[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0beta1-1-g3717fd962
Sat Oct 23 22:11:26 PDT 2021
the project "PostGIS".
       via  3717fd9629d9a5331b377821eabafcf12a4522a1 (commit)
      from  992819f6ac489a1c467a5c8855f07a376d225cc0 (commit)
revisions in full, below.
commit 3717fd9629d9a5331b377821eabafcf12a4522a1
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Oct 24 01:11:17 2021 -0400
    Flip back to dev and add beta1 upgrade target
diff --git a/NEWS b/NEWS
index 73e05a3c3..41340f184 100644
--- a/NEWS
+++ b/NEWS
@@ -1,30 +1,5 @@
-PostGIS 3.2.0beta1
-2021/10/23
-This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+
-Additional features are enabled if you are running GEOS 3.9+
-(and ST_MakeValid enhancements with 3.10+),
-Proj 6.1+, and PostgreSQL 14+.
-Changes since PostGIS 3.2.0alpa1 release:
-  * Bug Fixes and Breaking Changes *
-    - #5012, Clean regress against released GEOS 3.10.0
-      (Regina Obe, Paul Ramsey)
-    - #5000, Turn off Window support in ST_AsMVT aggregate
-        as no real use-case for it and it crashes with random input
-        (Paul Ramsey)
-    - #4994, shp2pgsql is sometimes missing the INSERT statements
-      (Sandro Santilli)
-    - #4990, getfacecontainingpoint fails on i386 (Sandro Santilli)
-    - #5008, Have ST_DWithin with EMPTY operand always return false
-      (Sandro Santilli)
-    - #5002, liblwgeom should build with warning flags by default
-      (Sandro Santilli)
-  * Enhancements *
-    - #4997, FlatGeobuf format input/output (Björn Harrtell)
+PostGIS 3.2.0rc1
+2021/xx/xx
 PostGIS 3.2.0
 2021/xx/xx
@@ -112,6 +87,35 @@ PostGIS 3.2.0
   - #4808, ST_ClusterKMeans now supports max_radius argument. Use it when you're not sure what is
     the number of clusters but you know what the size of clusters should be. (Darafei Praliaskouski)
+PostGIS 3.2.0beta1
+2021/10/23
+This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+
+Additional features are enabled if you are running GEOS 3.9+
+(and ST_MakeValid enhancements with 3.10+),
+Proj 6.1+, and PostgreSQL 14+.
+Changes since PostGIS 3.2.0alpa1 release:
+  * Bug Fixes and Breaking Changes *
+    - #5012, Clean regress against released GEOS 3.10.0
+      (Regina Obe, Paul Ramsey)
+    - #5000, Turn off Window support in ST_AsMVT aggregate
+        as no real use-case for it and it crashes with random input
+        (Paul Ramsey)
+    - #4994, shp2pgsql is sometimes missing the INSERT statements
+      (Sandro Santilli)
+    - #4990, getfacecontainingpoint fails on i386 (Sandro Santilli)
+    - #5008, Have ST_DWithin with EMPTY operand always return false
+      (Sandro Santilli)
+    - #5002, liblwgeom should build with warning flags by default
+      (Sandro Santilli)
+  * Enhancements *
+    - #4997, FlatGeobuf format input/output (Björn Harrtell)
 PostGIS 3.2.0alpha1
 2021/09/10
diff --git a/Version.config b/Version.config
index 4ffd6bd2d..843963a1e 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=2
-POSTGIS_MICRO_VERSION=0beta1
+POSTGIS_MICRO_VERSION=0dev
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index be0d1be90..3e700d193 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -68,4 +68,4 @@ UPGRADEABLE_VERSIONS = \
 	3.1.4 \
 	3.1.5dev \
 	3.2.0alpha1 \
-	3.2.0dev
+	3.2.0beta1
Summary of changes:
 NEWS                               | 58 ++++++++++++++++++++------------------
 Version.config                     |  2 +-
 extensions/upgradeable_versions.mk |  2 +-
 3 files changed, 33 insertions(+), 29 deletions(-)
hooks/post-receive
