[SCM] PostGIS branch master updated. 3.4.0rc1-1154-g15e18d33e
git at osgeo.org
git at osgeo.org
Fri Jun 14 09:54:50 PDT 2024
the project "PostGIS".
via 15e18d33e436c8b1cfe127c089b83572ce8e6a60 (commit)
from b802f32c8a56a3d59cc16cb71429f483b1d4c878 (commit)
revisions in full, below.
commit 15e18d33e436c8b1cfe127c089b83572ce8e6a60
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Jun 14 09:54:43 2024 -0700
Support geography in ST_EstimatedExtent
Refactor some of the index lookup code.
diff --git a/liblwgeom/cunit/cu_geodetic.c b/liblwgeom/cunit/cu_geodetic.c
index 5e89aef3b..d4b676f39 100644
--- a/liblwgeom/cunit/cu_geodetic.c
+++ b/liblwgeom/cunit/cu_geodetic.c
@@ -1615,6 +1615,41 @@ static void test_gbox_to_string_truncated(void)
lwfree(c);
+static void BOX3D_BOXLL_TEST(double xmin, double ymin, double xmax, double ymax)
+ LWGEOM *lwg;
+ GBOX gbox_gc;
+ GBOX gbox_ll;
+ char wkt[256];
+ snprintf(wkt, 256, "LINESTRING(%f %f,%f %f)", xmin, ymin, xmax, ymax);
+ lwg = lwgeom_from_wkt(wkt, LW_PARSER_CHECK_NONE);
+ lwgeom_calculate_gbox_geodetic(lwg, &gbox_gc);
+ lwgeom_free(lwg);
+ // printf("\n%s",wkt);
+ gbox_geocentric_get_gbox_cartesian(&gbox_gc, &gbox_ll);
+ // printf("\nBOX(%g %g, %g %g)\n",
+ // gbox_ll.xmin, gbox_ll.ymin,
+ // gbox_ll.xmax, gbox_ll.ymax);
+ CU_ASSERT(gbox_ll.xmin <= xmin);
+ CU_ASSERT(gbox_ll.ymin <= ymin);
+ CU_ASSERT(gbox_ll.xmax >= xmax);
+ CU_ASSERT(gbox_ll.ymax >= ymax);
+void test_gbox_geocentric_get_gbox_cartesian(void)
+ BOX3D_BOXLL_TEST(-90,80, 90,80);
+ BOX3D_BOXLL_TEST(1,1, 2,2);
+ BOX3D_BOXLL_TEST(10,10, 20,20);
+ BOX3D_BOXLL_TEST(100,10, 120,10);
+ BOX3D_BOXLL_TEST(-100,10, 120,10);
** Used by test harness to register the tests in this file.
@@ -1645,4 +1680,5 @@ void geodetic_suite_setup(void)
PG_ADD_TEST(suite, test_ptarray_contains_point_sphere);
PG_ADD_TEST(suite, test_ptarray_contains_point_sphere_iowa);
PG_ADD_TEST(suite, test_gbox_to_string_truncated);
+ PG_ADD_TEST(suite, test_gbox_geocentric_get_gbox_cartesian);
diff --git a/liblwgeom/lwgeodetic.c b/liblwgeom/lwgeodetic.c
index 29eef8e95..0a1cac924 100644
--- a/liblwgeom/lwgeodetic.c
+++ b/liblwgeom/lwgeodetic.c
@@ -3579,3 +3579,134 @@ int ptarray_contains_point_sphere(const POINTARRAY *pa, const POINT2D *pt_outsid
return LW_FALSE;
+* Given a geodetic bounding volume, calculate a lon/lat bounding
+* box that should contain the original feature that gave rise to
+* the geodetic box, in plate-carre space (planar lon/lat).
