[postgis-tickets] [SCM] PostGIS branch main updated. 3.2.0alpha1-30-g38b77f3
git at osgeo.org
git at osgeo.org
Mon Sep 27 03:16:23 PDT 2021
the project "PostGIS".
The branch, main has been updated
via 38b77f3a01788c1e0755fd49bc45ee4ace8c1cef (commit)
from ee69242d6d68f421392d146ed483e26c92596f10 (commit)
revisions in full, below.
commit 38b77f3a01788c1e0755fd49bc45ee4ace8c1cef
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Sep 27 11:37:12 2021 +0200
Tolerate 1e-5 units drift in closest_point_on_segment test
Or it will fail on 32bit systems
diff --git a/liblwgeom/cunit/cu_ptarray.c b/liblwgeom/cunit/cu_ptarray.c
index 60c23c7..d462f51 100644
--- a/liblwgeom/cunit/cu_ptarray.c
+++ b/liblwgeom/cunit/cu_ptarray.c
@@ -818,14 +818,14 @@ static void test_ptarray_closest_point_on_segment(void)
closest_point_on_segment(&qp, &s0, &s1, &cp);
ASSERT_DOUBLE_EQUAL(cp.x, 0);
ASSERT_DOUBLE_EQUAL(cp.y, 8);
- ASSERT_DOUBLE_EQUAL(cp.z, 2);
+ ASSERT_DOUBLE_EQUAL_TOLERANCE(cp.z, 2, 1e-5);
ASSERT_DOUBLE_EQUAL(cp.m, 12);
qp.x = -0.1; qp.y = 8;
diff --git a/liblwgeom/cunit/cu_tester.h b/liblwgeom/cunit/cu_tester.h
index ebc1681..b876c2b 100644
--- a/liblwgeom/cunit/cu_tester.h
+++ b/liblwgeom/cunit/cu_tester.h
@@ -35,6 +35,12 @@ typedef void (*PG_SuiteSetup)(void);
CU_ASSERT_EQUAL(o,(double)e); \
} while (0);
+#define ASSERT_DOUBLE_EQUAL_TOLERANCE(o,e,t) do { \
+ if ( o != e ) \
+ fprintf(stderr, "[%s:%d]\n Expected: %g\n Obtained: %g\n Difference: %.15g\n Tolerated: %.15g\n", __FILE__, __LINE__, (double)(e), (o), fabs((o)-(e)), (t)); \
+ CU_ASSERT_DOUBLE_EQUAL(o,e,t); \
+} while (0);
#define ASSERT_INT_EQUAL(o,e) do { \
if ( o != e ) \
fprintf(stderr, "[%s:%d]\n Expected: %d\n Obtained: %d\n", __FILE__, __LINE__, (e), (o)); \
Summary of changes:
liblwgeom/cunit/cu_ptarray.c | 4 ++--
liblwgeom/cunit/cu_tester.h | 6 ++++++
2 files changed, 8 insertions(+), 2 deletions(-)
hooks/post-receive
