[postgis-tickets] [PostGIS] #5053: Doing update-po (I think update-pot does the same), updates the files when it shouldn't
PostGIS trac at osgeo.org
Mon Jan 17 09:14:38 PST 2022
it shouldn't
  Reporter:  robe           |      Owner:  strk
      Type:  defect         |     Status:  assigned
  Priority:  medium         |  Milestone:  PostGIS 3.3.0
 Component:  documentation  |    Version:  master
Resolution:                 |   Keywords:
Comment (by robe):
 strk the output says all unchanged, but then all the .pot and many of the
 .po  when I do
 git status
 show all they've been modified and spot check of one shows the only
 difference is the creation date it want's to stamp today's date.  Is there
 a setting to prevent this
 "Report-Msgid-Bugs-To: http://bugs.kde.org\n"
 "POT-Creation-Date: 2022-01-15 21:04+0000\n"
         modified:   doc/po/de/administration.xml.po
         modified:   doc/po/de/database_tuning.xml.po
         modified:   doc/po/de/extras.xml.po
         modified:   doc/po/de/extras_address_standardizer.xml.po
         modified:   doc/po/de/extras_historytable.xml.po
         modified:   doc/po/de/extras_tigergeocoder.xml.po
         modified:   doc/po/de/extras_topology.xml.po
         modified:   doc/po/de/faq.xml.po
         modified:   doc/po/de/faq_raster.xml.po
         modified:   doc/po/de/installation.xml.po
         modified:   doc/po/de/introduction.xml.po
         modified:   doc/po/de/performance_tips.xml.po
         modified:   doc/po/de/postgis.xml.po
         modified:   doc/po/de/reference.xml.po
         modified:   doc/po/de/reference_accessor.xml.po
         modified:   doc/po/de/reference_bbox.xml.po
         modified:   doc/po/de/reference_cluster.xml.po
         modified:   doc/po/de/reference_constructor.xml.po
         modified:   doc/po/de/reference_editor.xml.po
         modified:   doc/po/de/reference_exception.xml.po
         modified:   doc/po/de/reference_guc.xml.po
         modified:   doc/po/de/reference_input.xml.po
         modified:   doc/po/de/reference_lrs.xml.po
         modified:   doc/po/de/reference_management.xml.po
         modified:   doc/po/de/reference_measure.xml.po
         modified:   doc/po/de/reference_operator.xml.po
         modified:   doc/po/de/reference_output.xml.po
         modified:   doc/po/de/reference_overlay.xml.po
         modified:   doc/po/de/reference_processing.xml.po
         modified:   doc/po/de/reference_raster.xml.po
         modified:   doc/po/de/reference_relationship.xml.po
         modified:   doc/po/de/reference_sfcgal.xml.po
         modified:   doc/po/de/reference_srs.xml.po
         modified:   doc/po/de/reference_trajectory.xml.po
         modified:   doc/po/de/reference_transaction.xml.po
         modified:   doc/po/de/reference_transformation.xml.po
         modified:   doc/po/de/reference_troubleshooting.xml.po
         modified:   doc/po/de/reference_type.xml.po
         modified:   doc/po/de/reference_validation.xml.po
         modified:   doc/po/de/reference_version.xml.po
         modified:   doc/po/de/release_notes.xml.po
         modified:   doc/po/de/reporting.xml.po
         modified:   doc/po/de/using_postgis_app.xml.po
         modified:   doc/po/de/using_postgis_dataman.xml.po
         modified:   doc/po/de/using_postgis_query.xml.po
         modified:   doc/po/de/using_raster_dataman.xml.po
         modified:   doc/po/es/administration.xml.po
         modified:   doc/po/es/database_tuning.xml.po
         modified:   doc/po/es/extras.xml.po
         modified:   doc/po/es/extras_address_standardizer.xml.po
         modified:   doc/po/es/extras_historytable.xml.po
         modified:   doc/po/es/extras_tigergeocoder.xml.po
         modified:   doc/po/es/extras_topology.xml.po
         modified:   doc/po/es/faq.xml.po
         modified:   doc/po/es/faq_raster.xml.po