+int gbox_geocentric_get_gbox_cartesian(const GBOX *gbox_geocentric, GBOX *gbox_planar)
+ /* Normalized corners of the bounding volume */
+ POINT3D corners[8];
+ POINT3D cap_center = {0,0,0};
+ double furthest_angle = 0.0;
+ double cap_angle = 0.0;
+ int all_longitudes = LW_FALSE;
+ double lon0 = -M_PI, lon1 = M_PI;
+ double lat0, lat1;
+ GEOGRAPHIC_POINT cap_center_g;
+ if (!gbox_geocentric || !gbox_planar)
+ lwerror("Null pointer passed to %s", __func__);
+ return LW_FALSE;
+#define CORNER_SET(ii, xx, yy, zz) { \
+ corners[ii].x = gbox_geocentric->xx; \
+ corners[ii].y = gbox_geocentric->yy; \
+ corners[ii].z = gbox_geocentric->zz; \
+ * First find a "centered" vector to serve as the mid-point
+ * of the input bounding volume.
+ CORNER_SET(0, xmin, ymin, zmin);
+ CORNER_SET(1, xmax, ymin, zmin);
+ CORNER_SET(2, xmin, ymax, zmin);
+ CORNER_SET(3, xmax, ymax, zmin);
+ CORNER_SET(4, xmin, ymin, zmax);
+ CORNER_SET(5, xmax, ymin, zmax);
+ CORNER_SET(6, xmin, ymax, zmax);
+ CORNER_SET(7, xmax, ymax, zmax);
+ * Normalize the volume corners
+ * and normalize the final vector.
+ for (uint32_t i = 0; i < 8; i++)
+ normalize(&(corners[i]));
+ cap_center.x += corners[i].x;
+ cap_center.y += corners[i].y;
+ cap_center.z += corners[i].z;
+ normalize(&cap_center);
+ * Find the volume corner that is furthest from the center,
+ * and calculate the angle between the center and the corner.
+ * Now we have a "cap" (center and angle)
+ double angle = vector_angle(&cap_center, &(corners[i]));
+ if (angle > furthest_angle)
+ furthest_angle = angle;
+ cap_angle = furthest_angle;
+ * Calculate the planar box that contains the cap.
+ * If the cap contains a pole, then we include all longitudes
+ cart2geog(&cap_center, &cap_center_g);
+ /* Check whether cap includes the south pole */
+ lat0 = cap_center_g.lat - cap_angle;
+ if (lat0 <= -M_PI_2)
+ lat0 = -M_PI_2;
+ all_longitudes = LW_TRUE;
+ /* Check whether cap includes the north pole */
+ lat1 = cap_center_g.lat + cap_angle;
+ if (lat1 >= M_PI_2)
+ lat1 = M_PI_2;
+ if (!all_longitudes)
+ // Compute the range of longitudes covered by the cap. We use the law
+ // of sines for spherical triangles. Consider the triangle ABC where
+ // A is the north pole, B is the center of the cap, and C is the point
+ // of tangency between the cap boundary and a line of longitude. Then
+ // C is a right angle, and letting a,b,c denote the sides opposite A,B,C,
+ // we have sin(a)/sin(A) = sin(c)/sin(C), or sin(A) = sin(a)/sin(c).
+ // Here "a" is the cap angle, and "c" is the colatitude (90 degrees
+ // minus the latitude). This formula also works for negative latitudes.
+ // The formula for sin(a) follows from the relationship h = 1 - cos(a).
+ double sin_a = sin(cap_angle);
+ double sin_c = cos(cap_center_g.lat);
+ if (sin_a <= sin_c)
+ double angle_A = asin(sin_a / sin_c);
+ lon0 = remainder(cap_center_g.lon - angle_A, 2 * M_PI);
+ lon1 = remainder(cap_center_g.lon + angle_A, 2 * M_PI);
+ else
+ lon0 = -M_PI;
+ lon1 = M_PI;
+ gbox_planar->xmin = rad2deg(lon0);
+ gbox_planar->ymin = rad2deg(lat0);
+ gbox_planar->xmax = rad2deg(lon1);
+ gbox_planar->ymax = rad2deg(lat1);
+ FLAGS_SET_GEODETIC(gbox_planar->flags, 0);
+ FLAGS_SET_Z(gbox_planar->flags, 0);
+ FLAGS_SET_M(gbox_planar->flags, 0);
+ return LW_TRUE;
diff --git a/liblwgeom/lwgeodetic.h b/liblwgeom/lwgeodetic.h
index 39053ef5f..56c6a08a5 100644
--- a/liblwgeom/lwgeodetic.h
+++ b/liblwgeom/lwgeodetic.h
@@ -144,6 +144,7 @@ void normalize(POINT3D *p);
void unit_normal(const POINT3D *P1, const POINT3D *P2, POINT3D *normal);
double sphere_direction(const GEOGRAPHIC_POINT *s, const GEOGRAPHIC_POINT *e, double d);
void ll2cart(const POINT2D *g, POINT3D *p);
+int gbox_geocentric_get_gbox_cartesian(const GBOX *gbox_geocentric, GBOX *gbox_planar);
