[postgis-tickets] [PostGIS] #5163: ST_OrientedEnvelope goes into infinite loop when given a straight line
PostGIS trac at osgeo.org
Thu May 26 13:12:39 PDT 2022
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS GEOS
 Component:  postgis  |    Version:  3.1.x
Resolution:           |   Keywords:
Comment (by mdavis):
 This is a GEOS issue, and also JTS.
 JTS fix is [https://github.com/locationtech/jts/pull/875 JTS-875].
 GEOS 3.11 fix is [https://github.com/libgeos/geos/pull/616 GEOS-616].
 Will be backported to 3.10 and probably 3.9.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5163#comment:3>