         modified:   doc/po/es/installation.xml.po
         modified:   doc/po/es/introduction.xml.po
         modified:   doc/po/es/performance_tips.xml.po
         modified:   doc/po/es/postgis.xml.po
         modified:   doc/po/es/reference.xml.po
         modified:   doc/po/es/reference_accessor.xml.po
         modified:   doc/po/es/reference_bbox.xml.po
         modified:   doc/po/es/reference_cluster.xml.po
         modified:   doc/po/es/reference_constructor.xml.po
         modified:   doc/po/es/reference_editor.xml.po
         modified:   doc/po/es/reference_exception.xml.po
         modified:   doc/po/es/reference_guc.xml.po
         modified:   doc/po/es/reference_input.xml.po
         modified:   doc/po/es/reference_lrs.xml.po
         modified:   doc/po/es/reference_management.xml.po
         modified:   doc/po/es/reference_measure.xml.po
         modified:   doc/po/es/reference_operator.xml.po
         modified:   doc/po/es/reference_output.xml.po
         modified:   doc/po/es/reference_overlay.xml.po
         modified:   doc/po/es/reference_processing.xml.po
         modified:   doc/po/es/reference_raster.xml.po
         modified:   doc/po/es/reference_relationship.xml.po
         modified:   doc/po/es/reference_sfcgal.xml.po
         modified:   doc/po/es/reference_srs.xml.po
         modified:   doc/po/es/reference_trajectory.xml.po
         modified:   doc/po/es/reference_transaction.xml.po
         modified:   doc/po/es/reference_transformation.xml.po
         modified:   doc/po/es/reference_troubleshooting.xml.po
         modified:   doc/po/es/reference_type.xml.po
         modified:   doc/po/es/reference_validation.xml.po
         modified:   doc/po/es/reference_version.xml.po
         modified:   doc/po/es/release_notes.xml.po
         modified:   doc/po/es/reporting.xml.po
         modified:   doc/po/es/using_postgis_app.xml.po
         modified:   doc/po/es/using_postgis_dataman.xml.po
         modified:   doc/po/es/using_postgis_query.xml.po
         modified:   doc/po/es/using_raster_dataman.xml.po
         modified:   doc/po/fr/administration.xml.po
         modified:   doc/po/fr/database_tuning.xml.po
         modified:   doc/po/fr/extras.xml.po
         modified:   doc/po/fr/extras_address_standardizer.xml.po
         modified:   doc/po/fr/extras_historytable.xml.po
         modified:   doc/po/fr/extras_tigergeocoder.xml.po
         modified:   doc/po/fr/extras_topology.xml.po
         modified:   doc/po/fr/faq.xml.po
         modified:   doc/po/fr/faq_raster.xml.po
         modified:   doc/po/fr/installation.xml.po
         modified:   doc/po/fr/introduction.xml.po
         modified:   doc/po/fr/performance_tips.xml.po
         modified:   doc/po/fr/postgis.xml.po
         modified:   doc/po/fr/reference.xml.po
         modified:   doc/po/fr/reference_accessor.xml.po
         modified:   doc/po/fr/reference_bbox.xml.po
         modified:   doc/po/fr/reference_cluster.xml.po
         modified:   doc/po/fr/reference_constructor.xml.po
         modified:   doc/po/fr/reference_editor.xml.po
         modified:   doc/po/fr/reference_exception.xml.po
         modified:   doc/po/fr/reference_guc.xml.po
         modified:   doc/po/fr/reference_input.xml.po
         modified:   doc/po/fr/reference_lrs.xml.po
         modified:   doc/po/fr/reference_management.xml.po
         modified:   doc/po/fr/reference_measure.xml.po
         modified:   doc/po/fr/reference_operator.xml.po
         modified:   doc/po/fr/reference_output.xml.po
         modified:   doc/po/fr/reference_overlay.xml.po
         modified:   doc/po/fr/reference_processing.xml.po
         modified:   doc/po/fr/reference_raster.xml.po
         modified:   doc/po/fr/reference_relationship.xml.po
         modified:   doc/po/fr/reference_sfcgal.xml.po
         modified:   doc/po/fr/reference_srs.xml.po
