[SCM] PostGIS branch master updated. 3.4.0rc1-1233-g848d9e453
git at osgeo.org
git at osgeo.org
Wed Jun 26 22:28:42 PDT 2024
the project "PostGIS".
via 848d9e4536b57d802317ecd64e85aebdca25ab93 (commit)
from 5795ded4a99591985c41fcdedbacc3e336520bde (commit)
revisions in full, below.
commit 848d9e4536b57d802317ecd64e85aebdca25ab93
Author: Regina Obe <lr at pcorp.us>
Date: Thu Jun 27 01:28:36 2024 -0400
Update pot
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index af518f50f..0960d4e26 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
msgstr ""
"Project-Id-Version: PACKAGE VERSION\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2024-03-14 17:56+0000\n"
+"POT-Creation-Date: 2024-06-27 05:26+0000\n"
"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
"Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -4242,7 +4242,7 @@ msgid ""
"Adds a linestring to an existing topology and returns a set of edge "
"identifiers forming it up. The given line will snap to existing nodes or "
"edges within given tolerance. Existing edges and faces may be split by the "
-"line."
+"line. New nodes and faces may be added."
msgstr ""
#. Tag: para
@@ -5255,6 +5255,13 @@ msgid ""
"sys error will be thrown."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"is deprecated as of 3.5.0. Use <xref linkend=\"TopoGeo_AddLineString\"/> "
+"instead."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -7943,6 +7950,11 @@ msgstr ""
msgid "Dane Springmeyer"
msgstr ""
+#. Tag: member
+#, no-c-format
+msgid "Dapeng Wang"
+msgstr ""
#. Tag: member
#, no-c-format
msgid "Daryl Herzmann"
@@ -8303,6 +8315,11 @@ msgstr ""
msgid "Ron Mayer"
msgstr ""
+#. Tag: member
+#, no-c-format
+msgid "Sam Peters"
+msgstr ""
#. Tag: member
#, no-c-format
msgid "Sebastiaan Couwenberg"
@@ -8403,6 +8420,11 @@ msgstr ""
msgid "Volf Tomáš"
msgstr ""
+#. Tag: member
+#, no-c-format
+msgid "Zuo Chenwei"
+msgstr ""
#. Tag: term
#, no-c-format
msgid "Corporate Sponsors"
@@ -8505,6 +8527,11 @@ msgstr ""
msgid "Geographic Data BC"
msgstr ""
+#. Tag: link
+#, no-c-format
+msgid "HighGo"
+msgstr ""
#. Tag: simpara
#, no-c-format
msgid "Hunter Systems Group"
@@ -9316,8 +9343,7 @@ msgid ""
"&reference_relationship; &reference_measure; &reference_overlay; "
"&reference_processing; &reference_coverage; &reference_transformation; "
"&reference_cluster; &reference_bbox; &reference_lrs; &reference_trajectory; "
-"&reference_transaction; &reference_version; &reference_guc; "
-"&reference_troubleshooting;"
+"&reference_version; &reference_guc; &reference_troubleshooting;"
msgstr ""
#. Tag: title
@@ -13729,6 +13755,215 @@ msgid ""
"distance tolerance."
msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Removes points that are irrelevant for rendering a specific rectangluar view "
+"of a geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Returns a <xref linkend=\"geometry\"/> without points being irrelevant for "
+"rendering the geometry within a given rectangluar view."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This function can be used to quickly preprocess geometries that should be "
+"rendered only within certain bounds."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Only geometries of type (MULTI)POLYGON and (MULTI)LINESTRING are evaluated. "
+"Other geometries keep unchanged."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "In contrast to <code>ST_ClipByBox2D()</code> this function"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"sorts out points without computing new intersection points which avoids "
+"rounding errors and usually increases performance,"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "returns a geometry with equal or similar point number,"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "leads to the same rendering result within the specified view, and"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"may introduce self-intersections which would make the resulting geometry "
+"invalid (see example below)."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"For polygons, this function does currently not ensure that the result is "
+"valid. This situation can be checked with <xref linkend=\"ST_IsValid\"/> and "
+"repaired with <xref linkend=\"ST_MakeValid\"/>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Example: ST_RemoveIrrelevantPointsForView() applied to a polygon. Blue "
+"points remain, the rendering result (light-blue area) within the grey view "
+"box remains as well."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Example: Due to the fact that points are just sorted out and no new points "
+"are computed, the result of ST_RemoveIrrelevantPointsForView() may contain "
+"self-intersections."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_Intersection\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Removes small parts (polygon rings or linestrings) of a geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Returns a <xref linkend=\"geometry\"/> without small parts (exterior or "
+"interior polygon rings, or linestrings)."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This function can be used as preprocessing step for creating simplified "
+"maps, e. g. to remove small islands or holes."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"It evaluates only geometries of type (MULTI)POLYGON and (MULTI)LINESTRING. "
+"Other geometries remain unchanged."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If <parameter>minSizeX</parameter> is greater than 0, parts are sorted out "
+"if their width is smaller than <parameter>minSizeX</parameter>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If <parameter>minSizeY</parameter> is greater than 0, parts are sorted out "
+"if their height is smaller than <parameter>minSizeY</parameter>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Both <parameter>minSizeX</parameter> and <parameter>minSizeY</parameter> are "
+"measured in coordinate system units of the geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"For polygon types, evaluation is done separately for each ring which can "
+"lead to one of the following results:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "the original geometry,"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "a POLYGON with all rings with less vertices,"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"a POLYGON with a reduced number of interior rings (having possibly less "
+"vertices),"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "a POLYGON EMPTY, or"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"a MULTIPOLYGON with a reduced number of polygons (having possibly less "
+"interior rings or vertices), or"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "a MULTIPOLYGON EMPTY."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"For linestring types, evaluation is done for each linestring which can lead "
+"to one of the following results:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "a LINESTRING with a reduced number of vertices,"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "a LINESTRING EMPTY,"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"a MULTILINESTRING with a reduced number of linestrings (having possibly less "
+"vertices), or"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "a MULTILINESTRING EMPTY."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Example: ST_RemoveSmallParts() applied to a multi-polygon. Blue parts remain."
+msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid "Return the geometry with vertex order reversed."
@@ -21918,6 +22153,13 @@ msgid ""
"'miter_limit' is also accepted as a synonym for 'mitre_limit'."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Behavior changed in GEOS 3.11 so offset curves now have the same direction "
+"as the input line, for both positive and negative offsets."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -30910,7 +31152,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"In mathematical terms: <emphasis>ST_Touches(A, B) ⇔ (Int(A) ⋂ Int(B) ≠ ∅) ∧ "
+"In mathematical terms: <emphasis>ST_Touches(A, B) ⇔ (Int(A) ⋂ Int(B) = ∅) ∧ "
"(A ⋂ B ≠ ∅) </emphasis>"
msgstr ""
@@ -31319,13 +31561,6 @@ msgstr ""
msgid "Check if a surface is or not planar"
msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Availability: 2.2.0: This was documented in 2.1.0 but got accidentally left "
-"out in 2.1 release."
-msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid "Test if the geometry is a solid. No validity check is performed."
@@ -31397,8 +31632,8 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-", <xref linkend=\"ST_MakeSolid\"/>, <xref linkend=\"ST_IsSolid\"/>, <xref "
-"linkend=\"ST_Area\"/>"
+", <xref linkend=\"CG_MakeSolid\"/>, <xref linkend=\"CG_IsSolid\"/>, <xref "
+"linkend=\"CG_Area\"/>"
msgstr ""
#. Tag: refpurpose
@@ -31408,6 +31643,76 @@ msgid ""
"geometries will return 0."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "&sqlmm_compliant; SQL-MM IEC 13249-3: 9.1 (same as CG_3DVolume)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"When closed surfaces are created with WKT, they are treated as areal rather "
+"than solid. To make them solid, you need to use <xref "
+"linkend=\"CG_MakeSolid\"/>. Areal geometries have no volume. Here is an "
+"example to demonstrate."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"CG_MakeSolid\"/>, <xref linkend=\"CG_IsSolid\"/>"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "is deprecated as of 3.5.0. Use <xref linkend=\"CG_ForceLHR\"/> instead."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "is deprecated as of 3.5.0. Use <xref linkend=\"CG_IsPlanar\"/> instead."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Availability: 2.2.0: This was documented in 2.1.0 but got accidentally left "
+"out in 2.1 release."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "is deprecated as of 3.5.0. Use <xref linkend=\"CG_IsSolid\"/> instead."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"is deprecated as of 3.5.0. Use <xref linkend=\"CG_MakeSolid\"/> instead."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"is deprecated as of 3.5.0. Use <xref linkend=\"CG_Orientation\"/> instead."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "is deprecated as of 3.5.0. Use <xref linkend=\"CG_3DArea\"/> instead."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_MakeSolid\"/>, <xref linkend=\"ST_IsSolid\"/>, <xref "
+"linkend=\"ST_Area\"/>"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "is deprecated as of 3.5.0. Use <xref linkend=\"CG_Volume\"/> instead."
