[postgis-tickets] [PostGIS] #5005: ST_FlatGeoBuf crashes with derived table
trac at osgeo.org
Wed Sep 29 13:07:46 PDT 2021
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Resolution: | Keywords:
Description changed by robe:
Old description:
> CREATE TABLE test AS
> SELECT x, y, ST_Point(x,y,4326)::geometry(POINT,4326) AS geom
> FROM generate_series(1,10,1) AS x,
> generate_series(10,1, -1) AS y;
> -- works
> SELECT ST_ASMVT(t)
> FROM (SELECT x, geom FROM test) AS t;
> -- crashes
> SELECT ST_ASFlatGeobuf(t)
> bt looks like
> [Thread 1952.0x71f8 exited with code 0]
> Thread 1 received signal SIGSEGV, Segmentation fault.
> [Switching to Thread 1952.0x4b50]
> pg_detoast_datum_copy (datum=0x1) at fmgr.c:1733
> 1733 if (VARATT_IS_EXTENDED(datum))
> (gdb) bt
> #0 pg_detoast_datum_copy (datum=0x1) at fmgr.c:1733
> #1 0x00000000711c7568 in flatgeobuf_agg_transfn
> (ctx=ctx at entry=0x5341e00)
> at flatgeobuf.c:527
> #2 0x00000000711c7ed2 in pgis_asflatgeobuf_transfn (fcinfo=0x84d66c0)
> at lwgeom_out_flatgeobuf.c:74
> #3 0x0000000000607869 in ExecAggPlainTransByVal (setno=<optimized out>,
> aggcontext=<optimized out>, pergroup=0x5341bb8, pertrans=<optimized
> out>,
> aggstate=<optimized out>) at execExprInterp.c:4315
> #4 ExecInterpExpr (state=0x84d6470, econtext=0x5340468,
> isnull=<optimized out>) at execExprInterp.c:1713
> #5 0x0000000000623193 in ExecEvalExprSwitchContext (isNull=0x520f0af,
> econtext=<optimized out>, state=<optimized out>)
> at ../../../src/include/executor/executor.h:339
> #6 advance_aggregates (aggstate=0x5340030, aggstate=0x5340030)
> at nodeAgg.c:842
> #7 agg_retrieve_direct (aggstate=0x5340030) at nodeAgg.c:2454
> #8 ExecAgg (pstate=<optimized out>) at nodeAgg.c:2179
> #9 0x000000000060c88a in ExecProcNode (node=0x5340030)
> at ../../../src/include/executor/executor.h:257
> #10 ExecutePlan (execute_once=<optimized out>, dest=0x842f930,
> direction=<optimized out>, numberTuples=0, sendTuples=<optimized
> out>,
> operation=CMD_SELECT, use_parallel_mode=<optimized out>,
> planstate=0x5340030, estate=0x533fdf0) at execMain.c:1551
> #11 standard_ExecutorRun (queryDesc=0x8438f70, direction=<optimized out>,
> count=0, execute_once=<optimized out>) at execMain.c:361
> #12 0x00000000007c06eb in PortalRunSelect (portal=portal at entry=0x52dd0e0,
> forward=forward at entry=true, count=0, count at entry=2147483647,
> dest=dest at entry=0x842f930) at pquery.c:919
> #13 0x00000000007c244c in PortalRun (portal=portal at entry=0x52dd0e0,
> count=count at entry=2147483647, isTopLevel=isTopLevel at entry=true,
> run_once=run_once at entry=true, dest=dest at entry=0x842f930,
> altdest=altdest at entry=0x842f930, qc=qc at entry=0x520f360) at
> pquery.c:763
> #14 0x00000000007baacb in exec_simple_query (
> query_string=0x5314d30 "SELECT ST_ASFlatGeobuf(t)\nFROM (SELECT x,
> geom FROM test) AS t;") at postgres.c:1214
> #15 0x00000000007be40c in PostgresMain (argc=argc at entry=1,
> argv=argv at entry=0x520f980, dbname=<optimized out>,
> username=0x1f8e90 "postgres") at postgres.c:4486
> #16 0x00000000007202a1 in BackendRun (port=0x520f7b0, port=0x520f7b0)
> at postmaster.c:4506
> #17 SubPostmasterMain (argc=argc at entry=3, argv=argv at entry=0x1f6d80)
> at postmaster.c:5019
> #18 0x0000000000964b53 in main (argc=3, argv=0x1f6d80) at main.c:186
> This is running with
> PostgreSQL 14rc1 on x86_64-w64-mingw32, compiled by gcc.exe (x86_64
> -posix-seh-rev0, Built by MinGW-W64 project) 8.1.0, 64-bit
> POSTGIS="3.2.0dev 3.2.0alpha1-19-gf48c4a86a" [EXTENSION] PGSQL="140"
> GEOS="3.10.0dev-CAPI-1.15.0" SFCGAL="1.3.10" PROJ="7.1.1" GDAL="GDAL
> 3.2.3, released 2021/04/27" LIBXML="2.9.9" LIBJSON="0.12"
> LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER
New description:
-- works
SELECT ST_ASMVT(t)
-- crashes
--this also crashes so not just derived
SELECT ST_ASFlatGeobuf(test)
FROM test;
bt looks like
(gdb) bt
#1 0x00000000711c7568 in flatgeobuf_agg_transfn (ctx=ctx at entry=0x5341e00)
at flatgeobuf.c:527
out>,
at nodeAgg.c:842
direction=<optimized out>, numberTuples=0, sendTuples=<optimized out>,
pquery.c:763
PostgreSQL 14rc1 on x86_64-w64-mingw32, compiled by gcc.exe (x86_64-posix-
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5005#comment:1>