         modified:   doc/po/fr/reference_trajectory.xml.po
         modified:   doc/po/fr/reference_transaction.xml.po
         modified:   doc/po/fr/reference_transformation.xml.po
         modified:   doc/po/fr/reference_troubleshooting.xml.po
         modified:   doc/po/fr/reference_type.xml.po
         modified:   doc/po/fr/reference_validation.xml.po
         modified:   doc/po/fr/reference_version.xml.po
         modified:   doc/po/fr/release_notes.xml.po
         modified:   doc/po/fr/reporting.xml.po
         modified:   doc/po/fr/using_postgis_app.xml.po
         modified:   doc/po/fr/using_postgis_dataman.xml.po
         modified:   doc/po/fr/using_postgis_query.xml.po
         modified:   doc/po/fr/using_raster_dataman.xml.po
         modified:   doc/po/it_IT/administration.xml.po
         modified:   doc/po/it_IT/database_tuning.xml.po
         modified:   doc/po/it_IT/extras.xml.po
         modified:   doc/po/it_IT/extras_address_standardizer.xml.po
         modified:   doc/po/it_IT/extras_historytable.xml.po
         modified:   doc/po/it_IT/extras_tigergeocoder.xml.po
         modified:   doc/po/it_IT/extras_topology.xml.po
         modified:   doc/po/it_IT/faq.xml.po
         modified:   doc/po/it_IT/faq_raster.xml.po
         modified:   doc/po/it_IT/installation.xml.po
         modified:   doc/po/it_IT/introduction.xml.po
         modified:   doc/po/it_IT/performance_tips.xml.po
         modified:   doc/po/it_IT/postgis.xml.po
         modified:   doc/po/it_IT/reference.xml.po
         modified:   doc/po/it_IT/reference_accessor.xml.po
         modified:   doc/po/it_IT/reference_bbox.xml.po
         modified:   doc/po/it_IT/reference_cluster.xml.po
         modified:   doc/po/it_IT/reference_constructor.xml.po
         modified:   doc/po/it_IT/reference_editor.xml.po
         modified:   doc/po/it_IT/reference_exception.xml.po
         modified:   doc/po/it_IT/reference_guc.xml.po
         modified:   doc/po/it_IT/reference_input.xml.po
         modified:   doc/po/it_IT/reference_lrs.xml.po
         modified:   doc/po/it_IT/reference_management.xml.po
         modified:   doc/po/it_IT/reference_measure.xml.po
         modified:   doc/po/it_IT/reference_operator.xml.po
         modified:   doc/po/it_IT/reference_output.xml.po
         modified:   doc/po/it_IT/reference_overlay.xml.po
         modified:   doc/po/it_IT/reference_processing.xml.po
         modified:   doc/po/it_IT/reference_raster.xml.po
         modified:   doc/po/it_IT/reference_relationship.xml.po
         modified:   doc/po/it_IT/reference_sfcgal.xml.po
         modified:   doc/po/it_IT/reference_srs.xml.po
         modified:   doc/po/it_IT/reference_trajectory.xml.po
         modified:   doc/po/it_IT/reference_transaction.xml.po
         modified:   doc/po/it_IT/reference_transformation.xml.po
         modified:   doc/po/it_IT/reference_troubleshooting.xml.po
         modified:   doc/po/it_IT/reference_type.xml.po
         modified:   doc/po/it_IT/reference_validation.xml.po
         modified:   doc/po/it_IT/reference_version.xml.po
         modified:   doc/po/it_IT/release_notes.xml.po
         modified:   doc/po/it_IT/reporting.xml.po
         modified:   doc/po/it_IT/using_postgis_app.xml.po
         modified:   doc/po/it_IT/using_postgis_dataman.xml.po
         modified:   doc/po/it_IT/using_postgis_query.xml.po
         modified:   doc/po/it_IT/using_raster_dataman.xml.po
         modified:   doc/po/ja/administration.xml.po
         modified:   doc/po/ja/database_tuning.xml.po
         modified:   doc/po/ja/extras.xml.po
         modified:   doc/po/ja/extras_address_standardizer.xml.po
         modified:   doc/po/ja/extras_historytable.xml.po
         modified:   doc/po/ja/extras_tigergeocoder.xml.po
         modified:   doc/po/ja/extras_topology.xml.po
         modified:   doc/po/ja/faq.xml.po
         modified:   doc/po/ja/faq_raster.xml.po
