[SCM] PostGIS branch master updated. 3.5.0-238-g01f39857f
git at osgeo.org
git at osgeo.org
Tue Apr 1 02:47:41 PDT 2025
the project "PostGIS".
via 01f39857f7597ee68a211560c379cb038dc64980 (commit)
from b93591733d9d474cd4c39cb5771d1c8c36ad3e43 (commit)
revisions in full, below.
commit 01f39857f7597ee68a211560c379cb038dc64980
Author: Kristian Thy <thy at 42.dk>
Date: Tue Apr 1 08:16:58 2025 +0000
Translated PostGIS Manual using Weblate (Danish)
Currently translated at 0.1% (9 of 5756 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/da/
diff --git a/doc/po/da/postgis-manual.po b/doc/po/da/postgis-manual.po
index 6ef728e21..faec9958b 100644
--- a/doc/po/da/postgis-manual.po
+++ b/doc/po/da/postgis-manual.po
@@ -5,13 +5,16 @@ msgstr ""
"Project-Id-Version: PACKAGE VERSION\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-11-19 11:58+0000\n"
-"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
-"Last-Translator: Automatically generated\n"
-"Language-Team: none\n"
+"PO-Revision-Date: 2025-04-01 09:47+0000\n"
+"Last-Translator: Kristian Thy <thy at 42.dk>\n"
+"Language-Team: Danish <https://weblate.osgeo.org/projects/postgis/"
+"postgis-manual/da/>\n"
"Language: da\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
+"Plural-Forms: nplurals=2; plural=n != 1;\n"
+"X-Generator: Weblate 5.4.3\n"
#. Tag: chapter
#, no-c-format
@@ -21,12 +24,12 @@ msgstr ""
#. Tag: title
#, no-c-format
msgid "PostGIS Administration"
-msgstr ""
+msgstr "Administration af PostGIS"
#. Tag: title
#, no-c-format
msgid "Configuring raster support"
-msgstr ""
+msgstr "Opsætning af rasterunderstøttelse"
#. Tag: para
#, no-c-format
@@ -34,6 +37,8 @@ msgid ""
"If you enabled raster support you may want to read below how to properly "
"configure it."
msgstr ""
+"Hvis du har aktiveret rasterunderstøttelse bør du læse her hvordan du sætter "
+"det rigtigt op."
#. Tag: para
#, no-c-format
@@ -45,16 +50,25 @@ msgid ""
"For PostGIS 2.2, you can use the more cross-platform approach of setting the "
"corresponding <xref linkend=\"PostGIS_GUC\"/>."
msgstr ""
+"Startende med PostGIS 2.1.3 er understøttelse af raster udenfor databasen "
+"samt alle raster-drivere slået fra som standard. For at aktivere disse, skal "
+"du sætte følgende miljøvariable på serveren: "
+"<varname>POSTGIS_GDAL_ENABLED_DRIVERS</varname> og "
+"<varname>POSTGIS_ENABLE_OUTDB_RASTERS</varname>. Fra PostGIS 2.2 kan du "
+"sætte den tilsvarende <xref linkend=\"PostGIS_GUC\"/>, hvilket er mere "
+"platform-neutralt."
#. Tag: para
#, no-c-format
msgid "If you want to enable offline raster:"
-msgstr ""
+msgstr "Hvis du vil aktivere offline raster:"
#. Tag: para
#, no-c-format
msgid "Any other setting or no setting at all will disable out of db rasters."
msgstr ""
+"Enhver anden indstilling - eller slet ingen indstilling - vil deaktivere "
+"raster udenfor databasen."
#. Tag: para
#, no-c-format
@@ -62,6 +76,8 @@ msgid ""
"In order to enable all GDAL drivers available in your GDAL install, set this "
"environment variable as follows"
msgstr ""
+"For at aktivere alle GDAL-drivere i din GDAL-installation skal du sætte "
+"miljøvariablen som følger"
#. Tag: para
#, no-c-format
@@ -69,11 +85,13 @@ msgid ""
"If you want to only enable specific drivers, set your environment variable "
"as follows:"
msgstr ""
+"Hvis du kun vil aktivere enkelte drivere, skal du sætte din miljøvariabel "
+"som følger:"
#. Tag: para
#, no-c-format
msgid "If you are on windows, do not quote the driver list"
-msgstr ""
+msgstr "Hvis du bruger Windows skal du ikke sætte driver-listen i gåseøjne"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/da/postgis-manual.po | 32 +++++++++++++++++++++++++-------
1 file changed, 25 insertions(+), 7 deletions(-)
hooks/post-receive
