[postgis-tickets] [PostGIS] #4994: shp2pgsql is sometimes missing the INSERT statements
trac at osgeo.org
Wed Sep 15 13:21:47 PDT 2021
Reporter: myon | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.5
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Changes (by myon):
* owner: robe => pramsey
* version: master => 2.5.x
* component: loader/dumper => postgis
Comment:
Thanks robe2 and strk on #postgis for their patience. More datapoints:
15 22:06 <Myon> oookay, I can trigger the bug using shp2pgsql from
3.1.4+dfsg-1.pgdg+1 on unstable
15 22:07 <Myon> but not using 3.1.3+dfsg-1~exp1.pgdg+1+b1 on (a semi-up-
to-date) bookworm
15 22:13 <Myon> 3.1.1+dfsg-1 on bullseye seems ok
15 22:14 <Myon> 3.1.4+dfsg-1.pgdg110+1 on bullseye seems ok
15 22:18 <Myon> 3.1.4+dfsg-1.pgdg+1 on bookworm seems ok
15 22:19 <Myon> 3.2.0~alpha1+dfsg-1~exp1 from experimental installed on
bookworm is also ok
15 22:19 <Myon> so it seems it might be an issue with the OS or some
library on unstable
15 22:19 <Myon> ... that hasn't trickled down to testing/bookworm yet
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4994#comment:3>
