[SCM] PostGIS branch master updated. 3.4.0rc1-1165-g7fbf95a1d
git at osgeo.org
git at osgeo.org
Tue Jun 18 02:46:59 PDT 2024
the project "PostGIS".
via 7fbf95a1d8bb503ca728c8e9ca9f66048f425bb8 (commit)
via b472fb9f61dabdb0d6136ca712c4b286fea4a271 (commit)
from f6a29f699cae07dcd4231d179f9bdf6a521cd678 (commit)
revisions in full, below.
commit 7fbf95a1d8bb503ca728c8e9ca9f66048f425bb8
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Tue Jun 18 09:44:14 2024 +0000
Translated PostGIS Manual using Weblate (French)
Currently translated at 98.7% (5636 of 5707 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index d58bdf10c..a0b46488b 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-03-14 17:56+0000\n"
"PO-Revision-Date: 2024-06-18 09:46+0000\n"
-"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
"Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/fr/>\n"
"Language: fr\n"
@@ -29119,6 +29119,10 @@ msgid ""
"GeometryCollections), but only line and polygon elements are simplified. "
"Endpoints of linear geometry are preserved."
msgstr ""
+"La fonction peut être appelée avec n'importe quel type de géométrie (y "
+"compris les GeometryCollections), mais seuls les éléments linéaires et "
+"polygonaux sont simplifiés. Les extrémités des géométries linéaires sont "
+"préservées."
#. Tag: para
#, no-c-format
commit b472fb9f61dabdb0d6136ca712c4b286fea4a271
Author: Thomas Muguet <thomas.muguet at oslandia.com>
Date: Tue Jun 18 09:43:53 2024 +0000
index 5d6ebaf82..d58bdf10c 100644
@@ -8,8 +8,8 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-06-18 09:43+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-06-18 09:46+0000\n"
+"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
"Language: fr\n"
@@ -29105,11 +29105,11 @@ msgid ""
"be valid even if the input is."
msgstr ""
"Calcule une représentation simplifiée d'une géométrie en utilisant "
-"l'algorithme <link xlink:href=\"https://en.wikipedia.org/wiki/"
-"Ramer%E2%80%93Douglas%E2%80%93Peucker_algorithm\">Douglas-Peucker</link>. La "
-"<varname>tolérance</varname> de simplification est une valeur de distance, "
-"dans les unités du SRS d'entrée. La simplification supprime les sommets qui "
-"se trouvent à l'intérieur de la distance de tolérance du réseau simplifié. "
+"l'algorithme <link xlink:href=\"https://fr.wikipedia.org/wiki/"
+"Algorithme_de_Douglas-Peucker\">Douglas-Peucker</link>. La variable "
+"<varname>tolerance</varname> de simplification est une valeur de distance, "
+"dans les unités du SRS d'entrée. La simplification supprime les sommets dont "
+"la distance au réseau simplifié est inférieure à la distance de tolérance. "
"Le résultat peut ne pas être valide même si l'entrée l'est."
#. Tag: para
Summary of changes:
doc/po/fr/postgis-manual.po | 16 ++++++++++------
1 file changed, 10 insertions(+), 6 deletions(-)
hooks/post-receive