** Prototypes for spheroid functions.
diff --git a/postgis/gserialized_estimate.c b/postgis/gserialized_estimate.c
index d182d79dc..6a505a31c 100644
--- a/postgis/gserialized_estimate.c
+++ b/postgis/gserialized_estimate.c
@@ -111,6 +111,7 @@ dimensionality cases. (2D geometry) &&& (3D column), etc.
#include "stringbuffer.h"
#include "liblwgeom.h"
+#include "lwgeodetic.h"
#include "lwgeom_pg.h" /* For debugging macros. */
#include "gserialized_gist.h" /* For index common functions */
@@ -142,15 +143,14 @@ Datum _postgis_gserialized_joinsel(PG_FUNCTION_ARGS);
Datum _postgis_gserialized_stats(PG_FUNCTION_ARGS);
/* Local prototypes */
-static Oid table_get_spatial_index(Oid tbl_oid, text *col, int *key_type, int *att_num);
-static GBOX * spatial_index_read_extent(Oid idx_oid, int key_type, int att_num);
+static Oid table_get_spatial_index(Oid tbl_oid, int16 attnum, int *key_type, int16 *idx_attnum);
+static GBOX * spatial_index_read_extent(Oid idx_oid, int idx_att_num, int key_type);
/* Other prototypes */
float8 gserialized_joinsel_internal(PlannerInfo *root, List *args, JoinType jointype, int mode);
float8 gserialized_sel_internal(PlannerInfo *root, List *args, int varRelid, int mode);
/* Old Prototype */
Datum geometry_estimated_extent(PG_FUNCTION_ARGS);
@@ -2280,211 +2280,156 @@ Datum gserialized_gist_sel(PG_FUNCTION_ARGS)
PG_RETURN_FLOAT8(selectivity);
- * Return the estimated extent of the table
- * looking at gathered statistics (or NULL if
- * no statistics have been gathered).
-PG_FUNCTION_INFO_V1(gserialized_estimated_extent);
-Datum gserialized_estimated_extent(PG_FUNCTION_ARGS)
- char *nsp = NULL;
- char *tbl = NULL;
- text *col = NULL;
- char *nsp_tbl = NULL;
- Oid tbl_oid, idx_oid = 0;
- ND_STATS *nd_stats;
- GBOX *gbox = NULL;
- bool only_parent = false;
- int key_type, att_num;
- size_t sz;
- /* We need to initialize the internal cache to access it later via postgis_oid() */
- postgis_initialize_cache();
- if ( PG_NARGS() == 4 )
- nsp = text_to_cstring(PG_GETARG_TEXT_P(0));
- tbl = text_to_cstring(PG_GETARG_TEXT_P(1));
- col = PG_GETARG_TEXT_P(2);
- only_parent = PG_GETARG_BOOL(3);
- sz = strlen(nsp) + strlen(tbl) + 6;
- nsp_tbl = palloc(sz);
- snprintf(nsp_tbl, sz, "\"%s\".\"%s\"", nsp, tbl);
- tbl_oid = DatumGetObjectId(DirectFunctionCall1(regclassin, CStringGetDatum(nsp_tbl)));
- pfree(nsp_tbl);
- else if ( PG_NARGS() == 3 )
- pfree(nsp_tbl);
- else if ( PG_NARGS() == 2 )
- tbl = text_to_cstring(PG_GETARG_TEXT_P(0));
- col = PG_GETARG_TEXT_P(1);
- sz = strlen(tbl) + 3;
- snprintf(nsp_tbl, sz, "\"%s\"", tbl);
- pfree(nsp_tbl);
- else
- elog(ERROR, "estimated_extent() called with wrong number of arguments");
- PG_RETURN_NULL();
- /* Read the extent from the head of the spatial index, if there is one */