         modified:   doc/po/ja/installation.xml.po
         modified:   doc/po/ja/introduction.xml.po
         modified:   doc/po/ja/performance_tips.xml.po
         modified:   doc/po/ja/postgis.xml.po
         modified:   doc/po/ja/reference.xml.po
         modified:   doc/po/ja/reference_accessor.xml.po
         modified:   doc/po/ja/reference_bbox.xml.po
         modified:   doc/po/ja/reference_cluster.xml.po
         modified:   doc/po/ja/reference_constructor.xml.po
         modified:   doc/po/ja/reference_editor.xml.po
         modified:   doc/po/ja/reference_exception.xml.po
         modified:   doc/po/ja/reference_guc.xml.po
         modified:   doc/po/ja/reference_input.xml.po
         modified:   doc/po/ja/reference_lrs.xml.po
         modified:   doc/po/ja/reference_management.xml.po
         modified:   doc/po/ja/reference_measure.xml.po
         modified:   doc/po/ja/reference_operator.xml.po
         modified:   doc/po/ja/reference_output.xml.po
         modified:   doc/po/ja/reference_overlay.xml.po
         modified:   doc/po/ja/reference_processing.xml.po
         modified:   doc/po/ja/reference_raster.xml.po
         modified:   doc/po/ja/reference_relationship.xml.po
         modified:   doc/po/ja/reference_sfcgal.xml.po
         modified:   doc/po/ja/reference_srs.xml.po
         modified:   doc/po/ja/reference_trajectory.xml.po
         modified:   doc/po/ja/reference_transaction.xml.po
         modified:   doc/po/ja/reference_transformation.xml.po
         modified:   doc/po/ja/reference_troubleshooting.xml.po
         modified:   doc/po/ja/reference_type.xml.po
         modified:   doc/po/ja/reference_validation.xml.po
         modified:   doc/po/ja/reference_version.xml.po
         modified:   doc/po/ja/release_notes.xml.po
         modified:   doc/po/ja/using_postgis_app.xml.po
         modified:   doc/po/ja/using_postgis_dataman.xml.po
         modified:   doc/po/ja/using_postgis_query.xml.po
         modified:   doc/po/ja/using_raster_dataman.xml.po
         modified:   doc/po/ko_KR/administration.xml.po
         modified:   doc/po/ko_KR/database_tuning.xml.po
         modified:   doc/po/ko_KR/extras.xml.po
         modified:   doc/po/ko_KR/extras_address_standardizer.xml.po
         modified:   doc/po/ko_KR/extras_historytable.xml.po
         modified:   doc/po/ko_KR/extras_tigergeocoder.xml.po
         modified:   doc/po/ko_KR/extras_topology.xml.po
         modified:   doc/po/ko_KR/faq.xml.po
         modified:   doc/po/ko_KR/faq_raster.xml.po
         modified:   doc/po/ko_KR/installation.xml.po
         modified:   doc/po/ko_KR/introduction.xml.po
         modified:   doc/po/ko_KR/performance_tips.xml.po
         modified:   doc/po/ko_KR/postgis.xml.po
         modified:   doc/po/ko_KR/reference.xml.po
         modified:   doc/po/ko_KR/reference_accessor.xml.po
         modified:   doc/po/ko_KR/reference_bbox.xml.po
         modified:   doc/po/ko_KR/reference_cluster.xml.po
         modified:   doc/po/ko_KR/reference_constructor.xml.po
         modified:   doc/po/ko_KR/reference_editor.xml.po
         modified:   doc/po/ko_KR/reference_exception.xml.po
         modified:   doc/po/ko_KR/reference_guc.xml.po
         modified:   doc/po/ko_KR/reference_input.xml.po
         modified:   doc/po/ko_KR/reference_lrs.xml.po
         modified:   doc/po/ko_KR/reference_management.xml.po
         modified:   doc/po/ko_KR/reference_measure.xml.po
         modified:   doc/po/ko_KR/reference_operator.xml.po
         modified:   doc/po/ko_KR/reference_output.xml.po
         modified:   doc/po/ko_KR/reference_overlay.xml.po
         modified:   doc/po/ko_KR/reference_processing.xml.po
         modified:   doc/po/ko_KR/reference_raster.xml.po
         modified:   doc/po/ko_KR/reference_relationship.xml.po
         modified:   doc/po/ko_KR/reference_sfcgal.xml.po
