[postgis-tickets] [PostGIS] #4990: getfacecontainingpoint fails on i386
trac at osgeo.org
Tue Sep 21 05:15:48 PDT 2021
Reporter: Bas Couwenberg | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.2.0
Component: topology | Version: master
Resolution: | Keywords:
Comment (by robe):
Sorry I should have looked at the logs -- so this is a
Failing build
PostgreSQL 13.4 (Debian 13.4-3) on i686-pc-linux-gnu, compiled by gcc
(Debian 10.3.0-8) 10.3.0, 32-bit
Postgis 3.2.0alpha1 - (e357e0a) - 2021-09-11 05:49:54
scripts 3.2.0alpha1 e357e0a
raster scripts 3.2.0alpha1 e357e0a
GEOS: 3.9.1-CAPI-1.14.2
PROJ: 7.2.1
SFCGAL: 1.3.10
GDAL: GDAL 3.3.2, released 2021/09/01
berrie (success). I'm pretty sure the 3.2.0alpha1 was success too but
this is the latest run of 3.2 branch
15:58:38 PostgreSQL 12.6 on aarch64-unknown-linux-gnu, compiled by gcc
(Raspbian 8.3.0-6+rpi1) 8.3.0, 32-bit
15:58:38 Postgis 3.2.0dev - (d807a0f) - 2021-09-20 19:49:37
15:58:38 scripts 3.2.0dev d807a0f
15:58:38 raster scripts 3.2.0dev d807a0f
15:58:38 GEOS: 3.7.1-CAPI-1.11.1 27a5e771
15:58:38 PROJ: Rel. 5.2.0, September 15th, 2018
15:58:38 GDAL: GDAL 2.4.0, released 2018/12/14
bessie32 (success). Also pretty sure 3.2.0alpha1 passed and latest run is
passing
15:52:32 PostgreSQL 12.7 on i386-portbld-freebsd12.2, compiled by gcc10
(FreeBSD Ports Collection) 10.2.0, 32-bit
15:52:32 Postgis 3.2.0dev - (d807a0f) - 2021-09-17 21:07:45
15:52:32 scripts 3.2.0dev d807a0f
15:52:32 raster scripts 3.2.0dev d807a0f
15:52:32 GEOS: 3.9.1-CAPI-1.14.2
15:52:32 PROJ: 7.2.1
15:52:32 SFCGAL: 1.3.8
15:52:32 GDAL: GDAL 3.2.1, released 2020/12/29
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4990#comment:5>
