[PostGIS] #5726: Cases where ST_Overlaps(ST_Difference(a, b), b) = TRUE
trac at osgeo.org
Sun Jun 16 15:07:48 PDT 2024
#5726: Cases where ST_Overlaps(ST_Difference(a,b),b) = TRUE
Reporter: dannytoone | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.4.3
Component: postgis | Version: 3.4.x
Resolution: wontfix | Keywords:
Changes (by pramsey):
* status: new => closed
* resolution: => wontfix
Old description:
> POSTGIS="3.4.1 ca035b9" [EXTENSION] PGSQL="160" GEOS="3.12.1-CAPI-1.18.1"
> PROJ="9.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/Users/DToone2/Library/Application Support/proj
> DATABASE_PATH=/Applications/Postgres.app/Contents/Versions/16/share/proj/proj.db"
> LIBXML="2.11.7" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0
> (Internal)"
> I'm having a tough time thinking through the relational geometry of this,
> and I can't help but think this is a bug. If b is cut out from a, then
> the result should intersect with b along the shared boundary, but it
> shouldn't overlap. A resulting overlap would indicate that the
> ST_Difference was not complete. I've recently found several cases where
> `ST_Overlaps(ST_Difference(a,b),b) = TRUE`, and I thought I'd file a bug
> report to make sure.
New description:
(Internal)"
and I can't help but think this is a bug. If b is cut out from a, then the
result should intersect with b along the shared boundary, but it shouldn't
overlap. A resulting overlap would indicate that the ST_Difference was not
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5726#comment:2>
