[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-867-g216aca648
Fri May 20 08:37:29 PDT 2022
the project "PostGIS".
       via  216aca6483a2fa65a33b488e103c1188c4ade878 (commit)
      from  9f074a348926da7a66f5d5f7b01e8503c0079494 (commit)
revisions in full, below.
commit 216aca6483a2fa65a33b488e103c1188c4ade878
Author: Regina Obe <lr at pcorp.us>
Date:   Fri May 20 11:37:22 2022 -0400
    Fix some schema quals. References #5155 for PostGIS 3.3.0
diff --git a/extensions/postgis_extension_helper.sql b/extensions/postgis_extension_helper.sql
index 4d9b19538..e5546327e 100644
--- a/extensions/postgis_extension_helper.sql
+++ b/extensions/postgis_extension_helper.sql
@@ -85,7 +85,7 @@ CREATE FUNCTION postgis_extension_drop_if_exists(param_extension text, param_sta
   RETURNS boolean AS
 DECLARE
-	var_sql_ext text := 'ALTER EXTENSION ' || pg_catalog.quote_ident(param_extension) || ' ' || replace(param_statement, 'IF EXISTS', '');
+	var_sql_ext text := 'ALTER EXTENSION ' || pg_catalog.quote_ident(param_extension) || ' ' || pg_catalog.replace(param_statement, 'IF EXISTS', '');
 	var_result boolean := false;
 BEGIN
 	BEGIN
@@ -111,7 +111,7 @@ DECLARE
 BEGIN
 	WITH settings AS (
-		SELECT unnest(setconfig) config
+		SELECT pg_catalog.unnest(setconfig) config
 		FROM pg_catalog.pg_db_role_setting
 		WHERE setdatabase = (
 			SELECT oid
@@ -119,7 +119,7 @@ BEGIN
 			WHERE datname = current_database()
 		) and setrole = 0
-	SELECT regexp_replace(config, '^search_path=', '')
+	SELECT pg_catalog.regexp_replace(config, '^search_path=', '')
 	FROM settings WHERE config like 'search_path=%'
 	INTO var_cur_search_path;
Summary of changes:
 extensions/postgis_extension_helper.sql | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
