[postgis-tickets] [PostGIS] #5014: flatgeobuf test failure
trac at osgeo.org
Sat Oct 30 21:40:08 PDT 2021
Reporter: Bas Couwenberg | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Bas Couwenberg):
> Is it possible for you to send a backtrace for this or if there is a way
for me to test this via some container thing.
You can setup a cowbuilder chroot to reproduce the issue, see:
https://debian-gis-team.pages.debian.net/policy/packaging.html#git-
pbuilder
After configuring `sudo` as documented:
sudo cowbuilder --create \
--distribution=sid \
--basepath=/var/cache/pbuilder/base-sid.cow
sudo cowbuilder --login --basepath /var/cache/pbuilder/base-sid.cow
# Inside the chroot
## Add apt sources
echo "deb http://deb.debian.org/debian/ experimental main contrib non-
free" >> /etc/apt/sources.list
echo "deb-src http://deb.debian.org/debian/ experimental main contrib non-
sed -i 's/^#deb-src/deb-src/' /etc/apt/sources.list
apt update
## Install tools you need (vim, less, gdb, etc)
## Get postgis source package
cd /tmp/buildd
apt source -t experimental postgis
cd postgis-*/
## Install build dependencies
apt build-dep postgis
## Delete patch which skips the failing test
apt install quilt
quilt delete flatgeobuff.patch
## Build the package
DEB_BUILD_OPTIONS="parallel=3" dpkg-buildpackage -uc -uc 2>&1 | tee
../postgis.build
> I see you are using pg_virtualenv but not sure what that is.
It creates a throw-away PostgreSQL environment for running regression
tests, see its manpage:
https://manpages.debian.org/unstable/postgresql-
common/pg_virtualenv.1.en.html
You can use its `-s` option to launch a shell when the command fails,
e.g.:
pg_virtualenv -v 14 -s make check RUNTESTFLAGS="-v"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5014#comment:3>