- idx_oid = table_get_spatial_index(tbl_oid, col, &key_type, &att_num);
- if (idx_oid)
- /* TODO: how about only_parent ? */
- gbox = spatial_index_read_extent(idx_oid, key_type, att_num);
- POSTGIS_DEBUGF(2, "index for \"%s.%s\" exists, reading gbox from there", tbl, text_to_cstring(col));
- if ( ! gbox ) PG_RETURN_NULL();
- else
- POSTGIS_DEBUGF(2, "index for \"%s.%s\" does not exist", tbl, text_to_cstring(col));
- /* Fall back to reading the stats, if no index is found */
- /* Estimated extent only returns 2D bounds, so use mode 2 */
- nd_stats = pg_get_nd_stats_by_name(tbl_oid, col, 2, only_parent);
- /* Error out on no stats */
- if ( ! nd_stats ) {
- elog(WARNING, "stats for \"%s.%s\" do not exist", tbl, text_to_cstring(col));
- PG_RETURN_NULL();
- /* Construct the box */
- gbox = palloc(sizeof(GBOX));
- FLAGS_SET_GEODETIC(gbox->flags, 0);
- FLAGS_SET_Z(gbox->flags, 0);
- FLAGS_SET_M(gbox->flags, 0);
- gbox->xmin = nd_stats->extent.min[0];
- gbox->xmax = nd_stats->extent.max[0];
- gbox->ymin = nd_stats->extent.min[1];
- gbox->ymax = nd_stats->extent.max[1];
- pfree(nd_stats);
- PG_RETURN_POINTER(gbox);
-PG_FUNCTION_INFO_V1(geometry_estimated_extent);
-Datum geometry_estimated_extent(PG_FUNCTION_ARGS)
- if ( PG_NARGS() == 3 )
- PG_RETURN_DATUM(
- DirectFunctionCall3(gserialized_estimated_extent,
- PG_GETARG_DATUM(0),
- PG_GETARG_DATUM(1),
- PG_GETARG_DATUM(2)));
- PG_RETURN_DATUM(
- DirectFunctionCall2(gserialized_estimated_extent,
- PG_GETARG_DATUM(1)));
- elog(ERROR, "geometry_estimated_extent() called with wrong number of arguments");
- PG_RETURN_NULL();
-static Oid
-table_get_spatial_index(Oid tbl_oid, text *col, int *key_type, int *att_num)
+ * Given an index and table column, confirm the
+ * index was built on that column, and return the
+ * corresponding index attribute for that column.
+static int16
+index_has_attr(Oid index_oid, Oid table_oid, int16 table_attnum)
- Relation tbl_rel;
+ HeapTuple index_tuple;
+ Form_pg_index index_form;
+ int16 index_attnum = InvalidAttrNumber;
+ /* Check if the index is on the desired column */
+ index_tuple = SearchSysCache1(INDEXRELID, ObjectIdGetDatum(index_oid));
+ if (!HeapTupleIsValid(index_tuple))
+ elog(ERROR, "cache lookup failed for index %u", index_oid);
+ index_form = (Form_pg_index) GETSTRUCT(index_tuple);
+ /* Something went wrong, this index isn't on our table of interest */
+ if (index_form->indrelid != table_oid)
+ elog(ERROR, "table=%u and index=%u are not related", table_oid, index_oid);
+ /* Check if the attnum is in the indkey array */
+ for (int16 i = 0; i < index_form->indkey.dim1; i++)
+ if (index_form->indkey.values[i] == table_attnum)
+ index_attnum = i+1;
+ break;
+ ReleaseSysCache(index_tuple);
+ return index_attnum;
+ * Given an index return the access method.
+ * (We only work with GIST access method.)
