[postgis-tickets] [PostGIS] #4990: getfacecontainingpoint fails on i386
PostGIS trac at osgeo.org
Fri Sep 24 09:57:57 PDT 2021
  Reporter:  Bas Couwenberg  |      Owner:  strk
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.2.0
 Component:  topology        |    Version:  master
Resolution:                  |   Keywords:
Comment (by strk):
 The failing test is t9, that is:
 select getfacecontainingpoint('city_data', 'POINT(7.1 31)');
 Here's the run with debugging on:
 DEBUG:  [lwgeom_topo.c:lwt_GetFaceContainingPoint:7097] Shortest line to
 closest edge 26: (null)
 DEBUG:  [lwgeom_topo.c:lwt_GetFaceContainingPoint:7103] Closest point on
 closest edge: POINT(7 31)
 DEBUG:  [lwgeom_topo.c:lwt_GetFaceContainingPoint:7209] Closest point is
 NOT a node
 DEBUG:  [lwgeom_topo.c:lwt_GetFaceContainingPoint:7236] Closest segment to
 edge 26 is 0
 DEBUG:  [lwgeom_topo.c:lwt_GetFaceContainingPoint:7239] Closest segment to
 edge 26 is LINESTRING(0 5.31406e-315, 5.32539e-315 5.31406e-315)
 ERROR:  Closest point is first point of closest segment, unexpectedly
 The "closest segment" is clearly bogus, and it's probably because of the
 unaligned memory.
 I'm on the right track to fix that, but keep thinking we could be nice and
 ALWAYS align the pointarray memory to the double boundary
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4990#comment:20>
