[SCM] PostGIS branch master updated. 3.4.0rc1-1153-gb802f32c8
Wed Jun 12 08:10:38 PDT 2024
the project "PostGIS".
       via  b802f32c8a56a3d59cc16cb71429f483b1d4c878 (commit)
       via  fecf9cda4f41995f2d4b8f494d6944f92c7e5526 (commit)
      from  bb94b8dc8bfbe31bcf505d0262724236011601a7 (commit)
revisions in full, below.
commit b802f32c8a56a3d59cc16cb71429f483b1d4c878
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jun 7 09:38:43 2024 +0200
    Override GEOS typedef to add attribute when needed
diff --git a/liblwgeom/lwgeom_geos.h b/liblwgeom/lwgeom_geos.h
index a6e387eae..d97cc83d4 100644
--- a/liblwgeom/lwgeom_geos.h
+++ b/liblwgeom/lwgeom_geos.h
@@ -23,11 +23,18 @@
+#if POSTGIS_GEOS_VERSION < 31300
+/* See https://github.com/libgeos/geos/pull/1097 */
+typedef void (*GEOSMessageHandler)(const char *fmt, ...) __attribute__ (( format(printf, 1, 0) ));
+#endif
 #include "geos_c.h"
 #include "liblwgeom.h"
 #include "lwunionfind.h"
 ** Public prototypes for GEOS utility functions.
commit fecf9cda4f41995f2d4b8f494d6944f92c7e5526
Date:   Thu May 16 18:31:51 2024 +0200
    Add format attributes suggested by -Wsuggest-attribute=format
index 90a1562fb..a6e387eae 100644
@@ -45,7 +45,7 @@ int union_dbscan(LWGEOM **geoms, uint32_t num_geoms, UNIONFIND *uf, double eps,
 POINTARRAY* ptarray_from_GEOSCoordSeq(const GEOSCoordSequence* cs, uint8_t want3d);
 extern char lwgeom_geos_errmsg[];
-extern void lwgeom_geos_error(const char* fmt, ...);
+extern void lwgeom_geos_error(const char* fmt, ...) __attribute__ ((format (printf, 1, 2)));
diff --git a/liblwgeom/lwgeom_log.h b/liblwgeom/lwgeom_log.h
index ca65a17db..5caf9dba9 100644
--- a/liblwgeom/lwgeom_log.h
+++ b/liblwgeom/lwgeom_log.h
@@ -126,7 +126,7 @@
  * For debugging, use LWDEBUG() or LWDEBUGF().
  * @ingroup logging
-void lwnotice(const char *fmt, ...);
+void lwnotice(const char *fmt, ...) __attribute__ ((format (printf, 1, 2)));
  * Write a notice out to the error handler.
@@ -136,7 +136,7 @@ void lwnotice(const char *fmt, ...);
  * @ingroup logging
-void lwerror(const char *fmt, ...);
+void lwerror(const char *fmt, ...) __attribute__ ((format (printf, 1, 2)));
  * Write a debug message out.
@@ -145,7 +145,7 @@ void lwerror(const char *fmt, ...);
  * efficiency.
  * @ingroup logging
-void lwdebug(int level, const char *fmt, ...);
+void lwdebug(int level, const char *fmt, ...) __attribute__ ((format (printf, 2, 3)));
diff --git a/liblwgeom/lwutil.c b/liblwgeom/lwutil.c
index b14bb23f2..27326b912 100644
--- a/liblwgeom/lwutil.c
+++ b/liblwgeom/lwutil.c
@@ -46,13 +46,13 @@ lwreallocator lwrealloc_var = default_reallocator;
 lwfreeor lwfree_var = default_freeor;
 /* Default reporters */
-static void default_noticereporter(const char *fmt, va_list ap);
-static void default_errorreporter(const char *fmt, va_list ap);
+static void default_noticereporter(const char *fmt, va_list ap) __attribute__ ((format (printf, 1, 0)));
+static void default_errorreporter(const char *fmt, va_list ap) __attribute__ ((format (printf, 1, 0)));
 lwreporter lwnotice_var = default_noticereporter;
 lwreporter lwerror_var = default_errorreporter;
 /* Default logger */
-static void default_debuglogger(int level, const char *fmt, va_list ap);
+static void default_debuglogger(int level, const char *fmt, va_list ap) __attribute__ ((format (printf, 2, 0)));
 lwdebuglogger lwdebug_var = default_debuglogger;
 #define LW_MSG_MAXLEN 256
diff --git a/liblwgeom/stringbuffer.c b/liblwgeom/stringbuffer.c
index 0c7101997..902bd2094 100644
--- a/liblwgeom/stringbuffer.c
+++ b/liblwgeom/stringbuffer.c
@@ -193,6 +193,8 @@ stringbuffer_copy(stringbuffer_t *dst, stringbuffer_t *src)
 * check errno for reasons, documented in the printf man page.