+msgstr ""
#. Tag: para
#, no-c-format
msgid "&sqlmm_compliant; SQL-MM IEC 13249-3: 9.1 (same as ST_3DVolume)"
@@ -31447,11 +31752,6 @@ msgstr ""
msgid "NOTE: this function returns a geometry representing the intersection."
msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ", <xref linkend=\"ST_Intersection\"/>"
-msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -31498,6 +31798,12 @@ msgstr ""
msgid "Perform 3D difference"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"is deprecated as of 3.5.0. Use <xref linkend=\"CG_3DDifference\"/> instead."
+msgstr ""
#. Tag: para
#, no-c-format
msgid "Returns that part of geom1 that is not part of geom2."
@@ -31525,8 +31831,8 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-", <xref linkend=\"ST_AsX3D\"/>, <xref linkend=\"ST_3DIntersection\"/> <xref "
-"linkend=\"ST_3DUnion\"/>"
+", <xref linkend=\"ST_AsX3D\"/>, <xref linkend=\"CG_3DIntersection\"/> <xref "
+"linkend=\"CG_3DUnion\"/>"
msgstr ""
#. Tag: refpurpose
@@ -31548,7 +31854,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid ", <xref linkend=\"ST_Distance\"/>"
+msgid ", <xref linkend=\"CG_Distance\"/>"
msgstr ""
#. Tag: refpurpose
@@ -31578,6 +31884,12 @@ msgstr ""
msgid "Computes the 3D convex hull of a geometry."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"is deprecated as of 3.5.0. Use <xref linkend=\"CG_3DConvexHull\"/> instead."
+msgstr ""
#. Tag: para
#, no-c-format
msgid "Original geometry overlaid with 3D convex hull"
@@ -31593,6 +31905,12 @@ msgstr ""
msgid "Perform 3D intersection"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"is deprecated as of 3.5.0. Use <xref linkend=\"CG_3DIntersection\"/> instead."
+msgstr ""
#. Tag: para
#, no-c-format
msgid "Return a geometry that is the shared portion between geom1 and geom2."
@@ -31645,6 +31963,11 @@ msgstr ""
msgid "Perform 3D union."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "is deprecated as of 3.5.0. Use <xref linkend=\"CG_3DUnion\"/> instead."
+msgstr ""
#. Tag: para
#, no-c-format
msgid "Availability: 3.3.0 aggregate variant was added"
@@ -31660,6 +31983,16 @@ msgid ""
"do and like most aggregates, it also ignores NULL geometries."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<emphasis role=\"bold\">Aggregate variant:</emphasis> returns a geometry "
+"that is the 3D union of a rowset of geometries. The CG_3DUnion() function is "
+"an \"aggregate\" function in the terminology of PostgreSQL. That means that "
+"it operates on rows of data, in the same way the SUM() and AVG() functions "
+"do and like most aggregates, it also ignores NULL geometries."
+msgstr ""
#. Tag: para
#, no-c-format
msgid "Original 3D geometries overlaid. geom2 is the one with transparency."
@@ -31673,8 +32006,8 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"linkend=\"ST_3DDifference\"/>"
+"linkend=\"CG_3DDifference\"/>"
msgstr ""
#. Tag: refpurpose
@@ -31682,6 +32015,12 @@ msgstr ""
msgid "Computes an Alpha-shape enclosing a geometry"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"is deprecated as of 3.5.0. Use <xref linkend=\"CG_AlphaShape\"/> instead."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -31731,21 +32070,21 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "Availability: 3.3.0 - requires SFCGAL >= 1.4.1."
