[SCM] PostGIS branch master updated. 3.4.0rc1-1151-gbb94b8dc8
Wed Jun 12 08:08:39 PDT 2024
the project "PostGIS".
       via  bb94b8dc8bfbe31bcf505d0262724236011601a7 (commit)
      from  23a1dd0339b4333787d23e7f2ffd5f6d293bead8 (commit)
revisions in full, below.
commit bb94b8dc8bfbe31bcf505d0262724236011601a7
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jun 12 12:42:17 2024 +0200
    New postgis_proj_compiled_version() and exposure in full version
    Only shows compiled version in postgis_full_version() output
    if it doesn't match with runtime version up to patchlevel.
    Closes #5742
diff --git a/NEWS b/NEWS
index 195cd9102..c0283954f 100644
--- a/NEWS
+++ b/NEWS
@@ -50,6 +50,7 @@ Andreas Schild (German Team)
       - command upgrade upgrades all databases that need to be
       - command status reports status of all databases
     (Sandro Santilli)
+  - #5742, expose version of PROJ at compile time (Sandro Santilli)
   - #5721, Allow sharing sequences between different topologies (Lars Opsahl)
   - #5667, TopoGeo_LoadGeometry (Sandro Santilli)
   - #5055, add explicit <> geometry operator to prevent non-unique
diff --git a/doc/reference_version.xml b/doc/reference_version.xml
index 9c448561a..1cbdc8917 100644
--- a/doc/reference_version.xml
+++ b/doc/reference_version.xml
@@ -7,7 +7,7 @@
     </abstract>
     </info>
 <refentry xml:id="PostGIS_Extensions_Upgrade">
 	  <refnamediv>
@@ -420,10 +420,64 @@ postgis_liblwgeom_version
 	  <refsection>
 		<title>See Also</title>
-		<para><xref linkend="PostGIS_Full_Version"/>, <xref linkend="PostGIS_GEOS_Version"/>,  <xref linkend="PostGIS_Lib_Version"/>, <xref linkend="PostGIS_LibXML_Version"/>, <xref linkend="PostGIS_Version"/></para>
+		<para>
+<xref linkend="PostGIS_PROJ_Compiled_Version"/>,
+<xref linkend="PostGIS_Full_Version"/>,
+<xref linkend="PostGIS_GEOS_Version"/>,
+<xref linkend="PostGIS_Lib_Version"/>,
+<xref linkend="PostGIS_LibXML_Version"/>,
+<xref linkend="PostGIS_Version"/></para>
 	  </refsection>
 	</refentry>
+	<refentry xml:id="PostGIS_PROJ_Compiled_Version">
+	  <refnamediv>
+		<refname>PostGIS_PROJ_Compiled_Version</refname>
+		<refpurpose>Returns the version number of the PROJ
+		library against which PostGIS was built.</refpurpose>
+	  </refnamediv>
+	  <refsynopsisdiv>
+		<funcsynopsis>
+		  <funcprototype>
+			<funcdef>text <function>PostGIS_PROJ_Compiled_Version</function></funcdef>
+			<paramdef></paramdef>
+		  </funcprototype>
+		</funcsynopsis>
+	  </refsynopsisdiv>
+	  <refsection>
+		<title>Description</title>
+		<para>Returns the version number of the PROJ library, or
+		against which PostGIS was built.</para>
+		<para role="availability" conformance="3.4.0">Availability: 3.5.0</para>
+	  </refsection>
+	  <refsection>
+		<title>Examples</title>
+		<programlisting>SELECT PostGIS_PROJ_Compiled_Version();
+ postgis_proj_compiled_version
+ 9.1.1
+(1 row)</programlisting>
+	  </refsection>
+	  <refsection>
+		<title>See Also</title>
+		<para>
+<xref linkend="PostGIS_PROJ_Version"/>,
+        </para>
