha1-54-g6c4b273fc
git at osgeo.org
git at osgeo.org
Sat Oct 23 14:14:14 PDT 2021
the project "PostGIS".
via 6c4b273fc235336ff24ea81eff776b6bcc1ba578 (commit)
from 525ea989af301a2c27fc1375db6dc4de4b831dc6 (commit)
revisions in full, below.
commit 6c4b273fc235336ff24ea81eff776b6bcc1ba578
Author: Regina Obe <lr at pcorp.us>
Date: Sat Oct 23 17:14:07 2021 -0400
Prep for PostGIS 3.2.0beta1 release
diff --git a/NEWS b/NEWS
index be16a57e2..73e05a3c3 100644
--- a/NEWS
+++ b/NEWS
@@ -1,3 +1,31 @@
+PostGIS 3.2.0beta1
+2021/10/23
+This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+
+Additional features are enabled if you are running GEOS 3.9+
+(and ST_MakeValid enhancements with 3.10+),
+Proj 6.1+, and PostgreSQL 14+.
+Changes since PostGIS 3.2.0alpa1 release:
+ * Bug Fixes and Breaking Changes *
+ - #5012, Clean regress against released GEOS 3.10.0
+ (Regina Obe, Paul Ramsey)
+ - #5000, Turn off Window support in ST_AsMVT aggregate
+ as no real use-case for it and it crashes with random input
+ (Paul Ramsey)
+ - #4994, shp2pgsql is sometimes missing the INSERT statements
+ (Sandro Santilli)
+ - #4990, getfacecontainingpoint fails on i386 (Sandro Santilli)
+ - #5008, Have ST_DWithin with EMPTY operand always return false
+ (Sandro Santilli)
+ - #5002, liblwgeom should build with warning flags by default
+ (Sandro Santilli)
+ * Enhancements *
+ - #4997, FlatGeobuf format input/output (Björn Harrtell)
PostGIS 3.2.0
2021/xx/xx
diff --git a/README.postgis b/README.postgis
index e58f682e1..c7b937282 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.2.0alpha1
-:Date: 2021-09-10
+:Version: 3.2.0beta1
+:Date: 2021-10-23
:Website: https://postgis.net
This distribution contains a module which implements GIS simple features, ties
@@ -46,6 +46,7 @@ this to work.
https://proj.org
* GEOS (Required, Version 3.6 or higher)
+ - 3/10+ for ST_MakeValid enhancements
- 3.9+ is needed to take advantage of
fixed precision enhancements in overlay functions
- 3.7+ is needed just for the ST_FrechetDistance function
diff --git a/Version.config b/Version.config
index 843963a1e..4ffd6bd2d 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=3
POSTGIS_MINOR_VERSION=2
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0beta1
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 9af06cbe7..d7ce29e01 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -3,6 +3,33 @@
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
<sect1>
+ <title>Release 3.2.0beta1</title>
+ <para>Release date: 2021/10/23</para>
+ <para>This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+
+Proj 6.1+, and PostgreSQL 14+.</para>
+ <simplesect>
+ <title>Bug Fixes and Breaking Changes</title>
+ <para>5012, Clean regress against released GEOS 3.10.0
+ (Regina Obe, Paul Ramsey)</para>
+ <para>5000, Turn off Window support in ST_AsMVT aggregate
+ (Paul Ramsey)</para>
+ <para>4994, shp2pgsql is sometimes missing the INSERT statements
+ (Sandro Santilli)</para>
+ <para>4990, getfacecontainingpoint fails on i386 (Sandro Santilli)</para>
+ <para>5008, Have ST_DWithin with EMPTY operand always return false
+ <para>5002, liblwgeom should build with warning flags by default
+ </simplesect>
+ <simplesect>
+ <title>Enhancements</title>
+ <para>4997, FlatGeobuf format input/output (Björn Harrtell)</para>
+ </simplesect>
+ </sect1>
+ <sect1>
<title>Release 3.2.0alpha1</title>
<para>Release date: 2021/09/10</para>
<para>This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9 or higher
Summary of changes:
NEWS | 28 ++++++++++++++++++++++++++++
README.postgis | 5 +++--
Version.config | 2 +-
doc/release_notes.xml | 27 +++++++++++++++++++++++++++
4 files changed, 59 insertions(+), 3 deletions(-)
hooks/post-receive
