[postgis-tickets] [PostGIS] #5053: Doing update-po (I think update-pot does the same), updates the files when it shouldn't
    trac at osgeo.org
    Mon Jan 17 07:01:25 PST 2022
it shouldn't
  Reporter:  robe           |      Owner:  strk
      Type:  defect         |     Status:  assigned
  Priority:  medium         |  Milestone:  PostGIS 3.3.0
 Component:  documentation  |    Version:  master
Resolution:                 |   Keywords:
Comment (by strk):
 Can you paste a diff ? The only change I get when running `make -C doc/
 update-po` is the following:
 diff --git a/doc/po/ja/reporting.xml.po b/doc/po/ja/reporting.xml.po
 index 3ac5b01ee..ba511158b 100644
 --- a/doc/po/ja/reporting.xml.po
 +++ b/doc/po/ja/reporting.xml.po
 @@ -4,8 +4,8 @@
  msgid ""
  msgstr ""
  "Project-Id-Version: PostGIS\n"
 -"Report-Msgid-Bugs-To: http://bugs.kde.org\n"
 -"POT-Creation-Date: 2022-01-15 20:24+0000\n"
 +"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 +"POT-Creation-Date: 2022-01-13 20:20+0000\n"
  "PO-Revision-Date: 2022-01-16 20:45+0000\n"
  "Last-Translator: Regina Obe <regina at arrival3d.com>\n"
  "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 @@ -134,8 +134,9 @@ msgid ""
  "a four step process on Unix (assuming you already have <ulink
 url=\"https://"
  "git-scm.com/\">git</ulink> installed):"
  msgstr ""
 -"変更が大きい場合は、パッチが確実に好まれます。Unix上で次の4ステップの処
 理を行います (既に<ulink url=\"https://git-scm."
 -"com/\">git</ulink>をインストールしていると仮定します)。"
 +"変更が大きい場合は、パッチが確実に好まれます。Unix上で次の4ステップの処
 理を行"
 +"います (既に<ulink url=\"https://git-scm.com/\">git</ulink>をインストー
 ルして"
 +"いると仮定します)。"
  #. Tag: para
  #: reporting.xml:54
 That is: my system uses `https` instead of `http` for the `Report-Msgid-
 Bugs-To` header and uses linewraps with less columns
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5053#comment:1>
