[postgis-tickets] [PostGIS] #5005: ST_FlatGeoBuf crashes on tables when geometry column is not the first column
trac at osgeo.org
Mon Oct 25 21:42:31 PDT 2021
column
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by chodgson):
Hey I don't have a source checkout or time to test this at the moment, but
it looks to me like the problem is that the ctx->geom_index is used in
flatgeobuf_agg_transfn() before it is ever initialized properly - it is
initialized to 0 in flatgeobuf_agg_ctx_init() but it is set based on the
actual data types of the tuple and/or the specified geom column name in
encode_header() - which is called after geom_index is used in transfn() .
It looks like encode_header() should just be called at the end of the
init? Instead of conditionally in the transfn/finalfn?
Hope that helps.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5005#comment:6>
