[PostGIS] #5636: berrie 32bit failing on garden tests on ST_MakePolygon
trac at osgeo.org
Mon May 20 11:03:25 PDT 2024
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: Website Management, Bots
Component: QA/buildbots | Version: master
Resolution: | Keywords:
Comment (by strk):
I tried getting more output but it still doesn't help, check this out:
https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie/5916/console
19:59:02 -------------------------------------------------
19:59:02 PostGIS garden tests in progress (it will take time)
19:59:02 psql -X -ad postgis_garden < \
19:59:02 ../doc/postgis_gardentest_35.sql \
19:59:02 > postgis_garden_result.txt 2>&1 || { \
19:59:02 tail postgis_garden_result.txt; false; }
20:00:20 INSERT 0 1
20:00:20 BEGIN;
20:00:20 BEGIN
20:00:20 INSERT INTO
postgis_garden_log35_output(logid, log_output)
20:00:20 SELECT logid,
query_to_xml(log_sql, false,false,'') As log_output
20:00:20 FROM postgis_garden_log35
ORDER BY logid DESC LIMIT 1;UPDATE postgis_garden_log35 SET log_end =
clock_timestamp()
20:00:20 server closed the connection unexpectedly
20:00:20 This probably means the server terminated abnormally
20:00:20 before or while processing the request.
20:00:20 connection to server was lost
How did you get the `ST_MakePolygon` call Regina ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5636#comment:4>
