[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-838-ga64f2dae9
git at osgeo.org
git at osgeo.org
Fri May 13 23:45:12 PDT 2022
the project "PostGIS".
via a64f2dae908baf89aa1a45ccd4d25702f5a59845 (commit)
via ec3e74ec1f0ffdfbead6edb9b5c2300a86abd9a6 (commit)
from 32268098405b097431a74be2963317f6585df56a (commit)
revisions in full, below.
commit a64f2dae908baf89aa1a45ccd4d25702f5a59845
Author: Regina Obe <regina at arrival3d.com>
Date: Sat May 14 06:14:00 2022 +0000
Translated using Weblate (Russian)
Currently translated at 22.3% (21 of 94 strings)
Translation: postgis/administration.xml
Translate-URL: https://weblate.osgeo.org/projects/postgis/administrationxml/ru/
diff --git a/doc/po/ru/administration.xml.po b/doc/po/ru/administration.xml.po
index b7deffcd1..fe738d3b0 100644
--- a/doc/po/ru/administration.xml.po
+++ b/doc/po/ru/administration.xml.po
@@ -7,7 +7,7 @@ msgstr ""
"Project-Id-Version: PACKAGE VERSION\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2022-01-25 19:29+0000\n"
-"PO-Revision-Date: 2022-01-20 20:57+0000\n"
+"PO-Revision-Date: 2022-05-14 06:14+0000\n"
"Last-Translator: Regina Obe <regina at arrival3d.com>\n"
"Language-Team: Russian <https://weblate.osgeo.org/projects/postgis/"
"administrationxml/ru/>\n"
@@ -17,7 +17,7 @@ msgstr ""
"Content-Transfer-Encoding: 8bit\n"
"Plural-Forms: nplurals=3; plural=n%10==1 && n%100!=11 ? 0 : n%10>=2 && n"
"%10<=4 && (n%100<10 || n%100>=20) ? 1 : 2;\n"
-"X-Generator: Weblate 4.10.1\n"
+"X-Generator: Weblate 4.12.2\n"
#. Tag: title
#: administration.xml:3
@@ -210,6 +210,8 @@ msgstr ""
msgid ""
"Run the following SQL snippet in the database you want to enable spatially:"
msgstr ""
+"Запустите следующий фрагмент SQL в базе данных, которую вы хотите включить "
+"пространственно:"
#. Tag: programlisting
#: administration.xml:57
commit ec3e74ec1f0ffdfbead6edb9b5c2300a86abd9a6
Date: Sat May 14 06:11:20 2022 +0000
Translated using Weblate (Spanish)
Currently translated at 13.6% (29 of 213 strings)
Translation: postgis/introduction.xml
Translate-URL: https://weblate.osgeo.org/projects/postgis/introductionxml/es/
diff --git a/doc/po/es/introduction.xml.po b/doc/po/es/introduction.xml.po
index b095fa204..848805ffa 100644
--- a/doc/po/es/introduction.xml.po
+++ b/doc/po/es/introduction.xml.po
@@ -3,20 +3,22 @@
# Translators:
# David Martinez Morata, 2013
+# Regina Obe <regina at arrival3d.com>, 2022.
msgid ""
msgstr ""
"Project-Id-Version: PostGIS\n"
"POT-Creation-Date: 2022-04-16 08:20+0000\n"
-"PO-Revision-Date: 2018-07-22 02:48+0000\n"
-"Last-Translator: georgersilva <georger.silva at gmail.com>\n"
-"Language-Team: Spanish (http://www.transifex.com/postgis/postgis/language/"
-"es/)\n"
+"Last-Translator: Regina Obe <regina at arrival3d.com>\n"
+"Language-Team: Spanish <https://weblate.osgeo.org/projects/postgis/"
+"introductionxml/es/>\n"
"Language: es\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
-"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+"Plural-Forms: nplurals=2; plural=n != 1;\n"
#. Tag: title
#: introduction.xml:3
@@ -1115,7 +1117,7 @@ msgstr ""
#: introduction.xml:341
#, no-c-format
msgid "Camptocamp"
-msgstr ""
+msgstr "Camptocamp"
#. Tag: ulink
#: introduction.xml:342
@@ -1259,7 +1261,7 @@ msgstr ""
#: introduction.xml:365
#, no-c-format
msgid "Paragon Corporation"
-msgstr ""
+msgstr "Paragon Corporation"
#. Tag: ulink
#: introduction.xml:366
Summary of changes:
doc/po/es/introduction.xml.po | 16 +++++++++-------
doc/po/ru/administration.xml.po | 6 ++++--
2 files changed, 13 insertions(+), 9 deletions(-)
hooks/post-receive
