[PostGIS] #5752: Wrong calculation in geography variant of ST_ClosestPoint()
trac at osgeo.org
Thu Jun 27 03:52:24 PDT 2024
Reporter: vogg | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.4.3
Component: postgis | Version: 3.4.x
Keywords: |
The `geography` variant of `ST_ClosestPoint()` fails to calculate the
closest point correctly.
Example query to reproduce this issue:
SELECT ST_AsText(ST_ClosestPoint(
'LINESTRING (18 9, 18 1)'::geography,
'POINT (16 4)'::geography
)) AS cp;
Expected result:
cp
POINT(18 4)
Actual result:
cp
POINT(16 4)
When using `geometry` instead of `geography`, the calculation of
`ST_ClosestPoint()` works correctly:
'LINESTRING (18 9, 18 1)'::geometry,
'POINT (16 4)'::geometry
)) AS cp;
Result:
cp
POINT(18 4)
PostgreSQL version:
PostgreSQL 13.15 (Debian 13.15-1.pgdg110+1) on x86_64-pc-linux-gnu,
compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
PostGIS version:
POSTGIS="3.4.2 c19ce56" [EXTENSION] PGSQL="130" GEOS="3.9.0-CAPI-1.16.2"
PROJ="7.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
(Internal)"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5752>
