[postgis-tickets] [SCM] PostGIS branch main updated. 3.2.0alpha1-29-gee69242
git at osgeo.org
git at osgeo.org
Mon Sep 27 03:08:10 PDT 2021
the project "PostGIS".
The branch, main has been updated
via ee69242d6d68f421392d146ed483e26c92596f10 (commit)
from 94f6cdfc79162410251f837229d6291317e251e9 (commit)
revisions in full, below.
commit ee69242d6d68f421392d146ed483e26c92596f10
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Sep 27 09:30:14 2021 +0200
Refactor getFaceContainingPoint code
Reduce constructive LWGEOM calls and supports glitches in
closest_segment2d sometimes returning the next segment when
the query point is closest to the vertex connecting the segments.
Fixes #4990 (exception on 32bit)
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index bf8280e..b8216eb 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -7057,14 +7057,12 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
LWT_ISO_EDGE* closestEdge;
LWT_ISO_EDGE* edges;
uint64_t numedges, i;
- LWGEOM *shortestLine;
- const POINT2D *shortestLineP0, *shortestLineP1;
+ const POINT2D *queryPoint;
+ const POINT2D *closestPointOnEdge = NULL;
int closestSegmentIndex;
int closestSegmentSide;
+ int closestPointVertex = -1;
const POINT2D *closestSegmentP0, *closestSegmentP1;
- double shortestLineAzimuth;
- LWPOINT *closestPointOnEdge;
- LWPOINT *closestEdgeEndpoint;
LWT_ELEMID closestNode = 0;
double dist;
int containingFace = -1;
@@ -7089,39 +7087,64 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
return 0;
+ LWDEBUGGF(2, lwline_as_lwgeom(closestEdge->geom), "Closest edge %" LWTFMT_ELEMID, closestEdge->edge_id);
- /* Compute shortest line from query point to closest edge */
- shortestLine = lwgeom_closest_line(lwline_as_lwgeom(closestEdge->geom), lwpoint_as_lwgeom(pt));
- LWDEBUGGF(1, shortestLine, "Shortest line to closest edge %" LWTFMT_ELEMID, closestEdge->edge_id);
- /* Check if the closest point on the edge is an edge endpoint */
- closestPointOnEdge = lwline_get_lwpoint(lwgeom_as_lwline(shortestLine), 0);
- LWDEBUGG(1, lwpoint_as_lwgeom(closestPointOnEdge), "Closest point on closest edge");
+ /* Find closest segment of edge to the point */
+ queryPoint = getPoint2d_cp(pt->point, 0);
+ closestSegmentIndex = ptarray_closest_segment_2d(closestEdge->geom->points, queryPoint, &dist);
+ LWDEBUGF(1, "Closest segment on edge %" LWTFMT_ELEMID " is %d (dist %g)", closestEdge->edge_id, closestSegmentIndex, dist);
+ closestSegmentP0 = getPoint2d_cp(closestEdge->geom->points, closestSegmentIndex);
+ closestSegmentP1 = getPoint2d_cp(closestEdge->geom->points, closestSegmentIndex + 1);
+ LWDEBUGF(1, "Closest segment on edge %" LWTFMT_ELEMID " is LINESTRING(%g %g, %g %g)",
+ closestEdge->edge_id,
+ closestSegmentP0->x,
+ closestSegmentP0->y,
+ closestSegmentP1->x,
+ closestSegmentP1->y
- closestEdgeEndpoint = lwline_get_lwpoint(closestEdge->geom, 0);
- if ( lwpoint_same(closestEdgeEndpoint, closestPointOnEdge) ) {
- closestNode = closestEdge->start_node;
- } else if ( ! lwline_is_closed(closestEdge->geom) ) {
- lwpoint_free(closestEdgeEndpoint);
- closestEdgeEndpoint = lwline_get_lwpoint(closestEdge->geom, closestEdge->geom->points->npoints - 1);
+ * We use comp.graphics.algorithms Frequently Asked Questions method
+ * (1) AC dot AB
+ * r = ----------
+ * ||AB||^2
+ * r has the following meaning:
+ * r=0 P = A
+ * r=1 P = B
+ * r<0 P is on the backward extension of AB
+ * r>1 P is on the forward extension of AB
+ * 0<r<1 P is interior to AB
+ const POINT2D *p = queryPoint;
+ const POINT2D *A = closestSegmentP0;
+ const POINT2D *B = closestSegmentP1;
+ double r = ( (p->x-A->x) * (B->x-A->x) + (p->y-A->y) * (B->y-A->y) )/( (B->x-A->x)*(B->x-A->x) +(B->y-A->y)*(B->y-A->y) );
+ if ( r <= 0 )
+ closestPointOnEdge = A;
+ closestPointVertex = closestSegmentIndex;
+ if ( closestSegmentIndex == 0 )
+ closestNode = closestEdge->start_node;
+ else if (r >= 1 )
+ closestPointOnEdge = B;
+ closestPointVertex = closestSegmentIndex + 1;
+ if ( closestSegmentIndex + 2 == closestEdge->geom->points->npoints )
closestNode = closestEdge->end_node;
- lwpoint_free(closestPointOnEdge);
if ( closestNode != 0 )
LWDEBUGF(1, "Closest point is node %d", closestNode);
- dist = lwgeom_length(shortestLine);
if ( dist == 0 )
- lwgeom_free(shortestLine);
LWDEBUGF(1, "Query point is node %d", closestNode);
/* Query point is the node
