[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.5-12-gb175c26ee
git at osgeo.org
git at osgeo.org
Thu May 19 19:58:24 PDT 2022
the project "PostGIS".
The branch, stable-3.1 has been updated
via b175c26eee538e472aaf1a22afd2099b14d60481 (commit)
via e10cabb1fabf1cf9d452d1c5758ee448e105241b (commit)
from c14e9a059aca3ee39fdbfab88190da5172a81122 (commit)
revisions in full, below.
commit b175c26eee538e472aaf1a22afd2099b14d60481
Author: Regina Obe <lr at pcorp.us>
Date: Thu May 19 22:56:53 2022 -0400
Numerous fixes to helper functions.
References #5150
References #5125
References #5155 for PostGIS 3.1.6
diff --git a/NEWS b/NEWS
index 1f54a4460..2370acda9 100644
--- a/NEWS
+++ b/NEWS
@@ -9,6 +9,9 @@ PostGIS 3.1.6dev
- #5100, Stop using pg_atoi, removed in PG 15 (Laurenz Albe)
- #5115, Allow dropping topologies with pending constraints (Sandro Santilli)
- #5151, ST_SetPoint with empty geometries (Regina Obe)
+ - #5150, Change signature of AddToSearchPath (Regina Obe)
+ - #5125, Fix search path function (Sandro Santilli)
+ - #5155, More schema qual fixes (Regina Obe)
PostGIS 3.1.5
2022/02/01
diff --git a/extensions/postgis_extension_helper.sql b/extensions/postgis_extension_helper.sql
index aa0713407..e40f03a9f 100644
--- a/extensions/postgis_extension_helper.sql
+++ b/extensions/postgis_extension_helper.sql
@@ -18,7 +18,7 @@
-- this is needed because there is no ALTER EXTENSION DROP FUNCTION/AGGREGATE command
-- and we can't CREATE OR REPALCe functions whose signatures have changed and we can drop them if they are part of an extention
-- So we use this to remove it from extension first before we drop
-CREATE OR REPLACE FUNCTION postgis_extension_remove_objects(param_extension text, param_type text)
+CREATE FUNCTION postgis_extension_remove_objects(param_extension text, param_type text)
RETURNS boolean AS
DECLARE
@@ -81,7 +81,7 @@ END;
LANGUAGE plpgsql VOLATILE;
-CREATE OR REPLACE FUNCTION postgis_extension_drop_if_exists(param_extension text, param_statement text)
+CREATE FUNCTION postgis_extension_drop_if_exists(param_extension text, param_statement text)
RETURNS boolean AS
DECLARE
@@ -101,7 +101,7 @@ END;
-CREATE OR REPLACE FUNCTION postgis_extension_AddToSearchPath(a_schema_name varchar)
+CREATE FUNCTION postgis_extension_AddToSearchPath(a_schema_name text)
RETURNS text
AS
@@ -109,7 +109,30 @@ DECLARE
var_result text;
var_cur_search_path text;
BEGIN
- SELECT reset_val INTO var_cur_search_path FROM pg_catalog.pg_settings WHERE name = 'search_path';
+ WITH settings AS (
+ SELECT pg_catalog.unnest(setconfig) config
+ FROM pg_catalog.pg_db_role_setting
+ WHERE setdatabase = (
+ SELECT oid
+ FROM pg_catalog.pg_database
+ WHERE datname = current_database()
+ ) and setrole = 0
+ SELECT pg_catalog.regexp_replace(config, '^search_path=', '')
+ FROM settings WHERE config like 'search_path=%'
+ INTO var_cur_search_path;
+ RAISE NOTICE 'cur_search_path from pg_db_role_setting is %', var_cur_search_path;
+ IF var_cur_search_path IS NULL THEN
+ SELECT reset_val
+ FROM pg_catalog.pg_settings
+ WHERE name = 'search_path';
+ RAISE NOTICE 'cur_search_path from pg_settings is %', var_cur_search_path;
+ END IF;
IF var_cur_search_path LIKE '%' || pg_catalog.quote_ident(a_schema_name) || '%' THEN
var_result := a_schema_name || ' already in database search_path';
ELSE
diff --git a/extensions/postgis_extension_helper_uninstall.sql b/extensions/postgis_extension_helper_uninstall.sql
index b08048fd9..2fb1d1756 100644
--- a/extensions/postgis_extension_helper_uninstall.sql
+++ b/extensions/postgis_extension_helper_uninstall.sql
@@ -15,4 +15,5 @@
-- and should be called at the end of the extension upgrade file
DROP FUNCTION postgis_extension_remove_objects(text, text);
DROP FUNCTION postgis_extension_drop_if_exists(text, text);
-DROP FUNCTION postgis_extension_AddToSearchPath(varchar);
+DROP FUNCTION IF EXISTS postgis_extension_AddToSearchPath(varchar);
+DROP FUNCTION IF EXISTS postgis_extension_AddToSearchPath(text);
commit e10cabb1fabf1cf9d452d1c5758ee448e105241b
Date: Thu May 19 22:53:05 2022 -0400
Only test window functions with OVER (not aggs). We did not backport some agg over crashers to 3.1
diff --git a/doc/xsl/postgis_gardentest.sql.xsl b/doc/xsl/postgis_gardentest.sql.xsl
index 8aec3efc1..871163589 100644
--- a/doc/xsl/postgis_gardentest.sql.xsl
+++ b/doc/xsl/postgis_gardentest.sql.xsl
@@ -526,11 +526,11 @@ SELECT '<xsl:value-of select="$log_label" /> Geography: End Testing';
</xsl:choose>
</xsl:variable>
- <!-- is a window or aggregate function -->
+ <!-- is a window function -->
<xsl:variable name='over_clause'>
<xsl:choose>
- <xsl:when test="paramdef/type[contains(text(),'set')]">
- <xsl:value-of select="'OVER(ORDER BY random())'"/>
+ <xsl:when test="paramdef/type[contains(text(),'winset')]">
+ <xsl:value-of select="'OVER(random())'"/>
</xsl:when>
<xsl:otherwise>
<xsl:value-of select="''"/>
Summary of changes:
NEWS | 3 +++
doc/xsl/postgis_gardentest.sql.xsl | 6 ++---
extensions/postgis_extension_helper.sql | 31 ++++++++++++++++++++---
extensions/postgis_extension_helper_uninstall.sql | 3 ++-
4 files changed, 35 insertions(+), 8 deletions(-)
hooks/post-receive
