[SCM] PostGIS branch master updated. 3.4.0rc1-1163-gf6a29f699
Tue Jun 18 02:43:55 PDT 2024
the project "PostGIS".
       via  f6a29f699cae07dcd4231d179f9bdf6a521cd678 (commit)
      from  d599d1a248dc655aa4d2e831773e36c4eb40e80d (commit)
revisions in full, below.
commit f6a29f699cae07dcd4231d179f9bdf6a521cd678
Author: DeepL <noreply-mt-deepl at weblate.org>
Date:   Tue Jun 18 09:40:20 2024 +0000
    Translated PostGIS Manual using Weblate (French)
    Currently translated at 98.7% (5635 of 5707 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index fec003402..5d6ebaf82 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -8,7 +8,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-03-14 17:56+0000\n"
-"PO-Revision-Date: 2024-06-18 09:38+0000\n"
+"PO-Revision-Date: 2024-06-18 09:43+0000\n"
 "Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/fr/>\n"
@@ -15212,6 +15212,8 @@ msgid ""
 "ST_ClusterWithinWin is equivalent to running <xref "
 "linkend=\"ST_ClusterDBSCAN\"/> with <code>minpoints => 0</code>."
 msgstr ""
+"ST_ClusterWithinWin est équivalent à l'exécution de <xref linkend="
+"\"ST_ClusterDBSCAN\"/> avec <code>minpoints => 0</code>."
 #. Tag: para
 #, no-c-format
@@ -24219,6 +24221,7 @@ msgstr ""
 msgid ""
 "Returns the n-D distance between the A and B geometries or bounding boxes"
 msgstr ""
+"Renvoie la distance n-D entre les géométries A et B ou les boîtes englobantes"
 #. Tag: para
 #, no-c-format
@@ -29087,6 +29090,8 @@ msgid ""
 "Returns a simplified representation of a geometry, using the Douglas-Peucker "
 "algorithm."
 msgstr ""
+"Renvoie une représentation simplifiée d'une géométrie, en utilisant "
+"l'algorithme de Douglas-Peucker."
 #. Tag: para
 #, no-c-format
@@ -29099,6 +29104,13 @@ msgid ""
 "within the tolerance distance of the simplified linework. The result may not "
 "be valid even if the input is."
 msgstr ""
+"Calcule une représentation simplifiée d'une géométrie en utilisant "
+"l'algorithme <link xlink:href=\"https://en.wikipedia.org/wiki/"
+"Ramer%E2%80%93Douglas%E2%80%93Peucker_algorithm\">Douglas-Peucker</link>. La "
+"<varname>tolérance</varname> de simplification est une valeur de distance, "
+"dans les unités du SRS d'entrée. La simplification supprime les sommets qui "
+"se trouvent à l'intérieur de la distance de tolérance du réseau simplifié. "
+"Le résultat peut ne pas être valide même si l'entrée l'est."
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/fr/postgis-manual.po | 14 +++++++++++++-
 1 file changed, 13 insertions(+), 1 deletion(-)
hooks/post-receive