+static int
+index_get_am(Oid index_oid)
+ int index_am;
+ Form_pg_class index_rel_form;
+ HeapTuple index_rel_tuple = SearchSysCache1(RELOID, ObjectIdGetDatum(index_oid));
+ if (!HeapTupleIsValid(index_rel_tuple))
+ index_rel_form = (Form_pg_class) GETSTRUCT(index_rel_tuple);
+ index_am = index_rel_form->relam;
+ ReleaseSysCache(index_rel_tuple);
+ return index_am;
+ * Given an index and index attribute, lookup the
+ * key type (box2df or gidx) of that index column.
+static int
+index_get_keytype (Oid index_oid, int16 index_attnum)
+ Oid atttypid = InvalidOid;
+ Form_pg_attribute att_form;
+ /* Get the key type for the index key? */
+ HeapTuple att_tuple = SearchSysCache2(ATTNUM,
+ ObjectIdGetDatum(index_oid),
+ Int16GetDatum(index_attnum));
+ if (!HeapTupleIsValid(att_tuple))
+ elog(ERROR, "cache lookup failed for index %u attribute %d", index_oid, index_attnum);
+ att_form = (Form_pg_attribute) GETSTRUCT(att_tuple);
+ atttypid = att_form->atttypid;
+ ReleaseSysCache(att_tuple);
+ return atttypid;
+ * Given a table and attribute number, find any
+ * "spatial index" of that attribute. For our purposes
+ * a spatial index is one we can read the top page of,
+ * namely a geometry or geography column, with
+ * a GIST index having either a gidx or box2df key.
+static Oid
+table_get_spatial_index(Oid table_oid, int16 attnum, int *key_type, int16 *idx_attnum)
+ Relation table_rel;
+ List *index_list;
ListCell *lc;
- List *idx_list;
- Oid result = InvalidOid;
- char *colname = text_to_cstring(col);
/* Lookup our spatial index key types */
Oid b2d_oid = postgis_oid(BOX2DFOID);
- Oid gdx_oid = postgis_oid(BOX3DOID);
+ Oid gdx_oid = postgis_oid(GIDXOID);
if (!(b2d_oid && gdx_oid))
return InvalidOid;
- tbl_rel = RelationIdGetRelation(tbl_oid);
- idx_list = RelationGetIndexList(tbl_rel);
- RelationClose(tbl_rel);
+ /* Read a list of all indexes on this table */
+ table_rel = RelationIdGetRelation(table_oid);
+ index_list = RelationGetIndexList(table_rel);
+ RelationClose(table_rel);
/* For each index associated with this table... */
- foreach(lc, idx_list)
+ foreach(lc, index_list)
- Form_pg_class idx_form;
- HeapTuple idx_tup;
- int idx_relam;
- Oid idx_oid = lfirst_oid(lc);
+ Oid index_oid = lfirst_oid(lc);
+ Oid atttypid;
- idx_tup = SearchSysCache1(RELOID, ObjectIdGetDatum(idx_oid));
- if (!HeapTupleIsValid(idx_tup))
- elog(ERROR, "%s: unable to lookup index %u in syscache", __func__, idx_oid);
- idx_form = (Form_pg_class) GETSTRUCT(idx_tup);
- idx_relam = idx_form->relam;
- ReleaseSysCache(idx_tup);
+ /* Is our attribute indexed by this index? */
+ *idx_attnum = index_has_attr(index_oid, table_oid, attnum);
- /* Does the index use a GIST access method? */
- if (idx_relam == GIST_AM_OID)
+ /* No, move on */
+ if (*idx_attnum == InvalidAttrNumber)
+ continue;
+ /* We only handle GIST spatial indexes */
+ if (index_get_am(index_oid) != GIST_AM_OID)
+ continue;
+ /* Is the column actually spatial? */
+ /* Only if it uses our spatial key types */
+ atttypid = index_get_keytype (index_oid, *idx_attnum);
+ if (atttypid == b2d_oid || atttypid == gdx_oid)
- Form_pg_attribute att;
- Oid atttypid;
- int attnum;
- /* Is the index on the column name we are looking for? */
- HeapTuple att_tup = SearchSysCache2(ATTNAME,
- ObjectIdGetDatum(idx_oid),
- PointerGetDatum(colname));
- if (!HeapTupleIsValid(att_tup))
- continue;
- att = (Form_pg_attribute) GETSTRUCT(att_tup);
- atttypid = att->atttypid;
- attnum = att->attnum;
- ReleaseSysCache(att_tup);
- /* Is the column actually spatial? */
- if (b2d_oid == atttypid || gdx_oid == atttypid)
- /* Save result, clean up, and break out */
- result = idx_oid;
- if (att_num)
- *att_num = attnum;
- if (key_type)
- *key_type = (atttypid == b2d_oid ? STATISTIC_KIND_2D : STATISTIC_KIND_ND);
- break;
+ /* Spatial key found in this index! */
+ *key_type = (atttypid == b2d_oid ? STATISTIC_KIND_2D : STATISTIC_KIND_ND);
+ return index_oid;
- return result;
+ return InvalidOid;
+ * Given an index and indexed attribute, look up
+ * the keys in the top page of the index, and using
+ * the appropriate key type, return a box that is the
+ * union of all those keys.
