[postgis-tickets] [SCM] PostGIS branch main updated. 3.2.0alpha1-44-gce97128
Wed Sep 29 13:51:29 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  ce971289084fb1c1437c43bf5da97d42debc84e1 (commit)
      from  e932634f1be90a17a66caec4a17177b04df9f080 (commit)
revisions in full, below.
commit ce971289084fb1c1437c43bf5da97d42debc84e1
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Sep 29 22:49:41 2021 +0200
    Fix ASSERT_DOUBLE_EQUAL_TOLERANCE
diff --git a/liblwgeom/cunit/cu_tester.h b/liblwgeom/cunit/cu_tester.h
index b876c2b..24a0354 100644
--- a/liblwgeom/cunit/cu_tester.h
+++ b/liblwgeom/cunit/cu_tester.h
@@ -36,7 +36,7 @@ typedef void (*PG_SuiteSetup)(void);
 } while (0);
 #define ASSERT_DOUBLE_EQUAL_TOLERANCE(o,e,t) do { \
-  if ( o != e ) \
+  if ( fabs(o-e) > t ) \
     fprintf(stderr, "[%s:%d]\n Expected: %g\n Obtained: %g\n Difference: %.15g\n Tolerated: %.15g\n", __FILE__, __LINE__, (double)(e), (o), fabs((o)-(e)), (t)); \
   CU_ASSERT_DOUBLE_EQUAL(o,e,t); \
 } while (0);
Summary of changes:
 liblwgeom/cunit/cu_tester.h | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
