[SCM] PostGIS branch master updated. 3.4.0rc1-1207-g31fc730ab
git at osgeo.org
git at osgeo.org
Tue Jun 18 05:33:18 PDT 2024
the project "PostGIS".
via 31fc730abbd2695e83c45a513dab1ead77c5399d (commit)
via c0698e259ddd9b42aa1381e77d288e205ae1a42f (commit)
from 8ef0bfa81d15f00042e202df63fe4f4f38abf956 (commit)
revisions in full, below.
commit 31fc730abbd2695e83c45a513dab1ead77c5399d
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Tue Jun 18 12:33:04 2024 +0000
Translated PostGIS Manual using Weblate (French)
Currently translated at 99.5% (5679 of 5707 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index 6f9911935..5a09bdf1b 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-03-14 17:56+0000\n"
"PO-Revision-Date: 2024-06-18 12:33+0000\n"
-"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
"Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/fr/>\n"
"Language: fr\n"
@@ -42110,7 +42110,7 @@ msgstr "Calcule un squelette (straight skeleton) à partir d'une géométrie"
#. Tag: para
#, no-c-format
msgid "Requires SFCGAL >= 1.3.8 for option use_distance_as_m"
-msgstr ""
+msgstr "Requiert SFCGAL >= 1.3.8 pour l'option use_distance_as_m"
#. Tag: para
#, no-c-format
commit c0698e259ddd9b42aa1381e77d288e205ae1a42f
Author: Thomas Muguet <thomas.muguet at oslandia.com>
Date: Tue Jun 18 12:32:49 2024 +0000
index 145a9669b..6f9911935 100644
@@ -8,8 +8,8 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-06-18 12:32+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-06-18 12:33+0000\n"
+"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
"Language: fr\n"
@@ -41762,9 +41762,9 @@ msgid ""
"CG_StraightSkeleton (slower case)."
msgstr ""
"Retourne un axe médian approximatif pour l'entrée aréolaire en se basant sur "
-"son squelette droit. Utilise une API spécifique à SFCGAL lorsqu'elle est "
-"construite avec une version compatible (1.2.0+). Sinon, la fonction est "
-"juste une enveloppe autour de CG_StraightSkeleton (cas le plus lent)."
+"son squelette (straight skeleton). Utilise une API spécifique à SFCGAL "
+"lorsque compilée avec une version compatible (1.2.0+). Sinon, la fonction "
+"est juste un wrapper de CG_StraightSkeleton (cas le plus lent)."
#. Tag: para
#, no-c-format
@@ -41879,7 +41879,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ", <xref linkend=\"CG_StraightSkeleton\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"CG_StraightSkeleton\"/>"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/fr/postgis-manual.po | 12 ++++++------
1 file changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