 static int
+stringbuffer_avprintf(stringbuffer_t *s, const char *fmt, va_list ap) __attribute__ ((format (printf, 2, 0)));
+static int
 	int maxlen = (s->capacity - (s->str_end - s->str_start));
diff --git a/liblwgeom/stringbuffer.h b/liblwgeom/stringbuffer.h
index aa95ef4ca..6f8f3776e 100644
--- a/liblwgeom/stringbuffer.h
+++ b/liblwgeom/stringbuffer.h
@@ -53,7 +53,7 @@ extern void stringbuffer_destroy(stringbuffer_t *sb);
 extern void stringbuffer_clear(stringbuffer_t *sb);
 void stringbuffer_set(stringbuffer_t *sb, const char *s);
 void stringbuffer_copy(stringbuffer_t *sb, stringbuffer_t *src);
-extern int stringbuffer_aprintf(stringbuffer_t *sb, const char *fmt, ...);
+extern int stringbuffer_aprintf(stringbuffer_t *sb, const char *fmt, ...) __attribute__ ((format (printf, 2, 3)));
 extern const char *stringbuffer_getstring(stringbuffer_t *sb);
 extern char *stringbuffer_getstringcopy(stringbuffer_t *sb);
 extern lwvarlena_t *stringbuffer_getvarlenacopy(stringbuffer_t *s);
diff --git a/loader/pgsql2shp-core.c b/loader/pgsql2shp-core.c
index 0bea5081f..32a0eda3e 100644
--- a/loader/pgsql2shp-core.c
+++ b/loader/pgsql2shp-core.c
@@ -70,6 +70,9 @@ static char * goodDBFValue(char *in, char fieldType);
 /** @brief Binary to hexewkb conversion function */
 char *convert_bytes_to_hex(uint8_t *ewkb, size_t size);
+static char*
+core_asprintf(const char* format, ...) __attribute__ ((format (printf, 1, 2)));
 static char*
diff --git a/raster/loader/raster2pgsql.c b/raster/loader/raster2pgsql.c
index c2a8a8b83..f593ac64b 100644
--- a/raster/loader/raster2pgsql.c
+++ b/raster/loader/raster2pgsql.c
@@ -33,6 +33,9 @@
 #define xstr(s) str(s)
 #define str(s) #s
+static void
+loader_rt_error_handler(const char *fmt, va_list ap) __attribute__ ((format (printf, 1, 0)));
 static void
 loader_rt_error_handler(const char *fmt, va_list ap) {
 	static const char *label = "ERROR: ";
@@ -43,6 +46,9 @@ loader_rt_error_handler(const char *fmt, va_list ap) {
 	va_end(ap);
+static void
+loader_rt_warning_handler(const char *fmt, va_list ap) __attribute__ ((format (printf, 1, 0)));
 static void
 loader_rt_warning_handler(const char *fmt, va_list ap) {
 	static const char *label = "WARNING: ";
@@ -53,6 +59,9 @@ loader_rt_warning_handler(const char *fmt, va_list ap) {
 	va_end(ap);
+static void
+loader_rt_info_handler(const char *fmt, va_list ap) __attribute__ ((format (printf, 1, 0)));
 static void
 loader_rt_info_handler(const char *fmt, va_list ap) {
 	static const char *label = "INFO: ";
diff --git a/raster/rt_core/librtcore.h b/raster/rt_core/librtcore.h
index 8f4cd82b1..4c307b34b 100644
--- a/raster/rt_core/librtcore.h
+++ b/raster/rt_core/librtcore.h
@@ -258,9 +258,9 @@ extern void rtdealloc(void* mem);
  * Wrappers used for reporting errors and info.
-void rterror(const char *fmt, ...);
-void rtinfo(const char *fmt, ...);
-void rtwarn(const char *fmt, ...);
+void rterror(const char *fmt, ...) __attribute__ ((format (printf, 1, 2)));
+void rtinfo(const char *fmt, ...) __attribute__ ((format (printf, 1, 2)));
+void rtwarn(const char *fmt, ...) __attribute__ ((format (printf, 1, 2)));
  * Wrappers used for options
@@ -274,9 +274,9 @@ char* rtstrdup(const char *str);
 void * default_rt_allocator(size_t size);
 void * default_rt_reallocator(void * mem, size_t size);
 void default_rt_deallocator(void * mem);
-void default_rt_error_handler(const char * fmt, va_list ap);
-void default_rt_warning_handler(const char * fmt, va_list ap);
-void default_rt_info_handler(const char * fmt, va_list ap);
+void default_rt_error_handler(const char * fmt, va_list ap) __attribute__ ((format (printf, 1, 0)));
+void default_rt_warning_handler(const char * fmt, va_list ap) __attribute__ ((format (printf, 1, 0)));
+void default_rt_info_handler(const char * fmt, va_list ap) __attribute__ ((format (printf, 1, 0)));
 char * default_rt_options(const char* varname);
 /* Debugging macros */
Summary of changes:
 liblwgeom/lwgeom_geos.h      |  9 ++++++++-
 liblwgeom/lwgeom_log.h       |  6 +++---
 liblwgeom/lwutil.c           |  6 +++---
 liblwgeom/stringbuffer.c     |  2 ++
 liblwgeom/stringbuffer.h     |  2 +-
 loader/pgsql2shp-core.c      |  3 +++
 raster/loader/raster2pgsql.c |  9 +++++++++
 raster/rt_core/librtcore.h   | 12 ++++++------
 8 files changed, 35 insertions(+), 14 deletions(-)
hooks/post-receive