         modified:   doc/po/ko_KR/reference_srs.xml.po
         modified:   doc/po/ko_KR/reference_trajectory.xml.po
         modified:   doc/po/ko_KR/reference_transaction.xml.po
         modified:   doc/po/ko_KR/reference_transformation.xml.po
         modified:   doc/po/ko_KR/reference_troubleshooting.xml.po
         modified:   doc/po/ko_KR/reference_type.xml.po
         modified:   doc/po/ko_KR/reference_validation.xml.po
         modified:   doc/po/ko_KR/reference_version.xml.po
         modified:   doc/po/ko_KR/release_notes.xml.po
         modified:   doc/po/ko_KR/reporting.xml.po
         modified:   doc/po/ko_KR/using_postgis_app.xml.po
         modified:   doc/po/ko_KR/using_postgis_dataman.xml.po
         modified:   doc/po/ko_KR/using_postgis_query.xml.po
         modified:   doc/po/ko_KR/using_raster_dataman.xml.po
         modified:   doc/po/pl/administration.xml.po
         modified:   doc/po/pl/database_tuning.xml.po
         modified:   doc/po/pl/extras.xml.po
         modified:   doc/po/pl/extras_address_standardizer.xml.po
         modified:   doc/po/pl/extras_historytable.xml.po
         modified:   doc/po/pl/extras_tigergeocoder.xml.po
         modified:   doc/po/pl/extras_topology.xml.po
         modified:   doc/po/pl/faq.xml.po
         modified:   doc/po/pl/faq_raster.xml.po
         modified:   doc/po/pl/installation.xml.po
         modified:   doc/po/pl/introduction.xml.po
         modified:   doc/po/pl/performance_tips.xml.po
         modified:   doc/po/pl/postgis.xml.po
         modified:   doc/po/pl/reference.xml.po
         modified:   doc/po/pl/reference_accessor.xml.po
         modified:   doc/po/pl/reference_bbox.xml.po
         modified:   doc/po/pl/reference_cluster.xml.po
         modified:   doc/po/pl/reference_constructor.xml.po
         modified:   doc/po/pl/reference_editor.xml.po
         modified:   doc/po/pl/reference_exception.xml.po
         modified:   doc/po/pl/reference_guc.xml.po
         modified:   doc/po/pl/reference_input.xml.po
         modified:   doc/po/pl/reference_lrs.xml.po
         modified:   doc/po/pl/reference_management.xml.po
         modified:   doc/po/pl/reference_measure.xml.po
         modified:   doc/po/pl/reference_operator.xml.po
         modified:   doc/po/pl/reference_output.xml.po
         modified:   doc/po/pl/reference_overlay.xml.po
         modified:   doc/po/pl/reference_processing.xml.po
         modified:   doc/po/pl/reference_raster.xml.po
         modified:   doc/po/pl/reference_relationship.xml.po
         modified:   doc/po/pl/reference_sfcgal.xml.po
         modified:   doc/po/pl/reference_srs.xml.po
         modified:   doc/po/pl/reference_trajectory.xml.po
         modified:   doc/po/pl/reference_transaction.xml.po
         modified:   doc/po/pl/reference_transformation.xml.po
         modified:   doc/po/pl/reference_troubleshooting.xml.po
         modified:   doc/po/pl/reference_type.xml.po
         modified:   doc/po/pl/reference_validation.xml.po
         modified:   doc/po/pl/reference_version.xml.po
         modified:   doc/po/pl/release_notes.xml.po
         modified:   doc/po/pl/reporting.xml.po
         modified:   doc/po/pl/using_postgis_app.xml.po
         modified:   doc/po/pl/using_postgis_dataman.xml.po
         modified:   doc/po/pl/using_postgis_query.xml.po
         modified:   doc/po/pl/using_raster_dataman.xml.po
         modified:   doc/po/pt_BR/administration.xml.po
         modified:   doc/po/pt_BR/database_tuning.xml.po
         modified:   doc/po/pt_BR/extras.xml.po
         modified:   doc/po/pt_BR/extras_address_standardizer.xml.po
         modified:   doc/po/pt_BR/extras_historytable.xml.po
         modified:   doc/po/pt_BR/extras_tigergeocoder.xml.po
         modified:   doc/po/pt_BR/extras_topology.xml.po
         modified:   doc/po/pt_BR/faq.xml.po
