[postgis-tickets] [PostGIS] #4994: shp2pgsql is sometimes missing the INSERT statements
PostGIS trac at osgeo.org
Wed Sep 15 13:11:48 PDT 2021
  Reporter:  myon           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 3.1.5
 Component:  loader/dumper  |    Version:  master
Resolution:                 |   Keywords:
Changes (by robe):
 * milestone:  PostGIS 3.2.0 => PostGIS 3.1.5
Comment:
 Myon noted he can trigger in 3.1.4 but not 3.1.3
 Note from IRC:
 Myon
 oookay, I can trigger the bug using shp2pgsql from 3.1.4+dfsg-1.pgdg+1 on
 unstable
 but not using 3.1.3+dfsg-1~exp1.pgdg+1+b1 on (a semi-up-to-date) bookworm
 So this could be a debian unstable issue though strk recalls being able to
 trigger these things -- but we know strk doesn't ever run bleeding edge
 OS.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4994#comment:2>