+	  </refsection>
+	</refentry>
 	<refentry xml:id="PostGIS_Wagyu_Version">
 	  <refnamediv>
 		<refname>PostGIS_Wagyu_Version</refname>
@@ -650,4 +704,4 @@ postgis_liblwgeom_version
 	  </refsection>
 	</refentry>
-  </section>
\ No newline at end of file
+  </section>
diff --git a/postgis/lwgeom_transform.c b/postgis/lwgeom_transform.c
index 43e40de68..82c7382a4 100644
--- a/postgis/lwgeom_transform.c
+++ b/postgis/lwgeom_transform.c
@@ -39,6 +39,7 @@ Datum transform(PG_FUNCTION_ARGS);
 Datum transform_geom(PG_FUNCTION_ARGS);
 Datum transform_pipeline_geom(PG_FUNCTION_ARGS);
 Datum postgis_proj_version(PG_FUNCTION_ARGS);
+Datum postgis_proj_version_compiled(PG_FUNCTION_ARGS);
 Datum LWGEOM_asKML(PG_FUNCTION_ARGS);
@@ -227,6 +228,23 @@ Datum postgis_proj_version(PG_FUNCTION_ARGS)
 	PG_RETURN_POINTER(cstring_to_text(stringbuffer_getstring(&sb)));
+PG_FUNCTION_INFO_V1(postgis_proj_compiled_version);
+Datum postgis_proj_compiled_version(PG_FUNCTION_ARGS)
+  static char ver[64];
+  text *result;
+  sprintf(
+    ver,
+    "%d.%d.%d",
+    (POSTGIS_PROJ_VERSION/10000),
+    ((POSTGIS_GEOS_VERSION%10000)/100),
+    ((POSTGIS_GEOS_VERSION)%100)
+  result = cstring_to_text(ver);
+  PG_RETURN_POINTER(result);
  * Encode feature in KML
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index c8f0ed48b..33d0ee707 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -3033,6 +3033,11 @@ CREATE OR REPLACE FUNCTION postgis_proj_version() RETURNS text
 	LANGUAGE 'c' IMMUTABLE
 	_COST_DEFAULT;
+CREATE OR REPLACE FUNCTION postgis_proj_compiled_version() RETURNS text
+	AS 'MODULE_PATHNAME'
+	LANGUAGE 'c' IMMUTABLE
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION postgis_wagyu_version() RETURNS text
@@ -3223,6 +3228,7 @@ DECLARE
 	libver text;
 	librev text;
 	projver text;
+	projver_compiled text;
 	geosver text;
 	geosver_compiled text;
 	sfcgalver text;
@@ -3248,6 +3254,7 @@ BEGIN
 	SELECT @extschema at .postgis_proj_version() INTO projver;
 	SELECT @extschema at .postgis_geos_version() INTO geosver;
 	SELECT @extschema at .postgis_geos_compiled_version() INTO geosver_compiled;
+	SELECT @extschema at .postgis_proj_compiled_version() INTO projver_compiled;
 	SELECT @extschema at .postgis_libjson_version() INTO json_lib_ver;
 	SELECT @extschema at .postgis_libprotobuf_version() INTO protobuf_lib_ver;
 	SELECT @extschema at .postgis_wagyu_version() INTO wagyu_lib_ver;
@@ -3346,6 +3353,10 @@ BEGIN
 	IF  projver IS NOT NULL THEN
 		fullver = fullver || ' PROJ="' || projver || '"';
+		IF (string_to_array(projver, '.'))[1:3] != (string_to_array(projver_compiled, '.'))[1:3]
+		THEN
+			fullver = format('%s (compiled against PROJ %s)', fullver, projver_compiled);
+		END IF;
 	END IF;
 	IF  gdalver IS NOT NULL THEN
Summary of changes:
 NEWS                       |  1 +
 doc/reference_version.xml  | 60 +++++++++++++++++++++++++++++++++++++++++++---
 postgis/lwgeom_transform.c | 18 ++++++++++++++
 postgis/postgis.sql.in     | 11 +++++++++
 4 files changed, 87 insertions(+), 3 deletions(-)
hooks/post-receive