+msgid "Availability: 3.5.0 - requires SFCGAL >= 1.4.1."
msgstr ""
#. Tag: para
#, no-c-format
msgid ""
"Alpha-shape of a MultiPoint (same example As <xref "
-"linkend=\"ST_OptimalAlphaShape\"/>)"
+"linkend=\"CG_OptimalAlphaShape\"/>)"
msgstr ""
#. Tag: para
#, no-c-format
msgid ""
"Alpha-shape of a MultiPoint, allowing holes (same example as <xref "
msgstr ""
#. Tag: para
@@ -31757,7 +32096,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid ", <xref linkend=\"ST_OptimalAlphaShape\"/>"
+msgid ", <xref linkend=\"CG_OptimalAlphaShape\"/>"
msgstr ""
#. Tag: refpurpose
@@ -31820,6 +32159,13 @@ msgstr ""
msgid "Compute the approximate medial axis of an areal geometry."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"is deprecated as of 3.5.0. Use <xref linkend=\"CG_ApproximateMedialAxis\"/> "
+"instead."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -31840,6 +32186,13 @@ msgid ""
"Return a constrained Delaunay triangulation around the given input geometry."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"is deprecated as of 3.5.0. Use <xref "
+"linkend=\"CG_ConstrainedDelaunayTriangles\"/> instead."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -31850,7 +32203,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "ST_ConstrainedDelaunayTriangles of 2 polygons"
+msgid "CG_ConstrainedDelaunayTriangles of 2 polygons"
msgstr ""
#. Tag: para
@@ -31861,7 +32214,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-", <xref linkend=\"ST_TriangulatePolygon\"/>, <xref linkend=\"ST_Tesselate\"/"
+", <xref linkend=\"ST_TriangulatePolygon\"/>, <xref linkend=\"CG_Tesselate\"/"
">, <xref linkend=\"ST_ConcaveHull\"/>, <xref linkend=\"ST_Dump\"/>"
msgstr ""
@@ -31870,6 +32223,11 @@ msgstr ""
msgid "Extrude a surface to a related volume"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "is deprecated as of 3.5.0. Use <xref linkend=\"CG_Extrude\"/> instead."
+msgstr ""
#. Tag: para
#, no-c-format
msgid "Original octagon formed from buffering point"
@@ -31915,7 +32273,7 @@ msgid ""
"fall down to the contour edges (the roof's border), regardless of where it "
"falls on the roof. The function computes this extrusion aka \"roof\" on a "
"polygon. If the argument body_height > 0, so the polygon is extruded like "
-"with ST_Extrude(polygon, 0, 0, body_height). The result is an union of these "
+"with CG_Extrude(polygon, 0, 0, body_height). The result is an union of these "
"polyhedralsurfaces."
msgstr ""
@@ -31950,6 +32308,12 @@ msgstr ""
msgid "Performs Minkowski sum"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"is deprecated as of 3.5.0. Use <xref linkend=\"CG_MinkowskiSum\"/> instead."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -32018,6 +32382,13 @@ msgid ""
"value."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"is deprecated as of 3.5.0. Use <xref linkend=\"CG_OptimalAlphaShape\"/> "
+"instead."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -32044,23 +32415,28 @@ msgid ""
"varname> argument is specified as true."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.3.0 - requires SFCGAL >= 1.4.1."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
"Optimal alpha-shape of a MultiPoint (same example as <xref "
-"linkend=\"ST_AlphaShape\"/>)"
+"linkend=\"CG_AlphaShape\"/>)"
msgstr ""
#. Tag: para
#, no-c-format
msgid ""
"Optimal alpha-shape of a MultiPoint, allowing holes (same example as <xref "
msgstr ""
#. Tag: para
#, no-c-format
-msgid ", <xref linkend=\"ST_AlphaShape\"/>"
+msgid ", <xref linkend=\"CG_AlphaShape\"/>"
msgstr ""
#. Tag: refpurpose
@@ -32113,6 +32489,13 @@ msgstr ""
msgid "Straight Skeleton of polygon"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"is deprecated as of 3.5.0. Use <xref linkend=\"CG_StraightSkeleton\"/> "
+"instead."
+msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid ""
@@ -32120,6 +32503,12 @@ msgid ""
"a TIN or collection of TINS"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"is deprecated as of 3.5.0. Use <xref linkend=\"CG_Tesselate\"/> instead."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -32799,155 +33188,6 @@ msgid ""
"linkend=\"ST_DistanceCPA\"/>, <xref linkend=\"geometry_distance_cpa\"/>"
msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Long Transaction Support"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"These functions implement a row locking mechanism to support long "
-"transactions. They are provided primarily for implementors of the <link "
-"xlink:href=\"http://www.opengeospatial.org/standards/wfs\">Web Feature "
-"Service</link> specification."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"For the locking mechanism to operate correctly the <emphasis "
-"role=\"bold\">serializable</emphasis> <link xlink:href=\"http://www."
-"postgresql.org/docs/current/static/transaction-iso.html\"> transaction "
-"isolation level</link> must be used."
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid ""
-"<refpurpose>Adds an authorization token to be used in the current "
-"transaction.</refpurpose>"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<para>Adds an authorization token to be used in the current transaction.</"
-"para>"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Adds the current transaction identifier and authorization token to a "
-"temporary table called <varname>temp_lock_have_table</varname>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Availability: 1.1.3"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid ""
-"Creates a trigger on a table to prevent/allow updates and deletes of rows "
-"based on authorization token."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Creates trigger on a table to prevent/allow updates and deletes of rows "
-"based on an authorization token. Identify rows using <rowid_col> "
-"column."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If a_schema_name is not passed in, then searches for table in current schema."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If an authorization trigger already exists on this table function errors."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "If Transaction support is not enabled, function throws an exception."
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Disables long transaction support."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Disables long transaction support. This function removes the long "
-"transaction support metadata tables, and drops all triggers attached to lock-"
-"checked tables."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Drops meta table called <varname>authorization_table</varname> and a view "
-"called <varname>authorized_tables</varname> and all triggers called "
-"<varname>checkauthtrigger</varname>"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Enables long transaction support."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Enables long transaction support. This function creates the required "
-"metadata tables. It must be called once before using the other functions in "
-"this section. Calling it twice is harmless."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Creates a meta table called <varname>authorization_table</varname> and a "
-"view called <varname>authorized_tables</varname>"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Sets lock/authorization for a row in a table."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Sets lock/authorization for a specific row in a table. "
-"<varname>an_auth_token</varname> is a text value. <varname>expire_dt</"
-"varname> is a timestamp which defaults to <emphasis>now() + 1 hour</"
-"emphasis>. Returns 1 if lock has been assigned, 0 otherwise (i.e. row is "
-"already locked by another auth.)"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Removes all locks held by an authorization token."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Removes all locks held by specified authorization token. Returns the number "
-"of locks released."
-msgstr ""
#. Tag: title
#, no-c-format
msgid "Affine Transformations"
@@ -34000,9 +34240,24 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-", <xref linkend=\"PostGIS_GEOS_Version\"/>, <xref "
-"linkend=\"PostGIS_Lib_Version\"/>, <xref linkend=\"PostGIS_LibXML_Version\"/"
-">, <xref linkend=\"PostGIS_Version\"/>"
+", <xref linkend=\"PostGIS_Full_Version\"/>, <xref "
+"linkend=\"PostGIS_GEOS_Version\"/>, <xref linkend=\"PostGIS_Lib_Version\"/>, "
+"<xref linkend=\"PostGIS_LibXML_Version\"/>, <xref "
+"linkend=\"PostGIS_Version\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Returns the version number of the PROJ library against which PostGIS was "
+"built."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Returns the version number of the PROJ library, or against which PostGIS was "
+"built."
msgstr ""
#. Tag: refpurpose
@@ -34036,6 +34291,14 @@ msgstr ""
msgid "<para>Returns build date of the PostGIS scripts.</para>"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"PostGIS_GEOS_Version\"/>, <xref "
+"linkend=\"PostGIS_Lib_Version\"/>, <xref linkend=\"PostGIS_LibXML_Version\"/"
+">, <xref linkend=\"PostGIS_Version\"/>"
+msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid ""
Summary of changes:
doc/po/templates/postgis-manual.pot | 635 +++++++++++++++++++++++++-----------
1 file changed, 449 insertions(+), 186 deletions(-)
hooks/post-receive
