[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-10-g111d08021
git at osgeo.org
git at osgeo.org
Fri May 27 09:17:25 PDT 2022
the project "PostGIS".
via 111d080211e8bd1b4d9fd27974baabec562d29bd (commit)
from 61402cf4dcd8a9e26199f0a0baa9b914c47f3f91 (commit)
revisions in full, below.
commit 111d080211e8bd1b4d9fd27974baabec562d29bd
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri May 27 09:16:19 2022 -0700
Fix wraparound math problem in strncat calls, closes #5114
diff --git a/loader/pgsql2shp-core.c b/loader/pgsql2shp-core.c
index 06226e951..4a3d593de 100644
--- a/loader/pgsql2shp-core.c
+++ b/loader/pgsql2shp-core.c
@@ -35,6 +35,7 @@
#include <sys/param.h>
#endif
+#include "../liblwgeom/stringbuffer.h"
#include "../liblwgeom/liblwgeom.h" /* for LWGEOM struct and funx */
#include "../liblwgeom/lwgeom_log.h" /* for LWDEBUG macros */
@@ -1351,12 +1352,8 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
/* If a user-defined query has been specified, create and point the state to our new table */
if (state->config->usrquery)
- state->table = malloc(20 + 20); /* string + max long precision */
- sprintf(state->table, "__pgsql2shp%lu_tmp_table", (long)getpid());
- query = malloc(32 + strlen(state->table) + strlen(state->config->usrquery));
- sprintf(query, "CREATE TEMP TABLE \"%s\" AS %s", state->table, state->config->usrquery);
+ asprintf(&(state->table), "__pgsql2shp%lu_tmp_table", (long)getpid());
+ asprintf(&query, "CREATE TEMP TABLE \"%s\" AS %s", state->table, state->config->usrquery);
res = PQexec(state->conn, query);
free(query);
@@ -1380,9 +1377,7 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
/* Get the list of columns and their types for the selected table */
if (state->schema)
- query = malloc(250 + strlen(state->schema) + strlen(state->table));
- sprintf(query, "SELECT a.attname, a.atttypid, "
+ asprintf(&query, "SELECT a.attname, a.atttypid, "
"a.atttypmod, a.attlen FROM "
"pg_attribute a, pg_class c, pg_namespace n WHERE "
"n.nspname = '%s' AND a.attrelid = c.oid AND "
@@ -1392,9 +1387,7 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
else
- query = malloc(250 + strlen(state->table));
"pg_attribute a, pg_class c WHERE "
"a.attrelid = c.oid and a.attnum > 0 AND "
@@ -1569,13 +1562,10 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
/* Issue warning if column has been renamed */
if (strcasecmp(dbffieldname, pgfieldname))
- if ( snprintf(buf, 256, _("Warning, field %s renamed to %s\n"),
- pgfieldname, dbffieldname) >= 256 )
- buf[255] = '\0';
+ snprintf(buf, sizeof(buf), _("Warning, field %s renamed to %s\n"), pgfieldname, dbffieldname);
/* Note: we concatenate all warnings from the main loop as this is useful information */
- strncat(state->message, buf, SHPDUMPERMSGLEN - strlen(state->message) - 1);
+ if (SHPDUMPERMSGLEN > (strlen(state->message) + 1))
+ strncat(state->message, buf, SHPDUMPERMSGLEN - (strlen(state->message) + 1));
ret = SHPDUMPERWARN;
@@ -1765,9 +1755,12 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
if (dbffieldsize > MAX_DBF_FIELD_SIZE)
- snprintf(buf, 256, _("Warning: values of field '%s' exceeding maximum dbf field width (%d) "
+ snprintf(buf, sizeof(buf), _("Warning: values of field '%s' exceeding maximum dbf field width (%d) "
"will be truncated.\n"), dbffieldname, MAX_DBF_FIELD_SIZE);
- strncat(state->message, buf, SHPDUMPERMSGLEN - strlen(state->message));
+ strncat(state->message, buf, SHPDUMPERMSGLEN - (strlen(state->message)+1));
dbffieldsize = MAX_DBF_FIELD_SIZE;
@@ -1820,8 +1813,9 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
/* No geo* column specified so we can only create the DBF section -
but let's issue a warning... */
- snprintf(buf, 256, _("No geometry column found.\nThe DBF file will be created but not the shx or shp files.\n"));
+ snprintf(buf, sizeof(buf), _("No geometry column found.\nThe DBF file will be created but not the shx or shp files.\n"));
state->shp = NULL;
@@ -1840,10 +1834,10 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
/* Now we have the complete list of fieldnames, let's generate the SQL query. First let's make sure
we reserve enough space for tables with lots of columns */
j = 0;
/*TODO: this really should be rewritten to use stringbuffer */
for (i = 0; i < state->fieldcount; i++)
j += strlen( state->pgfieldnames[i]) + 10; /*add extra space for the quotes to quote identify and any embedded quotes that may need escaping */
@@ -1957,8 +1951,7 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
state->fetchres = NULL;
/* Generate the fetch query */
- state->fetch_query = malloc(256);
- sprintf(state->fetch_query, "FETCH %d FROM cur", state->config->fetchsize);
+ asprintf(&(state->fetch_query), "FETCH %d FROM cur", state->config->fetchsize);
return SHPDUMPEROK;
Summary of changes:
loader/pgsql2shp-core.c | 43 ++++++++++++++++++-------------------------
1 file changed, 18 insertions(+), 25 deletions(-)
hooks/post-receive
