[postgis-tickets] [PostGIS] #5150: postgis_extension_AddToSearchPath should take input as text instead of varchar
PostGIS trac at osgeo.org
Sat May 14 23:12:22 PDT 2022
varchar
 Reporter:  robe                   |      Owner:  robe
     Type:  defect                 |     Status:  assigned
 Priority:  medium                 |  Milestone:  PostGIS 2.5.7
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 This is a security change.
 It is possible for a user to create a function
 postgis_extension_AddToSearchPath(text) in the same schema as the
 postgis_extension_AddToSearchPath(varchar) we defined.
 This could allow a rogue user to have their version of function run during
 extension create/updates instead of the one we ship.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5150>