         modified:   doc/po/pt_BR/faq_raster.xml.po
         modified:   doc/po/pt_BR/installation.xml.po
         modified:   doc/po/pt_BR/introduction.xml.po
         modified:   doc/po/pt_BR/performance_tips.xml.po
         modified:   doc/po/pt_BR/postgis.xml.po
         modified:   doc/po/pt_BR/reference.xml.po
         modified:   doc/po/pt_BR/reference_accessor.xml.po
         modified:   doc/po/pt_BR/reference_bbox.xml.po
         modified:   doc/po/pt_BR/reference_cluster.xml.po
         modified:   doc/po/pt_BR/reference_constructor.xml.po
         modified:   doc/po/pt_BR/reference_editor.xml.po
         modified:   doc/po/pt_BR/reference_exception.xml.po
         modified:   doc/po/pt_BR/reference_guc.xml.po
         modified:   doc/po/pt_BR/reference_input.xml.po
         modified:   doc/po/pt_BR/reference_lrs.xml.po
         modified:   doc/po/pt_BR/reference_management.xml.po
         modified:   doc/po/pt_BR/reference_measure.xml.po
         modified:   doc/po/pt_BR/reference_operator.xml.po
         modified:   doc/po/pt_BR/reference_output.xml.po
         modified:   doc/po/pt_BR/reference_overlay.xml.po
         modified:   doc/po/pt_BR/reference_processing.xml.po
         modified:   doc/po/pt_BR/reference_raster.xml.po
         modified:   doc/po/pt_BR/reference_relationship.xml.po
         modified:   doc/po/pt_BR/reference_sfcgal.xml.po
         modified:   doc/po/pt_BR/reference_srs.xml.po
         modified:   doc/po/pt_BR/reference_trajectory.xml.po
         modified:   doc/po/pt_BR/reference_transaction.xml.po
         modified:   doc/po/pt_BR/reference_transformation.xml.po
         modified:   doc/po/pt_BR/reference_troubleshooting.xml.po
         modified:   doc/po/pt_BR/reference_type.xml.po
         modified:   doc/po/pt_BR/reference_validation.xml.po
         modified:   doc/po/pt_BR/reference_version.xml.po
         modified:   doc/po/pt_BR/release_notes.xml.po
         modified:   doc/po/pt_BR/reporting.xml.po
         modified:   doc/po/pt_BR/using_postgis_app.xml.po
         modified:   doc/po/pt_BR/using_postgis_dataman.xml.po
         modified:   doc/po/pt_BR/using_postgis_query.xml.po
         modified:   doc/po/pt_BR/using_raster_dataman.xml.po
         modified:   doc/po/ru/administration.xml.po
         modified:   doc/po/ru/database_tuning.xml.po
         modified:   doc/po/ru/extras.xml.po
         modified:   doc/po/ru/extras_address_standardizer.xml.po
         modified:   doc/po/ru/extras_historytable.xml.po
         modified:   doc/po/ru/extras_tigergeocoder.xml.po
         modified:   doc/po/ru/extras_topology.xml.po
         modified:   doc/po/ru/faq.xml.po
         modified:   doc/po/ru/faq_raster.xml.po
         modified:   doc/po/ru/installation.xml.po
         modified:   doc/po/ru/introduction.xml.po
         modified:   doc/po/ru/performance_tips.xml.po
         modified:   doc/po/ru/postgis.xml.po
         modified:   doc/po/ru/reference.xml.po
         modified:   doc/po/ru/reference_accessor.xml.po
         modified:   doc/po/ru/reference_bbox.xml.po
         modified:   doc/po/ru/reference_cluster.xml.po
         modified:   doc/po/ru/reference_constructor.xml.po
         modified:   doc/po/ru/reference_editor.xml.po
         modified:   doc/po/ru/reference_exception.xml.po
         modified:   doc/po/ru/reference_guc.xml.po
         modified:   doc/po/ru/reference_input.xml.po
         modified:   doc/po/ru/reference_lrs.xml.po
         modified:   doc/po/ru/reference_management.xml.po
         modified:   doc/po/ru/reference_measure.xml.po
         modified:   doc/po/ru/reference_operator.xml.po
         modified:   doc/po/ru/reference_output.xml.po
         modified:   doc/po/ru/reference_overlay.xml.po
         modified:   doc/po/ru/reference_processing.xml.po
         modified:   doc/po/ru/reference_raster.xml.po
         modified:   doc/po/ru/reference_relationship.xml.po
