[postgis-tickets] [PostGIS] #4990: getfacecontainingpoint fails on i386
trac at osgeo.org
Tue Sep 21 05:08:22 PDT 2021
Reporter: Bas Couwenberg | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.2.0
Component: topology | Version: master
Resolution: | Keywords:
Comment (by robe):
If it's a 32-bit issue, I'm surprised this didn't trigger a failure in
bessie32 (freebsd 12 32-bit
https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32/2879/consoleFull
running GEOS 3.9.1 and PostgreSQL 12) or berrie (which is a 32-bit rasbian
pi
https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie/2879/consoleFull
running 3.7.1-CAPI-1.11.1 and PostgreSQL 12 ) ci bots.
Which version of GEOS are you running? strk does this function rely on
GEOS. I didn't check. Just wanted to rule that out.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4990#comment:4>
