[postgis-tickets] [PostGIS] #4990: getfacecontainingpoint fails on i386
trac at osgeo.org
Thu Sep 23 23:22:13 PDT 2021
Reporter: Bas Couwenberg | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.2.0
Component: topology | Version: master
Resolution: | Keywords:
Comment (by strk):
That did it, thank you. I can reproduce now:
PostgreSQL 13.4 (Debian 13.4-3) on i686-pc-linux-gnu, compiled by gcc
(Debian 10.3.0-8) 10.3.0, 32-bit
Postgis 3.2.0dev - (0) - 2021-09-24 06:12:15
scripts 3.2.0dev 0
GEOS: 3.9.1-CAPI-1.14.2
PROJ: 7.2.1
Running tests
topology/test/regress/getfacecontainingpoint .. failed (diff expected
obtained: /tmp/pgis_reg/test_1_diff)
--- topology/test/regress/getfacecontainingpoint_expected 2021-09-24
06:02:21.148830927 +0000
+++ /tmp/pgis_reg/test_1_out 2021-09-24 06:21:41.275122456 +0000
@@ -21,21 +21,4 @@
ERROR: Two or more faces found
-t1|1
-t2|1
-t3|9
-t4|2
-t5|2
-t6|0
-t7|11
-t8|4
-t9|1
-t10|10
-t11|10
-t12|10
-t13|10
-t14|1
-t15|12
-t16|15
-t17|16
-t18|19
+ERROR: Closest point is first point of closest segment, unexpectedly
uninstall .. ok (4831)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4990#comment:19>
