[SCM] PostGIS branch master updated. 3.4.0rc1-1205-g8ef0bfa81
Tue Jun 18 05:32:52 PDT 2024
the project "PostGIS".
       via  8ef0bfa81d15f00042e202df63fe4f4f38abf956 (commit)
       via  3709ed9625561b113e590982b42cec24e759b0d5 (commit)
      from  da7ba76227b5655f4ad22579a6bbf0b11c3fcfb1 (commit)
revisions in full, below.
commit 8ef0bfa81d15f00042e202df63fe4f4f38abf956
Author: DeepL <noreply-mt-deepl at weblate.org>
Date:   Tue Jun 18 12:30:55 2024 +0000
    Translated PostGIS Manual using Weblate (French)
    Currently translated at 99.4% (5677 of 5707 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index d71f90d90..145a9669b 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-03-14 17:56+0000\n"
 "PO-Revision-Date: 2024-06-18 12:32+0000\n"
-"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/fr/>\n"
 "Language: fr\n"
@@ -41761,6 +41761,10 @@ msgid ""
 "(1.2.0+). Otherwise the function is just a wrapper around "
 "CG_StraightSkeleton (slower case)."
 msgstr ""
+"Retourne un axe médian approximatif pour l'entrée aréolaire en se basant sur "
+"son squelette droit. Utilise une API spécifique à SFCGAL lorsqu'elle est "
+"construite avec une version compatible (1.2.0+). Sinon, la fonction est "
+"juste une enveloppe autour de CG_StraightSkeleton (cas le plus lent)."
 #. Tag: para
 #, no-c-format
commit 3709ed9625561b113e590982b42cec24e759b0d5
Author: Thomas Muguet <thomas.muguet at oslandia.com>
Date:   Tue Jun 18 12:29:34 2024 +0000
index 2557e858a..d71f90d90 100644
@@ -8,7 +8,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-06-18 12:29+0000\n"
+"PO-Revision-Date: 2024-06-18 12:32+0000\n"
@@ -41724,7 +41724,7 @@ msgstr "Disponibilité : 3.5.0 - nécessite SFCGAL >= 1.5.0."
 #. Tag: para
 #, no-c-format
 msgid "Requires SFCGAL >= 1.5.0"
-msgstr "Requiert SFCGAL >= 1.5.0"
+msgstr "Nécessite SFCGAL >= 1.5.0"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/fr/postgis-manual.po | 10 +++++++---
 1 file changed, 7 insertions(+), 3 deletions(-)
hooks/post-receive
