[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0beta1-6-gf54850681
git at osgeo.org
git at osgeo.org
Wed Oct 27 08:48:50 PDT 2021
the project "PostGIS".
via f54850681cdea539141586e1a12bd6e0627baa11 (commit)
via 81bbb9abbeeebf03a2a36fee8cfb32a93c3bf83c (commit)
via 1821d309fd0962135ca3e5909454edbcaa839287 (commit)
via 101d4642c1d32e99d860af38f6d9b3d723bd07fb (commit)
from df88c3dba84355b44b85d852753bc8459f0a6ebc (commit)
revisions in full, below.
commit f54850681cdea539141586e1a12bd6e0627baa11
Merge: df88c3dba 81bbb9abb
Author: leoregina <lr at pcorp.us>
Date: Wed Oct 27 11:48:39 2021 -0400
Merge remote-tracking branch 'bartoletti/freebsd_ci'
commit 81bbb9abbeeebf03a2a36fee8cfb32a93c3bf83c
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date: Mon Sep 27 14:19:34 2021 +0200
change order and remove useless upgrade
diff --git a/.cirrus.yml b/.cirrus.yml
index 3d19f6125..265633c79 100644
--- a/.cirrus.yml
+++ b/.cirrus.yml
@@ -5,8 +5,8 @@ freebsd_instance:
task:
install_script:
- - ASSUME_ALWAYS_YES=yes pkg bootstrap -f ; pkg upgrade -y
- sed -i.bak -e 's,pkg+http://pkg.FreeBSD.org/\${ABI}/quarterly,pkg+http://pkg.FreeBSD.org/\${ABI}/latest,' /etc/pkg/FreeBSD.conf
+ - ASSUME_ALWAYS_YES=yes pkg bootstrap -f
- pkg install -y bison postgresql12-server gmake libxml2 autoconf automake libtool pkgconf iconv pcre proj gdal sfcgal geos libxslt cunit protobuf-c json-c postgresql12-contrib
patch_script:
commit 1821d309fd0962135ca3e5909454edbcaa839287
Date: Mon Sep 27 14:18:31 2021 +0200
remove useless parts
index 3ed7d6656..3d19f6125 100644
--- a/.cirrus.yml
+++ b/.cirrus.yml
@@ -4,13 +4,6 @@ freebsd_instance:
memory: 16G
task:
- timeout_in: 320m
- sysinfo_script:
- - mount
- - df -h
- - sysctl hw.model hw.ncpu hw.physmem
- - freebsd-version
install_script:
commit 101d4642c1d32e99d860af38f6d9b3d723bd07fb
Date: Mon Sep 27 14:04:04 2021 +0200
Add cirrus_ci for FreeBSD
new file mode 100644
index 000000000..3ed7d6656
--- /dev/null
+++ b/.cirrus.yml
@@ -0,0 +1,41 @@
+freebsd_instance:
+ image: freebsd-12-2-release-amd64
+ cpu: 8
+ memory: 16G
+task:
+ timeout_in: 320m
+ sysinfo_script:
+ - mount
+ - df -h
+ - sysctl hw.model hw.ncpu hw.physmem
+ - freebsd-version
+ install_script:
+ - ASSUME_ALWAYS_YES=yes pkg bootstrap -f ; pkg upgrade -y
+ - sed -i.bak -e 's,pkg+http://pkg.FreeBSD.org/\${ABI}/quarterly,pkg+http://pkg.FreeBSD.org/\${ABI}/latest,' /etc/pkg/FreeBSD.conf
+ - pkg install -y bison postgresql12-server gmake libxml2 autoconf automake libtool pkgconf iconv pcre proj gdal sfcgal geos libxslt cunit protobuf-c json-c postgresql12-contrib
+ patch_script:
+ # will be removed
+ - find . -name "*.pl" | xargs sed -i -r 's|/usr/bin/perl|/usr/bin/env perl|'
+ configure_script:
+ - ./autogen.sh
+ - ./configure PKG_CONFIG=/usr/local/bin/pkgconf CFLAGS="-isystem /usr/local/include -Wall -fno-omit-frame-pointer -Werror" LDFLAGS="-L/usr/local/lib" --with-libiconv-prefix=/usr/local --without-gui --without-interrupt-tests --with-topology --with-gdalconfig=/usr/local/bin/gdal-config --with-sfcgal=/usr/local/bin/sfcgal-config --with-address-standardizer --with-protobuf
+ - service postgresql oneinitdb
+ - service postgresql onestart
+ - su -l postgres -c "createuser -s `whoami`"
+ build_script:
+ - gmake -j8
+ check_script:
+ - gmake -j8 check
+ - gmake -j8 install
+ - gmake -j8 check RUNTESTFLAGS="-v --extension"
+ - gmake -j8 check RUNTESTFLAGS="-v --dumprestore"
+ matrix:
+ - name: freebsd12-amd64
+ freebsd_instance:
+ - name: freebsd13-amd64
+ freebsd_instance:
+ image: freebsd-13-0-release-amd64
Summary of changes:
.cirrus.yml | 34 ++++++++++++++++++++++++++++++++++
1 file changed, 34 insertions(+)
create mode 100644 .cirrus.yml
hooks/post-receive