static GBOX *
-spatial_index_read_extent(Oid idx_oid, int key_type, int att_num)
+spatial_index_read_extent(Oid idx_oid, int idx_att_num, int key_type)
BOX2DF *bounds_2df = NULL;
GIDX *bounds_gidx = NULL;
@@ -2517,7 +2462,7 @@ spatial_index_read_extent(Oid idx_oid, int key_type, int att_num)
if (!GistTupleIsInvalid(ituple))
bool isnull;
- Datum idx_attr = index_getattr(ituple, att_num, idx_rel->rd_att, &isnull);
+ Datum idx_attr = index_getattr(ituple, idx_att_num, idx_rel->rd_att, &isnull);
if (!isnull)
if (key_type == STATISTIC_KIND_2D)
@@ -2553,10 +2498,13 @@ spatial_index_read_extent(Oid idx_oid, int key_type, int att_num)
else if (key_type == STATISTIC_KIND_ND && bounds_gidx)
+ lwflags_t flags = 0;
if (gidx_is_unknown(bounds_gidx))
return NULL;
- gbox = gbox_new(0);
- gbox_from_gidx(bounds_gidx, gbox, 0);
+ FLAGS_SET_Z(flags, GIDX_NDIMS(bounds_gidx) > 2);
+ FLAGS_SET_M(flags, GIDX_NDIMS(bounds_gidx) > 3);
+ gbox = gbox_new(flags);
+ gbox_from_gidx(bounds_gidx, gbox, flags);
else
return NULL;
@@ -2576,9 +2524,9 @@ Datum _postgis_gserialized_index_extent(PG_FUNCTION_ARGS)
GBOX *gbox = NULL;
int key_type;
- int att_num;
+ int16 att_num, idx_att_num = InvalidAttrNumber;
Oid tbl_oid = PG_GETARG_DATUM(0);
- text *col = PG_GETARG_TEXT_P(1);
+ char *col = text_to_cstring(PG_GETARG_TEXT_P(1));
Oid idx_oid;
if(!tbl_oid)
@@ -2587,14 +2535,194 @@ Datum _postgis_gserialized_index_extent(PG_FUNCTION_ARGS)
+ att_num = get_attnum(tbl_oid, col);
+ if (att_num == InvalidAttrNumber)
+ PG_RETURN_NULL();
+ idx_oid = table_get_spatial_index(tbl_oid, att_num, &key_type, &idx_att_num);
if (!idx_oid)
PG_RETURN_NULL();
+ gbox = spatial_index_read_extent(idx_oid, idx_att_num, key_type);
if (!gbox)
PG_RETURN_NULL();
else
+ * Given a table and column name, look up the attribute number
+ * and type of that column.