@@ -7176,132 +7199,117 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
/* Closest point is a node, but query point is NOT on the node */
/* let's do azimuth computation */
- shortestLineP0 = getPoint2d_cp(((LWLINE *)shortestLine)->points, 0);
- shortestLineP1 = getPoint2d_cp(((LWLINE *)shortestLine)->points, 1);
- if ( ! azimuth_pt_pt(shortestLineP0, shortestLineP1, &shortestLineAzimuth) ) {
- lwerror("error computing azimuth of shortestLine [%.15g %.15g,%.15g %.15g]",
- shortestLineP0->x, shortestLineP0->y,
- shortestLineP1->x, shortestLineP1->y);
+ edgeend ee;
+ if ( ! azimuth_pt_pt(closestPointOnEdge, queryPoint, &ee.myaz) ) {
+ lwerror("error computing azimuth of query point [%.15g %.15g,%.15g %.15g]",
+ closestPointOnEdge->x, closestPointOnEdge->y,
+ queryPoint->x, queryPoint->y);
_lwt_release_edges(closestEdge, 1);
return -1;
- LWDEBUGF(1, "ShortestLine azimuth is %g", shortestLineAzimuth);
+ LWDEBUGF(1, "Query point azimuth is %g", ee.myaz);
- edgeend ee;
- ee.myaz = shortestLineAzimuth;
int found = _lwt_FindAdjacentEdges( topo, closestNode, &ee, NULL, -1 );
if ( ! found ) {
lwerror("Unexpected backend return: _lwt_FindAdjacentEdges(%d) found no edges when we previously found edge %d ending on that node",
closestNode, closestEdge->edge_id);
return -1;
return ee.cwFace;
- LWDEBUGF(1, "Closest point is NOT a node", closestNode);
+ LWDEBUG(1, "Closest point is NOT a node");
/* If this edge has the same face on the left and right sides
* we found the face containing our query point */
if ( closestEdge->face_left == closestEdge->face_right )
containingFace = closestEdge->face_left;
return containingFace;
if ( dist == 0 )
/* We checked the dangling case above */
lwerror("Two or more faces found");
return -1;
- /* find closest segment on closestEdge and use lw_segment_side
- * to determine on which side our query point falls */
- closestSegmentIndex = ptarray_closest_segment_2d(closestEdge->geom->points, shortestLineP1, NULL);
- LWDEBUGF(1, "Closest segment on edge %" LWTFMT_ELEMID " is %d", closestEdge->edge_id, closestSegmentIndex);
- closestSegmentP0 = getPoint2d_cp(closestEdge->geom->points, closestSegmentIndex);
- closestSegmentP1 = getPoint2d_cp(closestEdge->geom->points, closestSegmentIndex + 1);
- LWDEBUGF(1, "Closest segment on edge %" LWTFMT_ELEMID " is LINESTRING(%g %g, %g %g)",
- closestEdge->edge_id,
- closestSegmentP0->x,
- closestSegmentP0->y,
- closestSegmentP1->x,
- closestSegmentP1->y
/* Find on which side of the segment the query point lays */
- if ( p2d_same(shortestLineP0, closestSegmentP0) )
- /* Closest point is first point of closest segment (this should
- * never happen as we'd have returned the previous segment in
- * this case, unless it was the very first segment, and in that
- * case we'd have cought this earlier, as it would be a NODE
- * This would be more of an assert...
- lwerror("Closest point is first point of closest segment, unexpectedly");
- _lwt_release_edges(closestEdge, 1);
- return -1;
- else if ( p2d_same(shortestLineP0, closestSegmentP1) )
+ if ( closestPointVertex != -1 )
- /* Closest point is last point of the closest segment,
- * so we need to check if rotating the closest segment
- * clockwise around its last point we encounter
- * the shortestLine first (which means it's on the left
- * of the closest edge) or the next segment first (which
- * means the shortestLine is on the right)
+ /* Closest point is a vertex of the closest segment */
+ LWDEBUGF(1, "Closest point is vertex %d of closest segment", closestPointVertex);
+ * We need to check if rotating clockwise the line
+ * from previous vertex to closest vertex clockwise
+ * around the closest vertex encounters
+ * the line to query point first (which means it's on the left
+ * of the closest edge) or the line to next vertex first (which
+ * means the query point is on the right)
- const POINT2D *nextSegmentP0, *nextSegmentP1;
- double azS0, azS1, azSL;
- nextSegmentP0 = closestSegmentP1;
- /* This would be more of an assert...*/
- if ( closestSegmentIndex + 1 > (int)closestEdge->geom->points->npoints )
- lwerror("closestSegmentIndex is unexpectedly the last one and we didn't exit earlier as it would be a node");
- return -1;
- nextSegmentP1 = getPoint2d_cp(closestEdge->geom->points, closestSegmentIndex + 2);
+ int prevVertexIndex = closestPointVertex > 0 ?
