[postgis-tickets] [PostGIS] #5014: flatgeobuf test failure
PostGIS trac at osgeo.org
Sat Oct 30 11:58:46 PDT 2021
  Reporter:  Bas Couwenberg  |      Owner:  pramsey
      Type:  defect          |     Status:  new
  Priority:  blocker         |  Milestone:  PostGIS 3.2.0
 Component:  postgis         |    Version:  master
Resolution:                  |   Keywords:
Comment (by robe):
 From the line number in ticket looks like this combination should crash it
 but I can't get it to crash on my PostgreSQL 14 PostGIS 3.2.0beta1 mingw64
 install and hasn't been crashing on regression testing of other bots
 running debian (debbie and our raspberry pis (berrie, berrie32).
 -- creates the table
 SELECT ST_TableFromFlatGeobuf('public', 'flatgeobuf_t1', (select
 ST_AsFlatGeobuf(q) fgb from (select null::geometry) q));
 select 'P5', id, ST_AsEWKT(geom) from
 ST_FromFlatGeobuf(null::flatgeobuf_t1, (
     select ST_AsFlatGeobuf(q, true) fgb from (select
 ST_SetSRID(ST_MakePoint(-71.1043443253471, 42.3150676015829),4326)) q));
 Is it possible for you to send a backtrace for this or if there is a way
 for me to test this via some container thing.  I see you are using
 pg_virtualenv  but not sure what that is.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5014#comment:2>