+static bool
+get_attnum_attypid(Oid table_oid, const char *col, int16 *attnum, Oid *atttypid)
+ HeapTuple att_tuple;
+ Form_pg_attribute att;
+ if (!attnum || !atttypid)
+ elog(ERROR, "%s got null input parameters", __func__);
+ /* Is the index on the column name we are looking for? */
+ att_tuple = SearchSysCache2(ATTNAME,
+ ObjectIdGetDatum(table_oid),
+ PointerGetDatum(col));
+ return false;
+ att = (Form_pg_attribute) GETSTRUCT(att_tuple);
+ *atttypid = att->atttypid;
+ *attnum = att->attnum;
+ return true;
+ * Return the estimated extent of the table
+ * looking at gathered statistics (or NULL if
+ * no statistics have been gathered).
+PG_FUNCTION_INFO_V1(gserialized_estimated_extent);
+Datum gserialized_estimated_extent(PG_FUNCTION_ARGS)
+ text *coltxt = NULL;
+ char *col = NULL;
+ int16 attnum, idx_attnum;
+ char nsp_tbl[NAMEDATALEN];
+ char *tbl;
+ Oid tbl_oid, idx_oid = 0;
+ ND_STATS *nd_stats;
+ GBOX *gbox = NULL;
+ bool only_parent = false;
+ int key_type;
+ Oid geographyOid = postgis_oid(GEOGRAPHYOID);
+ Oid geometryOid = postgis_oid(GEOMETRYOID);
+ /* We need to initialize the internal cache to access it later via postgis_oid() */
+ postgis_initialize_cache();
+ if (PG_NARGS() < 2 || PG_NARGS() > 4)
+ elog(ERROR, "ST_EstimatedExtent() called with wrong number of arguments");
+ if ( PG_NARGS() == 4 )
+ only_parent = PG_GETARG_BOOL(3);
+ if ( PG_NARGS() >= 3 )
+ char *nsp = text_to_cstring(PG_GETARG_TEXT_P(0));
+ tbl = text_to_cstring(PG_GETARG_TEXT_P(1));
+ coltxt = PG_GETARG_TEXT_P(2);
+ snprintf(nsp_tbl, NAMEDATALEN, "\"%s\".\"%s\"", nsp, tbl);
+ if ( PG_NARGS() == 2 )
+ tbl = text_to_cstring(PG_GETARG_TEXT_P(0));
+ coltxt = PG_GETARG_TEXT_P(1);
+ snprintf(nsp_tbl, NAMEDATALEN, "\"%s\"", tbl);
+ /* Parse the namespace/table strings and lookup in system catalogs */
+ tbl_oid = DatumGetObjectId(DirectFunctionCall1(regclassin, CStringGetDatum(nsp_tbl)));
+ if (!tbl_oid)
+ elog(ERROR, "cannot lookup table %s", nsp_tbl);
+ /* Get the attribute number and type from the colum name */
+ col = text_to_cstring(coltxt);
+ if (!get_attnum_attypid(tbl_oid, col, &attnum, &atttypid))
+ elog(ERROR, "column %s.\"%s\" does not exist", nsp_tbl, col);
+ /* We can only do estimates on geograpy and geometry */
+ if ((atttypid != geographyOid) && (atttypid != geometryOid))
+ elog(ERROR, "column %s.\"%s\" must be a geometry or geography", nsp_tbl, col);
+ /* Read the extent from the head of the spatial index */
+ /* works if there is a spatial index */
+ idx_oid = table_get_spatial_index(tbl_oid, attnum, &key_type, &idx_attnum);
+ if (idx_oid != InvalidOid)
+ /* TODO: how about only_parent ? */
+ gbox = spatial_index_read_extent(idx_oid, idx_attnum, key_type);
+ elog(DEBUG3, "index for %s.\"%s\" exists, reading gbox from there", nsp_tbl, col);
+ if (!gbox) PG_RETURN_NULL();
+ /* Read the extent from the stats tables, */
+ /* works if ANALYZE has been run */
+ else
+ int stats_mode = 2;
+ elog(DEBUG3, "index for %s.\"%s\" does not exist", nsp_tbl, col);