+ closestPointVertex - 1 :
+ closestEdge->geom->points->npoints - 2; /* last vertex would be == first vertex, this being a closed edge */
+ const POINT2D *prevVertex = getPoint2d_cp(
+ closestEdge->geom->points,
+ prevVertexIndex
+ LWDEBUGF(1, "Previous vertex %d is POINT(%.15g %.15g)",
+ prevVertexIndex,
+ prevVertex->x,
+ prevVertex->y
+ int nextVertexIndex = closestPointVertex == closestEdge->geom->points->npoints - 1 ?
+ 1 : /* first point would be == last point, this being a closed edge */
+ closestPointVertex + 1;
+ const POINT2D *nextVertex = getPoint2d_cp(
+ nextVertexIndex
+ LWDEBUGF(1, "Next vertex %d is POINT(%.15g %.15g)",
+ nextVertexIndex,
+ nextVertex->x,
+ nextVertex->y
+ double azS0; /* azimuth from previous vertex to closestPointVertex */
+ double azS1; /* azimuth from closestPointVertex to next vertex */
+ double azSL; /* azimuth from closestPointVertex to query point */
- if ( ! azimuth_pt_pt(closestSegmentP1, closestSegmentP0, &azS0)) {
- lwerror("error computing azimuth of reverse closest segment [%.15g %.15g,%.15g %.15g]",
- closestSegmentP1->x, closestSegmentP1->y,
- closestSegmentP0->x, closestSegmentP0->y);
+ if ( ! azimuth_pt_pt(closestPointOnEdge, prevVertex, &azS0)) {
+ lwerror("error computing azimuth of segment to closest point [%.15g %.15g,%.15g %.15g]",
+ prevVertex->x, prevVertex->y);
return -1;
- if ( ! azimuth_pt_pt(nextSegmentP0, nextSegmentP1, &azS1)) {
- lwerror("error computing azimuth of next segment [%.15g %.15g,%.15g %.15g]",
- nextSegmentP0->x, nextSegmentP0->y,
- nextSegmentP1->x, nextSegmentP1->y);
+ if ( ! azimuth_pt_pt(closestPointOnEdge, nextVertex, &azS1)) {
+ lwerror("error computing azimuth of segment from closest point [%.15g %.15g,%.15g %.15g]",
+ nextVertex->x, nextVertex->y);
return -1;
- if ( ! azimuth_pt_pt(shortestLineP0, shortestLineP1, &azSL) ) {
+ if ( ! azimuth_pt_pt(closestPointOnEdge, queryPoint, &azSL) ) {
+ lwerror("error computing azimuth of queryPoint [%.15g %.15g,%.15g %.15g]",
return -1;
@@ -7312,19 +7320,19 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
double angle_S0_SL = azSL - azS0;
if ( angle_S0_SL < 0 ) angle_S0_SL += 2 * M_PI;
- LWDEBUGF(1, "Azimuths from last point of closest segment: S0:%g, S1:%g (+%g), SL:%g (+%g)",
+ LWDEBUGF(1, "Azimuths from closest (vertex) point: P:%g, N:%g (+%g), Q:%g (+%g)",
azS0,
azS1, angle_S0_S1,
azSL, angle_S0_SL
if ( angle_S0_SL < angle_S0_S1 )
- /* shortest line was encountered first, is on the left */
+ /* line to query point was encountered first, is on the left */
else
- /* shortest line NOT encountered first, is on the right */
+ /* line to query point was NOT encountered first, is on the right */
containingFace = closestEdge->face_right;
@@ -7333,16 +7341,16 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
/* Closest point is internal to closest segment, we can use
* lw_segment_side */
- LWDEBUGF(1, "Calling lw_segment_side((%g,%g),(%g,%g),(%g,%g)",
+ LWDEBUGF(1, "Closest point is internal to closest segment, calling lw_segment_side((%g,%g),(%g,%g),(%g,%g)",
- shortestLineP1->y
+ queryPoint->x,
+ queryPoint->y
- closestSegmentSide = lw_segment_side(closestSegmentP0, closestSegmentP1, shortestLineP1);
+ closestSegmentSide = lw_segment_side(closestSegmentP0, closestSegmentP1, queryPoint);
LWDEBUGF(1, "Side of closest segment query point falls on: %d", closestSegmentSide);
if ( closestSegmentSide == -1 ) /* left */
@@ -7357,13 +7365,11 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
lwerror("Unexpected collinearity reported from lw_segment_side");
return -1;
Summary of changes:
liblwgeom/lwgeom_topo.c | 236 +++++++++++++++++++++++++-----------------------
1 file changed, 121 insertions(+), 115 deletions(-)
hooks/post-receive
