[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0beta1-2-gdf88c3dba
git at osgeo.org
git at osgeo.org
Mon Oct 25 09:29:37 PDT 2021
the project "PostGIS".
via df88c3dba84355b44b85d852753bc8459f0a6ebc (commit)
from 3717fd9629d9a5331b377821eabafcf12a4522a1 (commit)
revisions in full, below.
commit df88c3dba84355b44b85d852753bc8459f0a6ebc
Author: Regina Obe <lr at pcorp.us>
Date: Mon Oct 25 12:29:31 2021 -0400
Change default for proj to be 7.2.1 (from 7.1.1) and GDAL from 3.2.3 to 3.3.2
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index 7b99c5749..cb9b5eb98 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -1,9 +1,9 @@
#!/usr/bin/env bash
set -e
if [[ "${OVERRIDE}" == '' ]] ; then
- export GEOS_VER=3.9.0
- export GDAL_VER=3.2.0
- export PROJ_VER=7.1.1
+ export GEOS_VER=3.10.0
+ export GDAL_VER=3.3.2
+ export PROJ_VER=7.2.1
export SFCGAL_VER=1.4.0
export CGAL_VER=5.3
export ICON_VER=1.16
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index b6fcd3856..a5487248f 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -16,9 +16,9 @@
#otherwise use the ones jenkins passes thru
#!/usr/bin/env bash
- export GEOS_VER=3.9.1
- export GDAL_VER=3.2.3
export CGAL_VER=5.3
@@ -27,6 +27,7 @@ if [[ "${OVERRIDE}" == '' ]] ; then
export PROTOBUFC_VER=1.2.1
export JSON_VER=0.12
export PROJSO=libproj-19.dll
+ export CURL_VER=7.73
fi;
export PROTOBUF_VER=3.2.0
@@ -40,6 +41,12 @@ fi;
echo "ICON_VER ${ICON_VER}"
+if [[ "${CURL_VER}" == '' ]] ; then
+fi;
+echo "CURL_VER ${CURL_VER}"
#set to something even if override is on but not set
if [[ "${ZLIB_VER}" == '' ]] ; then
export ZLIB_VER=1.2.11
@@ -61,6 +68,7 @@ echo "PROJ_VER $PROJ_VER"
echo "LIBXML_VER $LIBXML_VER"
echo "CGAL_VER $CGAL_VER"
export PROJECTS=/projects
export PATHOLD=$PATH
@@ -190,6 +198,7 @@ fi;
echo "PROTOBUF VERSION: ${PROTOBUF_VER} https://github.com/google/protobuf" >> $verfile
echo "PROTOBUF-C VERSION: ${PROTOBUFC_VER} https://github.com/protobuf-c/protobuf-c" >> $verfile
+echo "CURL VERSION: ${CURL_VER} https://github.com/protobuf-c/protobuf-c" >> $verfile
cp ${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/
#cp ${PGPATHEDB}/bin/libxml2-2.dll $outdir/bin/
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index e4f5d751a..a3fdb16e5 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -1,9 +1,9 @@
#!/usr/bin/env bash
set -e
+ export GDAL_VER=3.2.3
export CGAL_VER=5.3.0
export ICON_VER=1.15
Summary of changes:
ci/winnie/build_postgis.sh | 6 +++---
ci/winnie/package_postgis.sh | 15 ++++++++++++---
ci/winnie/regress_postgis.sh | 6 +++---
3 files changed, 18 insertions(+), 9 deletions(-)
hooks/post-receive