+ /* For a geography column, we need the XYZ geocentric bounds */
+ if (atttypid == geographyOid)
+ stats_mode = 3;
+ /* ND stats include an extent for the histogram */
+ nd_stats = pg_get_nd_stats_by_name(tbl_oid, coltxt, stats_mode, only_parent);
+ /* Error out on no stats */
+ if (!nd_stats)
+ elog(WARNING, "stats for \"%s.%s\" do not exist", tbl, col);
+ PG_RETURN_NULL();
+ /* Construct the box */
+ gbox = gbox_new(0);
+ gbox->xmin = nd_stats->extent.min[0];
+ gbox->xmax = nd_stats->extent.max[0];
+ gbox->ymin = nd_stats->extent.min[1];
+ gbox->ymax = nd_stats->extent.max[1];
+ if (stats_mode != 2)
+ FLAGS_SET_Z(gbox->flags, 1);
+ gbox->zmin = nd_stats->extent.min[2];
+ gbox->zmax = nd_stats->extent.max[2];
+ pfree(nd_stats);
+ /* Convert geocentric geography box into a planar box */
+ /* that users understand */
+ GBOX *gbox_planar = gbox_new(0);
+ gbox_geocentric_get_gbox_cartesian(gbox, gbox_planar);
+ PG_RETURN_POINTER(gbox_planar);
+ else
+ PG_RETURN_POINTER(gbox);
+ * Legacy prototype for Estimated_Extent()
+PG_FUNCTION_INFO_V1(geometry_estimated_extent);
+Datum geometry_estimated_extent(PG_FUNCTION_ARGS)
+ if ( PG_NARGS() == 3 )
+ PG_RETURN_DATUM(
+ DirectFunctionCall3(gserialized_estimated_extent,
+ PG_GETARG_DATUM(0),
+ PG_GETARG_DATUM(1),
+ PG_GETARG_DATUM(2)));
+ else if ( PG_NARGS() == 2 )
+ PG_RETURN_DATUM(
+ DirectFunctionCall2(gserialized_estimated_extent,
+ PG_GETARG_DATUM(1)));
+ elog(ERROR, "geometry_estimated_extent() called with wrong number of arguments");
+ PG_RETURN_NULL();
diff --git a/regress/core/estimatedextent.sql b/regress/core/estimatedextent.sql
index e7d08aef7..3ab5b3225 100644
--- a/regress/core/estimatedextent.sql
+++ b/regress/core/estimatedextent.sql
@@ -236,3 +236,28 @@ insert into test (geom1, geom2) select NULL, NULL;
ANALYZE test;
drop table test cascade;
+-- Geography estimated extent
+-- See https://trac.osgeo.org/postgis/ticket/5734
+BEGIN;
+CREATE TABLE t(g geography);
+INSERT INTO t SELECT ST_MakePoint(n,n) FROM generate_series(0,10) n;
+ANALYZE t;
+SELECT '#5734.noindex', ST_AsText(
+ ST_BoundingDiagonal(ST_EstimatedExtent('t','g')),
+ 0
+CREATE INDEX ON t USING GIST (g);
+SELECT '#5734.index', ST_AsText(
+ 0
+TRUNCATE t;
+SELECT '#5734.index_nodata', ST_AsText(
+ 0
+ROLLBACK;
diff --git a/regress/core/estimatedextent_expected b/regress/core/estimatedextent_expected
index a28486cb5..ed11cec58 100644
--- a/regress/core/estimatedextent_expected
+++ b/regress/core/estimatedextent_expected
@@ -47,3 +47,6 @@ NOTICE: drop cascades to 2 other objects
3.b null|
4.a box|BOX(-100 -100,100 100)
4.b box|BOX(-200 -200,200 200)
+#5734.noindex|LINESTRING(-2 -2,12 12)
+#5734.index|LINESTRING(-2 -2,12 12)
+#5734.index_nodata|
Summary of changes:
liblwgeom/cunit/cu_geodetic.c | 36 +++
liblwgeom/lwgeodetic.c | 131 ++++++++++
liblwgeom/lwgeodetic.h | 1 +
postgis/gserialized_estimate.c | 476 +++++++++++++++++++++-------------
regress/core/estimatedextent.sql | 25 ++
regress/core/estimatedextent_expected | 3 +
6 files changed, 498 insertions(+), 174 deletions(-)
hooks/post-receive