         modified:   doc/po/ru/reference_sfcgal.xml.po
         modified:   doc/po/ru/reference_srs.xml.po
         modified:   doc/po/ru/reference_trajectory.xml.po
         modified:   doc/po/ru/reference_transaction.xml.po
         modified:   doc/po/ru/reference_transformation.xml.po
         modified:   doc/po/ru/reference_troubleshooting.xml.po
         modified:   doc/po/ru/reference_type.xml.po
         modified:   doc/po/ru/reference_validation.xml.po
         modified:   doc/po/ru/reference_version.xml.po
         modified:   doc/po/ru/release_notes.xml.po
         modified:   doc/po/ru/reporting.xml.po
         modified:   doc/po/ru/using_postgis_app.xml.po
         modified:   doc/po/ru/using_postgis_dataman.xml.po
         modified:   doc/po/ru/using_postgis_query.xml.po
         modified:   doc/po/ru/using_raster_dataman.xml.po
         modified:   doc/po/templates/administration.xml.pot
         modified:   doc/po/templates/database_tuning.xml.pot
         modified:   doc/po/templates/extras.xml.pot
         modified:   doc/po/templates/extras_address_standardizer.xml.pot
         modified:   doc/po/templates/extras_historytable.xml.pot
         modified:   doc/po/templates/extras_tigergeocoder.xml.pot
         modified:   doc/po/templates/extras_topology.xml.pot
         modified:   doc/po/templates/faq.xml.pot
         modified:   doc/po/templates/faq_raster.xml.pot
         modified:   doc/po/templates/installation.xml.pot
         modified:   doc/po/templates/introduction.xml.pot
         modified:   doc/po/templates/performance_tips.xml.pot
         modified:   doc/po/templates/postgis.xml.pot
         modified:   doc/po/templates/reference.xml.pot
         modified:   doc/po/templates/reference_accessor.xml.pot
         modified:   doc/po/templates/reference_bbox.xml.pot
         modified:   doc/po/templates/reference_cluster.xml.pot
         modified:   doc/po/templates/reference_constructor.xml.pot
         modified:   doc/po/templates/reference_editor.xml.pot
         modified:   doc/po/templates/reference_exception.xml.pot
         modified:   doc/po/templates/reference_guc.xml.pot
         modified:   doc/po/templates/reference_input.xml.pot
         modified:   doc/po/templates/reference_lrs.xml.pot
         modified:   doc/po/templates/reference_management.xml.pot
         modified:   doc/po/templates/reference_measure.xml.pot
         modified:   doc/po/templates/reference_operator.xml.pot
         modified:   doc/po/templates/reference_output.xml.pot
         modified:   doc/po/templates/reference_overlay.xml.pot
         modified:   doc/po/templates/reference_processing.xml.pot
         modified:   doc/po/templates/reference_raster.xml.pot
         modified:   doc/po/templates/reference_relationship.xml.pot
         modified:   doc/po/templates/reference_sfcgal.xml.pot
         modified:   doc/po/templates/reference_srs.xml.pot
         modified:   doc/po/templates/reference_trajectory.xml.pot
         modified:   doc/po/templates/reference_transaction.xml.pot
         modified:   doc/po/templates/reference_transformation.xml.pot
         modified:   doc/po/templates/reference_troubleshooting.xml.pot
         modified:   doc/po/templates/reference_type.xml.pot
         modified:   doc/po/templates/reference_validation.xml.pot
         modified:   doc/po/templates/reference_version.xml.pot
         modified:   doc/po/templates/release_notes.xml.pot
         modified:   doc/po/templates/reporting.xml.pot
         modified:   doc/po/templates/using_postgis_app.xml.pot
         modified:   doc/po/templates/using_postgis_dataman.xml.pot
         modified:   doc/po/templates/using_postgis_query.xml.pot
         modified:   doc/po/templates/using_raster_dataman.xml.pot
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5053#comment:3>
